Stoke based VAG specialists - Custom Code dealers
uk-mkivs » Technical Community » FAQ Forum » Speedo \ Instrument Cluster
Last post Wed, Mar 17 2010 4:23 AM by old_n07. 204 replies.
Page 1 of 6 (205 items) 1 2 3 4 5 Next > ... Last »
  • Thu, Dec 6 2007 2:34 AM Speedo \ Instrument Cluster
    • Posts 8,162
    There are three styles of cluster fitted to the MK4 Golf and Bora range, the two main ones being the standard none sport cluster:
    And the Bora Sport style of cluster which is also fitted as standard into the Golf 25th Anniversary edition:
    The third type is the cluster as fitted into the R32:
    In the centre of the cluster is the driver information display but on the more basic models this did not include the multifunction computer.
     The computer display is available in two versions, the more common MFA:
     MFA stands for Multifunction Anzeige, or Multi-Function Indicator. The MFA cluster has an LCD screen backlit by red LEDs. It takes up the bottom half of the box in the middle of the cluster, and the top half has the warning lights
    And the FIS version which normally came in vehicles with satellite navigation fitted from the factory or in conjuncion with the multi function steering wheel:
    FIS stands for Fahrerinformationsystem, or Driver Information System. The FIS cluster has an LCD screen backlit by red LEDs in the middle of the cluster, which takes up the whole rectangular area where most VWs have the warning lights.
    Both FIS and half MFA came in standard and Bora Sport style clocks.
     Manufacturer
    The clusters were manufactured by two companies VDO who made Bora Sport style gauges as well as standard and Bosch Motometer who just made the standard gauges.
     Immobiliser (Immo)
    There are two versions on the MK4 paltform these being Immo 2 and Immo 3, earlier models came as Immobiliser 2 and in early 2001 VW introduced Immobiliser 3 with the vehicle immobiliser being integrated into the cluster.
    You can tell which version you have from the part number of your cluster by the last numerical digit, 5 being immo 2 and 6 being immo 3.
    EG: 1J0 920 926 C - immo 3 cluster / 1J0 920 925 C - immo 2 cluster (anything except a 6 is immo 2 Wink)
    Also as a general rule, on immo2 cars the immobiliser symbol is in the rev counter and on immo3 cars it is in the speedo.
     I Want to swap my cluster, can I do it?
    The general answer is yes, but there is always a condition:
    ·         You can put an immo 3 cluster into an immo 2 car (upgrade) but not an immo 2 cluster into an immo 3 car (downgrade)
    ·      If yor car is can bus based (920) then the swap to immo 3 clocks will enable miles to empty to work and the mpg functions will work, but if the car was none can then the functions will not work
    ·         If you put an immo 3 cluster into an older immo 2 car that was none can bus communication you will get an air bag light on, this can be coded out with Vag-com and the bags will still work.
     Can Miles to empty be enabled on my cluster?
    Yes it can if you have an immobiliser 3 cluster made by VDO or the RB8 cluster by Bosch with half or full FIS dislpay, but immobiliser 2 clusters can not have this function regardless of manufacturer.
     Can illuminated needles be enabled on my cluster?
    Yes it can if you have an immobiliser 3 cluster made by VDO but it can’t be enabled on the clusters made by Bosch Motometer or immobiliser 2 clusters
    Can illuminated needles and miles to empty be enabled with Vag-Com?
    No, Vag-Com can not be used to enable these functions.
    My car doesn't have a multi function display, can I fit a set of clock with the display?
    Yes you can but you will need a new wiper stalk (4B0 953 503 H) with the computer controls on it and then it will need wiring into the green multi plug connector on the rear of the rear of the clocks. Also if you currently don't have the outside temperature probe that is located in the bumper you will need to install one and wire it back to the green connector (pin 26) for the cluster to display the outside temperature.
    My car only has the half height display, will a set of clocks with the full height display work?
    Yes the clocks will work. They will display the radio station only if you have the VW head unit installed with the extra wiring loom to the clocks from the radio, also they display navigation directions when used with the VW navigation system and the extra wiring loom.
