AmD Technik- Servicing and Diagnostics- Mail Order
uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Wiring loom for bora vents and W8 light
Last post Sat, Jan 9 2010 7:34 AM by markyb. 68 replies.
Page 1 of 2 (69 items) 1 2 Next >
  • Thu, Feb 15 2007 2:15 PM Wiring loom for bora vents and W8 light
    • Posts 8,142
    As the wiring loom for the bora vents is now almost impossible to get hold of I decided to make my own, here is a short how to on the procedure involved.
    The loom can be made utilising the original plug circled above, (part number 1J0 973 119) but you will need to purchase the corresponding sockets from VW (part number 1J0 973 332) and three repair wires for the terminals (part number 000 979 132), at the time of writing this the plugs were unavailable so I had to use another method. I decided to replace the plugs on the vents to enable me to create the loom rather than just splicing the vent wiring directly into the cars wiring system behind each vent.
    The materials needed: bought from Vehicle Wiring Products of Ilkeston near Derby
    3m Thin wall Blue/Slate wire 1mm - 26p/m
    3m Thin wall Brown wire 1mm - 26p/m
    3 x 2-Way 2.8mm Mini Connector (If you are not using VW part 1J0 973 332)- 60p each
    3m Black braided sleeve (5 - 7mm) - 72p/m
    Cloth Tape (or you could use insulation tape) - £2.47
    Crimping Tool (If you don't have one already) - £8.55
    Spare terminals for the connectors in case of mistakes 10 of each - £2.00 (total)
    Tap connector x 2 (splice with blade connector) - 0.15p each
    Earth Ring (un insulated crimp ring terminal pk of 10) - £1.00
    This comes to £12.10 + P&P without the crimping tool.
    The principals for making the loom are the same if you are using original plugs or the replacements, the only difference will be is that you won't have to change the plug on the end of each vent lead. If you do change the plugs on the vents then crimp on the female connectors to the cables and put them into the male portion of the plug assembly ensuring to keep the orientation of the colours the same in each plug.
    Note: With the latch on top the blue wire is to the left when the plug is viewed from the rear, I used this orientation on all the vent plugs then matched the sockets to it.
    To make the loom cut lengths of the two cables corresponding to the above measurements and thread braided sleeve over them. Wind the cloth tape around the ends of the braid to stop it fraying but leave enough wire exposed to make up the connections.
    Use the male connectors and the female sockets to make up the cable to the above diagram, on the plug on the far left there is only one brown and one blue cable but the other plugs will have two of each cable in them. Ensure you match the orientation of the wires in these plugs to the ones on the end of the vent wires.
    On the free end of the final cable cut the braided sleeve back 25cm and on the end of the brown wire (earth) crimp on the ring terminal, on the blue/grey wire crimp on the connector to go with the tap splice.
    You should end up with this:
    Feed the cable behind the dash securing it out of the way with cable ties and connect each vent plug up as you install them to the plug on the loom.
    Connect the earth connection to the earthing terminal under the dash by the steering column:
    Clamp the splice to the blue/grey wire that comes out of the dash light dimmer switch then connect the wire from the loom to the splice, this connectioned is the variable output from the dimmer so the vents will dim with the rest of the dash lights.
    Connect the plug back up to the dimmer switch and give the vents a test.
    If you have a W8 light aswell (or thinking of adding one later) you could put a fourth connector in near to the right hand side of the loom to connect the illumination wire to.Yes
     Plug part numbers:
    The part numbers to make up the wiring adaptor for the W8 light are as follows:
    (Courtesy of Wazzer)
    Repair wire
    000 979 131
    2  needed
    Adaptor plug for existing loom
    893 971 993
    1  needed
    Repair wire
    000 979 103
    2  needed
    W8 light plug
    3B0 972 706
    1  needed
    For the W8 adaptor loom you need to look at each plug and the numbers that correspond to the wire slots.
    Adaptor Socket
    W8 Plug
    3
    à
    4
    2
    à
    5
    1
    à
    3
    1
    wire runs down to fuse box for +ve feed or to vent loom
    W8 light install
    Removing the golf vents:
  • Thu, Feb 15 2007 4:20 PM Re: Wiring loom for bora vents
    noelksmall
    • Joined on Fri, Jul 14 2006
    • Posts 620
    excellent post, Thanks
    I too am attempting to make a loom, though i have managed to order the original connectors (1J0 973 332) from vw today, should have them on monday and will go from there.
    if everything goes well, i will post up details.
