Exeter based supplier of a range of unique VAG tuning parts
uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » HOW TOO, black head liner
Last post Sun, Nov 18 2007 8:48 AM by old_n07. 19 replies.
Page 1 of 1 (20 items)
  • Fri, May 4 2007 5:46 PM HOW TOO, black head liner
    Dent Reform
    Golf IV V6 2motion 3.2 24v BHE supercharged
    • Joined on Tue, Feb 28 2006
    • Posts 12,162
    Well after talking about it for rather a long time i felt the urge to pull my finger out and get it sortedGeeked
    You will have to get your thinking caps on for this one as it is more a pain in the ass to do rather than hard
    Well here are the total amount of tools you will need to be able to remove the interior trim and the head liner
    From left to right:-
    Nail scissors, Philips screw driver, pliers, Ratchet 1/4 extension, 10mm socket, 17mm socket.
    The scissors are a prefernce for me to remove the small screw caps that hold the sun visors in place as it does not cause any damage to the plastic cap´s.
    ok it will be easier to show this in steps but this is so easy to remove and takes me about 15min to get the head liner out as i used to do this for a living lol
    normaly if you take your time it should take about 30-45min to complete.
    You can chose where to start as it is not really important if you ask meHuh?
    Remove the seat belt anchors on the B and C pillars
    Remove the interior front light plastic cover and you will find 2 Phillips screws and with a light pull it will come out.
    The RED marked areas  are where you will find more Philips screws that you will need to remove.
    Take care when removing the plastic cap from around the sun visor hook that you don´t snap it off SO DON`T pry off the hook part
    Use a verry small flat head screw driver and slide it between the hook and the cover from the front and leaver it towards the windscreen and it will come off BUT TAKE CARE.
    To remove the A pillar trim´s all you have to do it get your fingers in the top by the roof liner and pull as it is only cliped in place and should be quite easy to shift
    the same goes for the B pillar covers apart from that you need to slide them up to remove them from the bottom half of the trim.
    You should be left with this
    As for the rear C pillar covers you will need the 10mm socket and extension to remove 2 metal nuts on either side behind the carpet.
    Removing the sun visors by prying the small plastic covers from the anchor on the far left and right
    marked in red
    You will also have to pull the door rubbers down enough to free them from the head liner  as this holds it in place rather firmly
    Once you can see no other parts are holding the head liner in place just keep giving it a push and a shove till it comes free  BUT be careful not to damage it in any way as they cost a small fortune Angry
    if you recline your front seats it will make it better and then you can see the wiring loom that is attached to the underside  of the head liner and if you follow the cables down to the LEFT hand A pillar right in the corner by the dash board you will see 2 black plugs that you will need to undo to detach the roof loom from the rest of the car.
    The head liner should slide out the boot with ease but try and have someone to lend a hand because if the car has a sun roof then the head liner is quid flimsy on the edges.
    NOW FOR THE pain in the ass bit Confused
    Covering the roof is something you need to do as it is just preference how you want to do it but make sure you get a material that will stretch or life will be hell for you along the way due to all the curves and sharp corners like where the grab handle recesses are.
    Take your time and only spray the glue about 6 inches at a time starting from the rear of the head liner and take care not to get glue on the outer surface as it is a right mare to get off
    Once you have the head liner covered you can then cut around the edges, but make sure to leave enough to be able to fold around and stick on the underside, about an inch is enough.
    I chose to paint all the grey plastics with plastic BLACK SATIN paint
    I will be replacing all of this along the way for the OEM black plastics just to get the desired finish but i must say it does look good Big Smile
    The glue is used cost about 3-4 quid a tin and have used about 1 and a half tins of glue to do the job.
    Replace the head liner once finished in the reverse and just make sure all the bits and joins have a nice snug fit and you will not go far wrong
    I will put up some pics of the finished car tomorrow as it was dark when i had  finished
    I will use the same back paint to coat the door rubbers to hide the still grey bits so it all blends in .
    HAVE FUN and don´t make a mess like i did lol
    Andy
    The Elite 24v VR6 Club: Member #424 charged as well
  • Fri, May 4 2007 6:01 PM Re: HOW TOO, black head liner
    davemk Moderator
    • Joined on Thu, Jul 15 2004
    • Posts 6,441
  • Fri, May 4 2007 6:05 PM Re: HOW TOO, black head liner
    • Posts 8,162
    Looks good Andy Yes
    Looking forward to seeing the finished article, don't think I'd have the balls to try that myself though Tongue TiedSmile
  • Fri, May 4 2007 6:06 PM Re: HOW TOO, black head liner
    flygti2004
    • Joined on Mon, Feb 26 2007
    • Posts 871
    not a great idea of a fun stress free afternoon huh?? hahahahhaaha
    American in the UK ;)
    North American Spec GTI
    Silverstone Grey
    AWP - 1.8T
    afew mods.........
  • Fri, May 4 2007 6:10 PM Re: HOW TOO, black head liner
    Dent Reform
    • Posts 12,162
    It was not bad to be honest just a bit tedious towards the end lol
    Plenty of coffee, fags and swearing Stick out tongue
    Stress free my ass Big Smile
    AND you can see hoe minging my head liner was  Embarrassed
  • Fri, May 4 2007 6:32 PM Re: HOW TOO, black head liner
    flygti2004
    • Posts 871
    ya when i get back to the states im just going to shell out the $$$ to get it done professionally. i dont even want to fix my mess ups. it was to much of a headache.
    Silverstone Grey
    AWP - 1.8T
    afew mods.........