    Where can I find the part number of my clocks?
    There are two ways to do this:
    1.       Take the dash cluster out following this guide and look at the sticker on the rear of the cluster
    2.       Connect up VAGCom and open channel 17 (instruments), you will get this screen with the part number and manufacturer details displayed. In the below example RB8 signifying a Bosch \ Motometer cluster if the cluster was VDO then VDO would be in the manufacturers field.
    What part numbers do I need for:
    Bora sport style immo 3 Cluster:
    Half Fis
    1J5 920 926 C – Diesel
    1J5 920 926 A – Petrol
     Full FIS
    1J5 920 946 C – Diesel
    1J5 920 946 A – Petrol
     R32 sport style immo 3 Cluster:
    1J0 920 926 JX - Half FIS
    1J0 920 946 FX - Full FIS
    How do I code in my new clocks:
    Follow these instructions from Ross Tech, you will need VAGCom and your SKC , also  see this post for the cluster soft codingsYes
     How do I get my SKC (Secret Key Code)
    The dealers can’t provide the SKC as they no longer have access to it.
    If you have an earlier golf that came with the plastic tag on the spare keys the SKC may be printed on there.
    The SKC can be retrieved with third part pieces of software such as Vag tacho.
    If there are any additions or corrections then please PM me.
  • Thu, Oct 2 2008 4:52 PM Re: Speedo \ Instrument Cluster
    East Ender in 1.8T
    • Joined on Sun, Oct 1 2006
    • Posts 770
    someone got a steal here LOL
    good on ya.....  i picked my R32 clocks for 50squids....  you get good finds from time to time depending on how persistant you are with your search
    Veesh
    STOLEN 12/09/2009 RIP.......
    GOLF GTI 1.8T | Full R32 Kit | Full R32 Milltek | R32 Front Brake Conversion | R32 leathers l R32 clocks | 18"BBS LMs | on proxy T1Rs | Custom Headlamps | HID Kit 6000k | Blk US Spec Rear Lamps | Coilies | H&R arbs | Privacy Glass | Forge DV | REVO Stage 2 - Flushed boot - Flushed front bumper - Bad Boy Bonnet extention
  • Thu, Oct 2 2008 6:24 PM Re: Speedo \ Instrument Cluster
    JonJon
    • Joined on Sat, Jan 29 2005
    • Posts 664
     clocks for dummies, can't believe i havn't seen this till now. fantastic
  • Fri, Oct 24 2008 5:06 PM Re: Speedo \ Instrument Cluster
    Joe90k
    • Joined on Mon, Jun 4 2007
    • Posts 1,361
    This is a great guide but I have one thing to add which may help others out, I hope you dont mind neil.
    A quick way to tell which Immo you have is:
    If you cluster is Immo2 then the Immobiliser light will be in the rev counter, if the cluster has the immobiliser light in the speedo then it is Immo3.
    (Credit to Kalu for that)
    There are also 4 warning symbols above the MFD on Immo3 clusters and only 2 on the Immo2's.
    Hope this helps.
    Joe
    Xenons | Auto Lights/Wipers | Sunroof | Premium Bose | Ambient Lighting | Cruise Control | Matte Black RS6's | S3 DSG Shifter | TPMS | 09 LED Rear Lights | MFSW | S-Line Matte Black Front
    In Progress: Heated Seats | LED Sidelights | LED Numberplate Lights | Main Beam Upgrade
    To Do: Lamin-X | OEM Bluetooth | Puddle/Door Handle Lights | Millltek Turbo-Back
    DC Audio Lvl 4 12" | DLS CAD 11
    Golf Mk4 GT TDi 115PS Gone but never Forgotten!
  • Sat, Oct 25 2008 10:53 AM Re: Speedo \ Instrument Cluster
    T_C
    Bora Sport 1.9 AHF 110PS
    • Joined on Sat, Sep 13 2008
    • Posts 156
     my clocks have the immo in the rev counter but all my mfa readings are displayed in the lcd panel in the rev counter like the old mk3. the centre part only has warning lights n no display panel :(. would of thought a GTI would have the higher spec clocks.
     can i upgrade to the immo2 clocks with out any hassel?