    cheers
    Noel
    GT TDI 115| w8 light mod | aero wipers | polo rear aero | Nokia CK7W | vw 6 disc boot changer | vw sat nav | UKMKIV Sticker| cruise |
  • Tue, Jul 17 2007 7:25 AM Re: Wiring loom for bora vents
    mwill82
    • Joined on Tue, Feb 6 2007
    • Posts 323
    Sorry if this sounds stupid, but I'm not ace with electrics, and although I've had cars in the past, the Golf I have now is kind of my project car which I'm trying to do stuff to, and doing it myself when I can (not including clusters because of vagcom or steering wheel)
    So basically, this guide is to make a wiring loom which you plug you the Bora vent plugs into? With the one end connecting up to the earth terminal and to the dimmer control to power and control the illuminations?
    If thats totally wrong I apologise now.
    VW Golf GT TDi 110bhp -:- 16" Montreal 2 Alloys -:- 40% Window Tints -:- R32 Steering wheel and interior trim -:- Bora Sports Cluster -:- Bora Vents -:- More to come..........
  • Tue, Jul 17 2007 9:50 AM Re: Wiring loom for bora vents
    • Posts 8,142
    That's correct, if you buy the plugs from VW then the wiring loom is totally plug and play Yes
  • Wed, Mar 12 2008 1:01 PM Re: Wiring loom for bora vents
    hotboy836
    • Joined on Thu, Aug 30 2007
    • Posts 8,399
    old_n07:
    The loom can be made utilising the original plug (circled above, part 1J0 973 119) but you will need to purchase the corresponding sockets from VW (part number 1J0 973 332), at the time of writing this the plugs were unavailable so I had to use another method. I decided to replace the plugs on the vents to enable me to create the loom rather than just splicing the vent wiring directly into the cars wiring system behind each vent.
    any idea where i can get the above part mate. got my vents today and fitted them but missign this for my illumination?
    thanks
  • Wed, Mar 12 2008 1:52 PM Re: Wiring loom for bora vents
    CoolHands
    • Joined on Tue, Feb 14 2006
    • Posts 474
    you need to order it from a VW dealer. The part number is there ^
    4motion. Click here for my website: Supercharged 4Motion Golf. (+air-con fan mod).
  • Wed, Mar 12 2008 2:01 PM Re: Wiring loom for bora vents
    golf1973
    • Joined on Sun, Aug 19 2007
    • Posts 105
    Part Number is  1J0 973 332,  order 3 of these from VW.
    Stu
    Black Bolf GT TDI ASZ - Highline
    Bora Vents, W8 Light, Coil Overs, 18" Wheels
  • Wed, Mar 12 2008 3:58 PM Re: Wiring loom for bora vents
    hotboy836
    • Posts 8,399
    thanks guys. im getting them in from koolvw
    much obliged
  • Sun, Mar 16 2008 5:56 PM Re: Wiring loom for bora vents
    Wazzzer
    • Joined on Wed, Nov 15 2006
    • Posts 993
    you'll need 3 repair wires too, I can get you the numbers for them as well if you need it
  • Sun, Mar 16 2008 5:59 PM Re: Wiring loom for bora vents
    hotboy836
    • Posts 8,399
    just thre man, what do i need the repair wires for?
  • Sun, Mar 16 2008 6:30 PM Re: Wiring loom for bora vents
    Wazzzer
    • Posts 993
    the repair wires clip into those plugs to give you the means of connecting the wires inside (ie male to female)
  • Sun, Mar 16 2008 6:36 PM Re: Wiring loom for bora vents
    hotboy836
    • Posts 8,399
    ahhh i thought i cud just get the female connector as i have the wire already. cheers dude.
  • Sun, Mar 16 2008 6:40 PM Re: Wiring loom for bora vents
    Wazzzer
    • Posts 993
    you need 3 off 000 979 131 Wink
  • Sun, Apr 6 2008 10:18 PM Re: Wiring loom for bora vents
    graeme86
    Golf IV R32 3.2 240PS
    • Joined on Wed, Jul 14 2004
    • Posts 769
    "Vehicle Wiring Products" also sell the correct raw VW terminals which will fit into the VW connectors. You just get the terminal without any wire attached, so you can make up any length of loom you want.
    Their equivalent of the female VW repair wire 000 979 131 terminal is part number 3-8020 in their catalogue.
    The male terminal (VW repair wire 000 979 132) is 3-8010 in their catalogue.
