Midlands based VAG performance tuning, diagnostics and rolling road specialists
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Clutch and Gearbox » Clutch/Gearbox!!
Clutch/Gearbox!!
Last post Sun, Feb 2 2003 11:05 AM by Ridders. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Dec 20 2002 9:15 AM Clutch/Gearbox!!
    AndyPandy
    • Joined on Tue, Oct 1 2002
    I've got a 99 Golf Turbo. When cold the gearbox is awful between 1st and 2nd, sometimes can't get it into second.
    Any ideas? Anything I could check/how?
    Once it warms up, it's not as bad......
  • Fri, Dec 20 2002 10:59 AM Clutch/Gearbox!!
    RAM
    • Joined on Fri, Jul 5 2002
    My wifes 2001 GTI T has just started doing the same plus it all feels a bit grindy. This could be an oil thing.
    I want to know if the engine and gearbox oil are separate.
  • Fri, Dec 20 2002 5:09 PM Clutch/Gearbox!!
    Mo
    Golf V GTI Edition 30 2.0 230PS DSG
    • Joined on Fri, Nov 29 2002
    • Posts 2,494
    Had the same problem with my last car.What my mechanic did was to change the gearbox oil using synthetic gear oil and an oil additive.Never had the problem again.
  • Sat, Dec 21 2002 1:44 AM Clutch/Gearbox!!
    bigjon
    • Joined on Wed, Sep 11 2002
    • Posts 46
    I think all 02J transmissions are a bit like
    this. Mine is really juddery when it goes
    in when cold. OK when warmed up. I have
    Mobil 1 SHC 75-90 in there as well. I am
    going to change my read dogmount bushing for
    a poly one to see if this helps.
    Audi S4 Biturbo
    H&R ARBs
    RS4 Suspension
    RS4 Downpipes
    RS4 ICs
    Milltek Dual
    K04's, Lowered CR and MRC magic..
  • Sat, Dec 21 2002 6:53 AM Clutch/Gearbox!!
    batty
    • Joined on Mon, Dec 16 2002
    • Posts 5
    This problem is due to a weak synchromesh into 2nd gear. The old 02A gearbox used to have the same problem - I thought VW would have sorted this by now.
    The basic design issue is that the synchro has to work realy hard when shifting from 1st to 2nd, because this represents the greatest ratio difference of all the gears. Most gearboxes use triple cone synchronisers on 2nd gear to synchronise this large speed difference.
    The symptoms are worst when cold because: -
    1. The co-efficient of friction between the oil and synchro cones is less when cold (more slippery), and
    2. The oil is more difficult to wipe from between the friction surfaces when cold (more viscous or sticky)
    and worse when worn because the friction surface has reduced on the synchro cones.
    The problem is also worse when making a quick shift since the synchro unit needs to change the speed in less time.
    I would recommend: -
    1.VW should repair if still under warranty.
    2.Synthetic oil may help the problem - but be careful since viscosity and / or co-efficient of friction changes can upset all the synchros.
    3. Have a new synchro unit fitted on 2nd (Stealth Racing did my 02A transmission)
    - Sorry if I sound a bit nerdy on this, but have recently been working on synchro design of the 4WD transmission fitted to the new Range Rover & on another transmission fitted to the Toureg & Cayenne.
    - batty
  • Sat, Dec 21 2002 3:31 PM Clutch/Gearbox!!
    Felix
    • Joined on Tue, May 7 2002
    • Posts 551
    Ive just noticed a slight difference in gear changes on my car too (only 6 months old). I accidentaly managed to grind the gears between first and second the other day - and after that there now seems to be a slight pause when shifting between 1st and 2nd.
    When shifting it sort of pauses in neutral for a split second before dropping into second. The same effect can be felt throughout the gears. Think I could have done any damage when the gears were ground?
    It has started geting very cold round here recently though (-2 to 3) every day - and the gears seem to work better when the cars warmed up - which takes some time on the diesel! Plus at 4k, the engine isnt really all that well worn in yet i think.
    Anyones opinion???
    Clicky's = Guides..
    [De-Lock][Beetle Turbo Knob][Foxy Footwell Lighting][Shades Holders][Short Antenna][Fabia Wiper]
  • Sat, Dec 21 2002 5:18 PM Clutch/Gearbox!!
    hmi1750
    • Joined on Wed, Apr 17 2002
    • Posts 773
    i had the problem in my mk3, and this bora has a very slow gear change, try to rush it like (dare i say it) in the HOnda and just grinds or wont go in... and yes i do depress the clutch fully...
