uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - Engine and Exhaust » LAG on 150 pd
LAG on 150 pd
Last post 21/07/2008 9:19 AM by mark1000. 9 replies.
  • 29/08/2007 11:27 AM LAG on 150 pd
    jason5coe
    Bora Sport 1.9 ASZ 130PS
    • Joined on 15/04/2007
    • Posts 81
    hopefully some one could guide me right with thias one or agree that i have already answered it
    the turbo on the pd 150 is larger than the turbo on the pd 130 is it the turbo that causes the little bit of extra lag the pd 150 has or as i suspect the VERY MUCH LARGER front mounted intercooler pd 150 as a possed to the smaller side mounted pd 130
    answer would be nice so i can worranrt going bigger turbo
  • 29/08/2007 12:21 PM Re: LAG on 150 pd
    NCR1
    • Joined on 20/07/2005
    • Posts 226
    Turbo is bigger as far as I know...........
     Can't see the intercooler making any difference to lag but may be wrong.
  • 29/08/2007 2:43 PM Re: LAG on 150 pd
    jason5coe
    • Posts 81
    i looked at it this way the bigger the intercooler the more air that is needed to fill it the more air the more time the turbo would take to get to a point it is actual causing a pressure to the head
    agree or disagree
    i am open to being victomised or put down a peg or two if my therpy is not sound
    but as i said i need to know cause i didnt want to waste money doing the modes just to loose drive ability IE gain LAG
  • 29/08/2007 2:58 PM Re: LAG on 150 pd
    fenwick458
    • Joined on 05/05/2007
    • Posts 2,274
    bigger intercoolers and bigger turbos create more lag.
    it takes longer for the turbo to pressurise the air in the charge side(from turbo, through intercooler into inlet manifold)
    the PD115 does not have alot of lag, partly down to the small turbo, and very small intercooler pipework.
  • 29/08/2007 3:18 PM Re: LAG on 150 pd
    Bora Tee Dee Eye
    • Joined on 19/10/2006
    • Posts 1,743
    You will also find the length of the the pipework to the FMIC is a lot longer on the 150, this will also increase the lag
    John
  • 29/08/2007 3:47 PM Re: LAG on 150 pd
    jason5coe
    • Posts 81
    the next part of the question or answer is that would there be more LAG  how ever much more it is if i use the bigger turbo as it would take longer to spool up?
  • 29/08/2007 4:18 PM Re: LAG on 150 pd
    fenwick458
    • Posts 2,274
    yes
  • 30/08/2007 3:59 PM Re: LAG on 150 pd
    jason5coe
    • Posts 81
    NOW for my next question
    How much MAX boost from pd 130 turbo and pd 150 turbo?
    also MAX power/ torque from both?
  • 21/07/2008 9:12 AM Re: LAG on 150 pd
    mark1000
    • Joined on 21/07/2008
     HELP
  • 21/07/2008 9:19 AM Re: LAG on 150 pd
    mark1000
     HELP i have a 03 golf gti 150 pd the turbo stopped comming in so i got the car checked air flow meter ect this was diagnosed as lever in the variable vain torbo sticking 1 new turbo later the boost is now not comming in until about 1800 rev istead of the usual 1200 any ideas