    There are a lot of other VW connectors they sell as well - see this page:
    http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/mouldingterms.php
    Smile
  • Mon, Apr 7 2008 1:43 AM Re: Wiring loom for bora vents
    • Posts 8,142
    Nice find Greame Yes
    The thing I noticed is that at 65p each + P+P they could work out dearer than buying the repair wire from VW which are ~ £1.50 each (two terminals) Confused
  • Mon, Apr 7 2008 2:00 AM Re: Wiring loom for bora vents
    graeme86
    • Posts 769
    ...with useless bits of yellow wire attached!Smile
    Just means extra splices if you want to run longer wires...and you cannot crimp the water seals correctly to them either (if required such as in engine bay connectors), as they are already crimped!
    Surely it would be cheaper for VW to inventory just the connectors instead of great wads of wire (...like they used too)?
    I can see the benefit possibly for the very small terminals like those used in the cluster plugs as they would be very hard to actually crimp correctly "in the field".
    VW charge about $6 for one of those repair wires over here by the way.
    ...okay....I've calmed down now...Music
  • Mon, Jun 9 2008 3:04 PM Re: Wiring loom for bora vents
    Filby1
    Golf IV V6 4motion 2.8 24v AQP 204PS
    • Joined on Mon, Dec 10 2007
    • Posts 885
     Oh i can make my own loom now
    What I Got: 2001 Silver 2.8 V6 4Motion | 3 Dr | Sun Roof |Full sports leather | Multi Function wheel | Heated Seats | Winter Pack | Aero Wipers | Stubby Aerial | Phillips Xtream 80%+ | Diodems | TT Quick Shift | Rear ATB Spoiler | R Line Gear Nob and surround | Full R32 Alloy | Gamma + DSP | Full FIS | Rain Sensing Wipers |
  • Sat, Jun 21 2008 7:32 PM Re: Wiring loom for bora vents
    nadlad786
    • Joined on Mon, Jan 15 2007
    • Posts 132
    what size earth ring do u need ?
    ARL 196BHP:R-TECH: 03+ OEM XENONS : FULL MILTEK TWIN:PARKING SENSORS: BORO SPORT FIS CLOCKS:BLUETOOTH:MP3:RECARO LEATHER:AUTO DIMMER:RAIN SENSORS:HEADLIGHT WASHERS: BBS RC's: SUNROOF: CRUISE: CLIMATE: PIPERCROSS FILTER:REAR TINTS ALL MODS DECLARED!!
  • Mon, Feb 2 2009 1:56 PM Re: Wiring loom for bora vents and W8 light
    geezer_3000
    Golf IV Final Edition 1.6 16v AUS 105PS
    • Joined on Fri, Oct 31 2008
    • Posts 140
     Evening all. I have bought some illuminated bora vents and to my suprise they have the female and male plugs and some more wire comming off the male plug. So how would i wire them up?  My idea was to crimp? and solder all the blue and grey wires to some speaker cable then to the blue grey on the dimmerswitch and do the same with brown wires or send the brown wires to earthing points.
    Can anyone suggest anything better or am I on the right path. Also does anyone know where I can get a crimping tool and soldering set for the job.
    Cheers in advance.
    WANTED: BORA SPORT INSTRUMENT CLUSTERS 1J5 920 926 A.
  • Mon, Feb 2 2009 2:00 PM Re: Wiring loom for bora vents and W8 light
    • Posts 8,142
     All the info you need to make the loom is in the first post appart from the soldering iron, try Maplins for that.
  • Mon, Feb 2 2009 4:09 PM Re: Wiring loom for bora vents and W8 light
    geezer_3000
    • Posts 140
     Thanks No7Yes
  • Mon, Feb 2 2009 4:21 PM Re: Wiring loom for bora vents and W8 light
    kevinm
    • Joined on Tue, Oct 14 2008
    • Posts 64
    ChippedIre Remapped | Sachs Race Engineering Clutch | 312mm front brakes with Ferodo DS2500 | Heated Leather Recaros | .:R32 Steering Wheel | Bora Sport Clocks | Bora Vents | Net Optic to Brushed Alu | VCDS v908 + VagTacho
  • Mon, Feb 2 2009 4:30 PM Re: Wiring loom for bora vents and W8 light
    Dent Reform
    Golf IV V6 2motion 3.2 24v BHE supercharged
    • Joined on Tue, Feb 28 2006
    • Posts 12,123
    kevinm:
    YEP but don't forget the 12 EURO postage Coffee
    "I detest chequebook show slags"
    The Elite 24v VR6 Club: Member #424 charged as well
    If you cant walk the walk then dont talk the talk.....