    86 golf gti 1.8 cab - tsw's, d&g disc's, spax adjustables.
    94 golf gti 2.0 16v - too many too list...
    99 golf gti 1.8t - miltek cat back....
    00 bora TDi - .216 injectors on the kitchen side :)
  • Mon, Nov 3 2008 8:05 PM Re: Speedo \ Instrument Cluster
    luigidelgado
    • Joined on Tue, Nov 4 2008
    • Posts 3
    Excelent...
    I have a problem. I have a broken MOTOMETER (1J0920805J) and im swapping with a new one (1J0920805BX) immo 2, 2001 golf...
    I have ONLY both instrument clusters but not the car,, not the key, not the PIN (Im not even sure if the PIN is needed) the car is 2,000 kms from here. I have to send only the new cluster ready to be installed. I can ask for the key if needed.
    What would be the best solution here? Is it possible to open the new cluster and swap (solder) the old clusters EEPROM?
    Can the VAG TACHO read the PIN from this Bosch cluster? I read it can be done so how can I make the swap??
    HELPPP!!!! thank you.
  • Tue, Nov 4 2008 1:26 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
    Welcome to the forum Yes
    What version of Vagtacho do you have as the later versions (2.x) can read the SKC from Bosch clusters but it takes ages (hour plus sometimes). You only need the SKC of the new cluster to do the swap.
  • Tue, Nov 4 2008 1:53 AM Re: Speedo \ Instrument Cluster
    luigidelgado
    • Posts 3
    old_n07:
    Oh old_n07 thanks for your answer! I have 2.2 and 2.5... As for the SKC, its ok I will only check for the new one but I still need the CAN code from the old one isnt it? And to have that I shoud connect it to a VAg-COM, am I right? Thanks for your help.
  • Tue, Nov 4 2008 2:01 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
     Yes, just connect vagcom and note the value in the soft coding field but you will also need the instrument soft coding from the old cluster ideally, if you can't get it then vagcom tells you how to work it out.
  • Tue, Nov 18 2008 4:43 PM Re: Speedo \ Instrument Cluster
    luigidelgado
    • Posts 3
    old_n07:
    OK thank you guys! Thought the problem was worse than you describe it. I dont have the old cluster (nor the soft code) and the dealer couldnt code the new one (I dont have the SKC, the instrument cluster didnt came with one, and they say they couldt get it with the GEKO). But I will try what you say first getting SKC from the VAGTACHO (this is an immo 2 cluster) and then "making" a soft code with the VAG-COM (VCDS), am I correct? Confused
  • Thu, Nov 20 2008 10:33 AM Re: Speedo \ Instrument Cluster
    Jammy B
    • Joined on Sun, Feb 12 2006
    • Posts 3,045
     great thread. mine are IMMMO3 from reading this!
    how come on the 7th pic down, one showing the label, that the part number ends in 826C rather than 926C?????
    jammy
  • Thu, Nov 20 2008 10:50 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
    Jammy B:
    jammy
    The label is off a cluster that is calibrated in KPH Jammy Wink
    8 - signifies KPH
    9 - signifies MPH
  • Thu, Nov 20 2008 10:57 AM Re: Speedo \ Instrument Cluster
    chris_v6_4motion
    • Joined on Tue, Nov 27 2007
    • Posts 1,680
    Jammy B:
    jammy
    Not much gets past you mate! Wink
    Jammy Holmes, I presume! Chuckle
    Chris
  • Tue, Dec 9 2008 6:59 AM Re: Speedo \ Instrument Cluster
    geezer_3000
    Golf IV Final Edition 1.6 16v AUS 105PS
    • Joined on Fri, Oct 31 2008
    • Posts 140
    Hi all. Im a newbie...  I just wanted to know if i can swap my (1.6) clusters foR the bora sport ones and what parts are needed. i did read the above but im still lost... (I must be a bit of a Dummy!!)
    cheers.
    WANTED: BORA SPORT INSTRUMENT CLUSTERS 1J5 920 926 A.