    BMW E90 330d MSport
    Sold:Mazda 6 MPS
    Sold: Bora 150 TDI
  • Sat, Dec 21 2002 5:19 PM Clutch/Gearbox!!
    hmi1750
    • Posts 773
    oh, also, how do ii check the oil in the gearbox? as the car has a long way till service and only done 2k, dont want any further probs.
    BMW E90 330d MSport
    Sold:Mazda 6 MPS
    Sold: Bora 150 TDI
  • Mon, Dec 23 2002 7:22 AM Clutch/Gearbox!!
    westy
    • Joined on Thu, Jun 20 2002
    • Posts 9
    I had this too.
    I got the stealer to adjust the cables, I put redline MTL in the box, and changed the rear engine (dogbone) mount bushings to the poly ones.
    Still does it, but not as bad.
    You still have to pause from 1st to 2nd when its cold.
    Once warmed up its fine.
    Its really bad if you're turning right at the same time as changing 1st to 2nd though when cold.
    Mind you, its not as bad as the tractor gearbox in my wifes Maverick........
  • Thu, Jan 2 2003 1:28 AM Clutch/Gearbox!!
    AndyPandy
    Thanks for all the input, how can I check the gearbox oil level?
    If it's low, where do I fill it up?!?!
  • Thu, Jan 2 2003 6:50 AM Clutch/Gearbox!!
    dwa58
    Golf V GT TDI 2.0 140PS DSG
    • Joined on Thu, Nov 7 2002
    • Location: Australia, previously England, originally Scotland
    • Posts 6
    I have a 99 1.8T and had a problem with 2nd gear when it was quite new.
    Took it to the stealers and twice they said they had adjusted it.
    They had it the 3rd time, and had it overnight during a cold spell so that they could see what I meant and they eventually agreed that there was an issue and replaced the gearbox oil (under warranty) with Fully Synthetic oil and I haven't had a problem since...now done 49K and still okay!!!
  • Thu, Jan 2 2003 7:42 AM Clutch/Gearbox!!
    Gti Jazz Blue
    • Joined on Wed, Apr 24 2002
    • Posts 2,324
    I had problems with my 1-2nd shift (99 1.8T GTi) and my dealer changed the whole box under warranty.
    The new box still does it but not as bad as the original one. Notice it especially when the gearbox is cold (i.e worse in the winter) but gets easier as the gearbox oil warms up.
    2005 Audi A3 2.0TDi DSG S-Line.
    Previous Cars
    99 Jazz Blue GTI. Revo coded AGU with K03sport. Too much else here to list.
    Metalic Black 92 Mark 2 16V 5 door
  • Thu, Jan 2 2003 10:09 AM Clutch/Gearbox!!
    Ricardo
    • Joined on Mon, Aug 5 2002
    • Posts 701
    Anyones opinion???
    As mine was probably v close to yours on the assembly line (ex Bentleys) I havent any problems like this, however, have gratted ? them a couple o times recently, think its down to the cold, but only on a downshift[:I][:I], and no subsequent problem.
    Also mines at 21K and nothing helps the engine (heater) work more quicklySad [:(]Sad [:(] except use!
    I used to have a problem like this on my megane, helped by the garage putting some better oil in (dont remember what) which helped on cold days but not hugely.
  • Sun, Feb 2 2003 7:41 AM Clutch/Gearbox!!
    TDi Si
    • Joined on Tue, Sep 17 2002
    • Posts 15
    I'm still having this problem! My dealer won't do anything more than adjust the cables which they have aleady done. Just have to take it slow, which is annoying when you have to cane it out of a slip road on the motorway! Is it anything to do with the hydraulic clutch? It is slow into 1st gear as well which makes me think that the pressure is too low.
    I will take it back to the dealer when I can get some time off work.
    Simon
    Mk5 1.9 SE TDi
  • Sun, Feb 2 2003 11:05 AM Clutch/Gearbox!!
    Ridders
    • Joined on Fri, Aug 2 2002
    • Posts 17
    Mines also a 99T and I have no probs with 1st to 2nd, however fast.
    Hideous graunches when selecting reverse Fast sometimes.... (and yes I am stationary!)