  • Fri, May 4 2007 6:58 PM Re: HOW TOO, black head liner
    T10HJS
    • Joined on Tue, May 30 2006
    • Posts 2,695
    very nice write up think i will have to give this a go in the near future
    BucksVAG.net  For All VAG Enthusiasts in Buckinghamshire.
    Build Up Thread Of My 1.8T (be warned its a long read)
    http://uk-mkivs.net/forums/t/136881.aspx?PageIndex=1
  • Sat, May 5 2007 1:19 AM Re: HOW TOO, black head liner
    aRd
    Golf IV SDI 1.9 AQM 68PS
    • Joined on Sat, Aug 17 2002
    • Posts 2,881
    Looks good Andy
    Looking forward to seeing the finished article, well done !
    Need some help with Vagcom check, Keys/Immobilser adaption, cluster swapping, Miles till Empty/Illuminated Needles, Autowindows, ECU swapping//coding etc... PM me :) Pics of the aRd automobile http://uk-mkivs.net/forums/p/239924/1548484.aspx#1548484
  • Sat, May 5 2007 4:33 AM Re: HOW TOO, black head liner
    junglisteve
    • Joined on Tue, Jan 10 2006
    • Posts 6,333
    will look cool... i just dont think i could deal with the  hassle of doing it !... Big Smile
    nice stuff so far... black interior is awesome.... carry on...
    back in May 2010
  • Sat, May 5 2007 4:45 AM Re: HOW TOO, black head liner
    Dent Reform
    • Posts 12,162
    i am going to leave the seat belt covers and lights grey just to break it up a bit Huh?
    The car feels so small from inside now but looks the mutt´s nuts  Devil
    I will put some more pics up later when i am down at the beach
  • Sat, May 5 2007 4:51 AM Re: HOW TOO, black head liner
    junglisteve
    • Posts 6,333
    Big Smile
    back in May 2010
  • Sat, May 5 2007 7:08 AM Re: HOW TOO, black head liner
    flygti2004
    • Posts 871
    junglisteve:
    ya its a pain in the ass.
    Silverstone Grey
    AWP - 1.8T
    afew mods.........
  • Wed, May 9 2007 5:08 AM Re: HOW TOO, black head liner
    Ste2
    • Joined on Fri, Sep 29 2006
    • Posts 1,933
    looks good andy, out of interest where did you get the material from, and how much?
    Regards
    "Anyway what's a master degree engine designer doing driving a 200bhp tdi? Isn't that the equivalent of Gordon Ramsey living on a diet of Pot Noodles?" - Eyeamsparticus - uk-mkivs, July 14th 2008... Quality Quote!!
    Ste2: My Secondary Air Pump makes more power than a 1.4 Stick out tongue
  • Wed, May 9 2007 12:59 PM Re: HOW TOO, black head liner
    Dent Reform
    • Posts 12,162
    I got it from a local shop and it cost me 20 quid, YES 20 QUID!!!! for the l;ot including the glue to do it all
  • Fri, Nov 16 2007 3:25 PM Re: HOW TOO, black head liner
    type-rich
    • Joined on Fri, Sep 21 2007
    • Posts 8
    Firstly excellent write up.
     What material did you use, i was thinking alcantara. But for that price??
    Mite be doing this myself next week
    Rich
  • Sat, Nov 17 2007 2:29 AM Re: HOW TOO, black head liner
    T10HJS
    • Posts 2,695
    i forgot all about this post, in the end i decided to remove the a/b/c pillars and the headliner/sunvisers/grab handels and i bought 8cans of foliotech interior vinal spray and sprayed the lot. i got a really good finish all the plastic looks like the genuine parts was rather chuffed with my efforts i will get some pics up soon
  • Sun, Nov 18 2007 7:15 AM Re: HOW TOO, black head liner
    Dent Reform
    • Posts 12,162
    type-rich:
    Rich
    Well it was not so clear cut after about 2-3 weeks the glue started to losen and the roof liner saged like dumbo's ass LOL
    if you use spray glue make sure you get a glue that is a higher temp than the MAX 50 degree i used at first then later re did the lot with MAX 80 degree and has been fine ever since LOL
    the only shock i got was how small the car felt inside after doing it and due to the fact that this is a motorway munching tool carier rather than a show car it has held up very well and still looks like new Stick out tongue
    I still have the A B and C posts to do when i ever find the time or energy and thoughts are into changing the engine again for something with a little more grunt like the 3.6L V6 from the passat  then stage 2 HGP slaped on for the sake of it Geeked so should be good for munching the miles a bit quicker he he he
    i got the fabric from a local shop and she said lots of chavs use it for covering spearker boxes and the likes so i thought PERFECT and at 20 quid for 6 square meteres you cant go wrong and the added bonus that the amount of wind and road noise is reduced even more Stick out tongue
    Andy
  • Sun, Nov 18 2007 7:31 AM Re: HOW TOO, black head liner
    • Posts 8,162
    Dent Reform:
    Is that the one I PM'd you about Andy ?
    Niel
  • Sun, Nov 18 2007 7:43 AM Re: HOW TOO, black head liner
    Dent Reform
    • Posts 12,162
    HE HE
    Yup but he does not want t6o sell the engine and trans on it's own Angry and i dont want all that 4 MOTION grief LOL
    Looking at HGP with the stage 2 kit it should take the car to a V-MAX of 280KMH but i think with some transmision mods i can get her to do 300KMH or about 180MPH and this will ALSO be a first in the UK with a MK4 golf with the 3.6 engine and FWD not to mention what i have already done so far
  • Sun, Nov 18 2007 8:48 AM Re: HOW TOO, black head liner
    • Posts 8,162
    LOL, you still owe me that ride in your car as well Smile
    I can't wait to see how you shoe horn that under the bonnet, it is going to be quite a project.
