uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Cruise Control 1.8T Additional Loom
Last post Fri, Jun 22 2007 6:03 PM by Immortal. 0 replies.
Page 1 of 1 (1 items)
  • Fri, Jun 22 2007 6:03 PM Cruise Control 1.8T Additional Loom
    Immortal
    • Joined on Sun, Apr 22 2007
    • Posts 25
    You can now get the additional loom required to fit cruise control to a 1.8t (and other models) as a genuine VW spare.
     For engines with the 80-pole ECU plug (Engine codes: APE, AXP & BCA)
    1J0.971.425.B
    For engines with the 121-pole ECU plug (Engine Codes: ARZ, ATN, AUM, AUQ, AUS, AZD, AZH, AZJ, BAD, BCB, BFQ)
    1J0.971.425.C
    The wiring goes as follows:
    Engine Code: APE, AXP & BCA (80-pole plug)
    Pin 24: Black/White Wire
    Pin 25: Red/Yellow Wire
    Pin 39: Blue/Grey Wire
    Pin 50: White Wire
    Engine Code: BAD (121-pole plug)
    Pin 49: Blue/Grey
    Pin 51: Red/Yellow
    Pin 52: White
    Pin 55: Black/White
    Engine Code: BFQ (121-pole plug)
    Pin 66: Red/Yellow
    Pin 67: Blue/Grey
    Pin 68: White
    Pin 69: Black/White
    Engine Code: ARZ, ATN, AUM, AUQ, AUS, AZD, AZH, AZJ & BCB (121-pole plug)
    Pin 38: Black/White
    Pin 57: Red/Yellow
    Pin 75: Blue/Grey
    Pin 76: White
    Hope this helps
