Kool-VW.co.uk
uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - Clutch and Gearbox » Gti clutch judder
Gti clutch judder
Last post Wed, Sep 10 2008 3:08 PM by Fireblade69. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Mar 31 2007 11:34 AM Gti clutch judder
    staffs150
    • Joined on Sun, May 1 2005
    • Posts 150
    Getting a juddering sensation when in first gear when pulling away with some load on the engine,ie mainly on any incline. it's there up until the car's away and moving. it feels like a throbbing coming up the pedals and steering until the clutch is fully out.
    Gti 05 plate, 15k.
    Any one else had this??
    05' year gti
    reflex silver
    very standard!
  • Thu, Apr 5 2007 2:27 PM Re: Gti clutch judder
    russell golf gti
    Golf V GTI 2.0 200PS
    • Joined on Tue, Apr 3 2007
    • Posts 36
    staffs150:
    Gti 05 plate, 15k.
    i get it occasionally. it's not bothering me though, the car is still under warranty.
    i'd not let it bother you, unless it's shaking the car. if you feel the need to take it to the dealer and have a fix, please let me know the outcome.
    cheers.
    russell.
    Golf now for sale!
  • Fri, Aug 3 2007 2:03 AM Re: Gti clutch judder
    MK5GTI-PA
    • Joined on Fri, Jul 6 2007
    • Posts 308
    I get the same, sounds a bit rough. Dealer has checked the car and reckons its fine......, but he would.
    MKV 2.0T Gti FSi , Red, Heated Elec Leather, Armrest, Monza IIs, REVO Phase 1 - SOLD !!
    S3 (8P) - Sprint Blue, Loads of trinkets....
  • Fri, Mar 28 2008 3:30 PM Re: Gti clutch judder
    blue182
    • Joined on Sat, Sep 10 2005
    • Posts 454
     sorry to dig this up but mine is a bit like this too (perhaps not to the extent spoke about here tho)
    Edition 30 • Candy White • Lux pack • Front Armrest • ipod • Tinted Rear Glass • Multifunction Steering Wheel • Highline • Sunroof • Zenons • Soundpack • Cruise • Rns510 Nav •
  • Tue, Apr 8 2008 7:11 AM Re: Gti clutch judder
    MK5GTI-PA
    • Posts 308
    Not sure if its related but I had this problem and my clutch ended up slipping after it was REVOd.
    After stripping down the Dual Mass flywheel was found to be completely shagged, and the clutch had sustained damage as a result. Luckily VW did the lot under warranty, and the dealer was excellent I have to say.
    So it may be that the juddering is linked to a poorly DMF ?? maybe coincidence? who knows.
    Remember the clutch is NOT covered under warranty after 6 months old unless its considered as `mechanical failure` and not `wear and tear`., a very grey area and dependant on how supportive your dealer is.
    Good luck.
    Paul
  • Mon, May 26 2008 9:33 PM Re: Gti clutch judder
    mrx
    • Joined on Tue, May 27 2008
    • Posts 10
    Hi all,
    I'm new to this forum and just came across this thread.  I'm in Australia, and mine has had a slight vibration exactly as described above from about 500km of age.  I pointed it out to the dealer straight away and they replaced the flywheel under warranty.  It lasted for about 200km and then the noise/vibration came back.  It doesn't seem to affect performance and only really happens at low revs on a hill start, so I let it slide for a while.
    I just recently started going to another dealer and pointed out the problem to them.  They said it's common with the dual mass flywheels and nothing to worry about - that they replaced a few flywheels in the early days but it never lasts very long so they wont do it any more unless there is actually a problem with clutch performance.
  • Tue, May 27 2008 1:25 AM Re: Gti clutch judder
    Zippy V
    • Joined on Wed, Feb 6 2008
    • Posts 23
     There is also a thread on this problem on www.honestjohn.co.uk. The judders is a recognised problem from the dual mass flywheel caused by heat from slipping the clutch
  • Wed, Sep 10 2008 2:06 PM Re: Gti clutch judder
    Bora Bora Bora!
    • Joined on Wed, Feb 28 2007
    • Posts 97
    What Zippy V said. The dmf flywheel is rubbish and a lot of them self destruct. Don't let the dealers con you on this by claiming your friction plate is worn out. If it's juddering it's most likely on its way out.
    http://forums.tdiclub.com/showthread.php?t=137014
  • Wed, Sep 10 2008 3:08 PM Re: Gti clutch judder
    Fireblade69
    • Joined on Wed, Sep 10 2008
    • Posts 5
    Hi,
    I had this problem after caning the gti round the Nordschliefe and after the girlfriend put the car into the Armco I had to take it to a garage, the guy there, (Marc - TTE Engineering, Herr Toppen Geezeren), said that the clutch had overheated and warped.  As it was a fairly new clutch, he said it would wear even after a few months but it was common on tuned Golfs.  He is a Golf and E30 Bimmer specialist so I was wondering if you've been thrashing it?
    If not, why not Big Smile
    The Dark Side of the Hoon!