  • Tue, Feb 3 2009 4:12 AM Re: Wiring loom for bora vents and W8 light
    Wazzzer
    • Posts 993
    cheers for updating the first post with my W8 pics and how to mate Yes
  • Tue, Feb 3 2009 7:30 AM Re: Wiring loom for bora vents and W8 light
    • Posts 8,142
    Wazzzer:
    Just made sense to put it all in one place Yes
  • Wed, Feb 25 2009 6:39 AM Re: Wiring loom for bora vents and W8 light
    julian
    • Joined on Thu, Feb 5 2009
    • Posts 168
    Im sorry if this question has an obvious answer, but google images isnt helping me -
    The w8 light is set into the headliner, right?  Im not understanding what the mod with this is - dont all golf have them, and whats different with the bora one?
    One more question, which i havent been able to immediatly work out from the above -
    I see those crimp connectors in the original post that 'puncture' the original loom for extra feeds.
    Is is possible to install the bora loom in such a way as the process is really 100% reversable?  I meen can the live and earth be got via a try connector somewhere, rather than irreversably tapping into the existing looms?
    Is that what oldno7 is saying above with "That's correct, if you buy the plugs from VW then the wiring loom is totally plug and play" ?
    Golf IV SE TDI 1.9 (ALH)
  • Wed, Feb 25 2009 6:43 AM Re: Wiring loom for bora vents and W8 light
    julian
    • Posts 168
    ...oh, and one last thing -
    ive just had a look on ebay "complete items" and it seems like people are paying silly money for the vent sets - in some cases £30 more than what ive seen in the archives here as being the new dealer price!
    Is that because the prices in the archives here are old, and the current price of the parts has risen a load?
    Im wondering if anyone has done all this recently, and got up-to-date figures on the conversion using all new parts?
    j
  • Wed, Feb 25 2009 4:33 PM Re: Wiring loom for bora vents and W8 light
    Wazzzer
    • Posts 993
    £80 is about the going rate for the vents nowadays. The W8 light has LED downlights compared to the standard Golf/Bora light which doesn't. Also the icons are illuminated
    The process is reversable, all it would leave on the + wire on the original car loom if you removed it all is a small nick that wouldn't be noticable unless you went looking for it
  • Thu, Mar 5 2009 2:23 AM Re: Wiring loom for bora vents and W8 light
    triman
    • Joined on Mon, Aug 7 2006
    • Posts 49
    Hi Neil,
    Can you tell me what size earth ring to purcahse for the 3mm wire as there are various sizes on the suppliers site.
    4.3 /5.3mm hole
    6.4 / 8.4mm hole
    10.5mm hole
    Dave
    Black 3 Door GT TDI 150 PD
    Performance Torque Remap, Stubby Aerial, Anniversary Headlights, KVW100 (Auto Windows),Miles to Empty, Illuminated needles,Cruise Control, Anti Hijack, Aero Rear Wiper, Armrest, 312mm Front Brake Upgrades,Eibach Proset Springs/Dampers,more to come.........Milltek,/ Eibach ARB
  • Thu, Mar 5 2009 8:38 AM Re: Wiring loom for bora vents and W8 light
    teeach
    • Joined on Wed, Feb 11 2009
    • Posts 52
    will be doin this. thanks for the guide
  • Thu, Mar 5 2009 8:51 AM Re: Wiring loom for bora vents and W8 light
    • Posts 8,142
    triman:
    Hi Neil,
    4.3 /5.3mm hole
    6.4 / 8.4mm hole
    10.5mm hole
    Dave
    Not too sure as I used some ring terminals that came with a crimping kit I have, It was a blue terminal (I removed the blue sleeving) and had a center diameter of about 5.5mm and I don't think the external diameter really matters too much.
  • Sat, Mar 21 2009 10:09 PM Re: Wiring loom for bora vents and W8 light
    vwmadcat
    • Joined on Tue, Sep 25 2007
    • Posts 858
     where can I get the loom for the bora vents and w8 light???
  • Sun, Mar 22 2009 1:30 AM Re: Wiring loom for bora vents and W8 light
    • Posts 8,142
    The only place to get the vent loom is to make it, or get someone to do it for you.
    The W8 loom is available on Ebay.de or Kufatec.
  • Sun, Mar 22 2009 6:25 AM Re: Wiring loom for bora vents and W8 light
    vwmadcat
    • Posts 858
     old no7 can you make ths for me?? I have pm'd Chris I know he made some a while ago
  • Sun, Mar 22 2009 2:21 PM Re: Wiring loom for bora vents and W8 light
    • Posts 8,142
    vwmadcat:
    No, I don't make them sorry. PM aRd he made some a while back for someone.
