uk-mkivs » The Mk4 (MkIV) Community » MkIV (Mk4) Golf & Bora Discussion » VAGCOM ERROR
VAGCOM ERROR
Last post 21/08/2008 3:38 PM by mrmike. 11 replies.
Page 1 of 1 (12 items)
  • 06/04/2007 4:53 PM VAGCOM ERROR
    Seb1.8T
    • Joined on 12/11/2006
    • Posts 763
    Hi All!
    The other day my emmissions lamp came on (symbol right next to 20mph) and had the car vagcom checked by a fellow member yesterday and this is what it throw up:
    Address 01     -------------------------------------------------------
       Controller: 06A 906 032 HJ
       Component: 1.8L R4/5VT         0002
       Coding: 11500
       Shop #: WSC 14136
       WVWZZZ1JZ2W604123     VWZ6Z0B0001258
    1 Fault Found:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
                P1136 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Can someone give me a insight into what this might be?
  • 20/07/2008 8:09 AM Re: VAGCOM ERROR
    Jatie 150
    • Joined on 22/08/2005
    • Posts 350
     did you find a fix ?
  • 20/07/2008 8:41 AM Re: VAGCOM ERROR
    mrmike
    • Joined on 28/01/2007
    • Posts 257
     this can be a number of things...
    My own car has the same DTC which Im still trying to trace but only happens (seams to happen) in damp weather and on a sunday? I've carryed out alot of diag changed 02 sensors tryed AFM with on hope.
    talking to the master tech a skoda and dub the first thing is to change both oxygen sensors which work out to be £90 eachTongue Tied
    if this does not fix the problem there is an air leak after the AFM (air mass meter) which could be anywhere, most common on the AUM engine is the vaccum pipes and sensors under the inlet manifold and to the fuel pressure reg, if NFF Then you'll be start changing gaskets and pipes till the correct componant is found.
    I know this is'nt aload of help but its just were to start as im still trying to get the fault to happen again after ive changed/ adjusted a couple of bits.
    Mike
  • 20/07/2008 8:48 AM Re: VAGCOM ERROR
    Jatie 150
    • Posts 350
    I  have checked all the pipes etc & found  no leaks Hmm
    Looks like process of elimination will have to change them 1 by 1 Angry
  • 20/07/2008 9:03 AM Re: VAGCOM ERROR
    peace1969
    Golf IV V5 2.3 10v 150PS
    • Joined on 25/09/2005
    • Posts 850
  • 20/07/2008 10:32 AM Re: VAGCOM ERROR
    Pat
    • Joined on 18/04/2002
    • Posts 2,851
    Jatie 150:
    have you done a pressure test, or just looked at the pipes?
  • 20/07/2008 12:08 PM Re: VAGCOM ERROR
    Jatie 150
    • Posts 350
    Pat:
    Jatie 150:
    Just looked @ them .....
    How do i  pressure test on them ?
    Or should i get the car hooked upto a proper vag-com so it can be exaclty pin pointed whats @ fault ?
  • 21/07/2008 2:07 AM Re: VAGCOM ERROR
    mrmike
    • Posts 257
     get your self a vaccum tester from helfords etc, 9 time outer 10 this will be an air leak than doesn't want to be found, i've had a couple in my workshop with this problem 02 sensors sorted them, but my own car is proving more troblesome.
    More than likly the air leak will be from the pipes under the inlet manifold which you'll have to move the cover and metal plate.
    Mike
  • 21/08/2008 1:19 PM Re: VAGCOM ERROR
    Jatie 150
    • Posts 350
     Hi all I have been having trouble with the golf with DTC 17544 as you know &  found out the dam vac leak today its behind the inlet manifold ...
    What I need is a pic of the rubber pipes that run into the inlet manifold please  & also the part numbers for them ...
    & its not the Y shaped pipe thats leaking its 2 pipes with sort of got tape around it  ?
    Jatie
  • 21/08/2008 1:28 PM Re: VAGCOM ERROR
    mrmike
    • Posts 257
     i'm going to have aqnother look at mine now see if i can see a leak.
    Mike
  • 21/08/2008 2:18 PM Re: VAGCOM ERROR
    Jatie 150
    • Posts 350
     Yeah Mike its a pig to get to but its behind inlet manifold sort of near the dip stick area ...
    I need to remove the metal assembly in front of manifold 1st but wanted to know exact part name & number of the pipe or pipes   before I go butcher everthing ....
  • 21/08/2008 3:38 PM Re: VAGCOM ERROR
    mrmike
    • Posts 257
     I've had the lot off before for this fault but didnt find a fault but prob take the manifold off polish it and have a better look at all the pipes.
    Mike