  • Tue, Dec 9 2008 7:05 AM Re: Speedo \ Instrument Cluster
    matt_mkiv
    • Joined on Thu, Feb 7 2008
    • Posts 4,046
     firstly they can all be changed....updated, but not down graded....
    any idea which yours are, immo type?? style??
    then is it CAN based....take the code from the back of the clocks 919/920??
    then find some one really nice and friendly...like Neil(old_no7) or Ray(aRd)....to held you recode them.....
    they you may need new stalkes and a temp sensor?? (part numbers above)
    matt_mkiv
    • Posts 4,046
     and welcome to the forum!!!
  • Tue, Dec 9 2008 7:06 AM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
     Ah! now I HAVE read the above tut tut.....
  • Tue, Dec 9 2008 7:13 AM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
     Cheers matt.  They look like these: http://i65.photobucket.com/albums/h208/old_n07/FAQS/Cluster/basic.jpg (unsure if this the way to do it.
  • Tue, Dec 9 2008 7:16 AM Re: Speedo \ Instrument Cluster
    matt_mkiv
    • Posts 4,046
     same as mine, im having mine upgraded to bora spot ones on friday....Party!!!
    need the part number to know if they are CAN based.....will allow more features enabled if they are....
    there is also a tread on old_no7s FAQ to show you how to post up pics ect.....Yes
  • Sat, Dec 13 2008 3:21 AM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
    Nice. Been a bit busy and all but when I get the time I will get the clusters out and check code.
  • Mon, Dec 22 2008 3:31 AM Re: Speedo \ Instrument Cluster
    fenwick458
    • Joined on Sat, May 5 2007
    • Posts 4,482
  • Mon, Dec 22 2008 3:39 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
     Immo 3 none FIS Bora sport style clocks, most likely US in origin and very over priced.
  • Mon, Dec 22 2008 3:52 PM Re: Speedo \ Instrument Cluster
    Jammy B
    • Posts 3,045
    old_n07:
    that seller has got a load of foreign ones on eBay!
    jammy
  • Mon, Dec 22 2008 4:30 PM Re: Speedo \ Instrument Cluster
    Chrisdut
    • Joined on Sat, Sep 27 2008
    • Posts 1,617
    fenwick458:
    what are these clocks?
    1J5 920 906 GX
    heres a link to the ebay auction
    by the look of that part number they are an exchange part too with the X at the end
    52 Plate TDI Silver Anniversary
    Anni Build Thread
    ___________________________
    VW Maindealer Master Technician.
  • Mon, Dec 22 2008 4:46 PM Re: Speedo \ Instrument Cluster
    suj
    • Joined on Wed, Jun 21 2006
    • Posts 781
    Forget that US sport poverty cluster, £150 for foils basically.
    Retrofit := Armrest, Cupholder, MFA with lit-needles and MTE, MFA Stalk, Auto lock/unlock, Spare key, OEM style remote locking inc. flip and startable key
    To do := Install OAT sensor, Chrome rings
    Coming soon := New cluster needles
  • Mon, Dec 22 2008 5:20 PM Re: Speedo \ Instrument Cluster
    hjkl456
    • Joined on Fri, Dec 19 2008
    • Posts 9
     hi
    how do you know if your car is can bus based, slightly confused
    thanks
  • Tue, Dec 23 2008 12:26 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
    hjkl456:
     hi
    thanks
    1JX 920 XX6 - CAN Immo 3
    1JX 920 XX5 - CAN Immo 2
    1JX 919 XXX - Not CAN
  • Sat, Jan 3 2009 5:54 PM Re: Speedo \ Instrument Cluster
    snurre
    • Joined on Sat, Jan 3 2009
    Hi.
    Just wondering... Is is possible to change EVERY cluster to a immo2 or immo3?
    I have a non-can cluster number 1J0 919 880 B.
    A print from vag-com looks like this:
    Address 17: Instruments
       Controller: 1J0 919 880 B
       Component: KOMBI+WEGFAHRS. MM0 V11
       Coding: 04142
       Shop #: WSC 00000
       Ident.-Nr. WEGFAHRS.:VWZ6Z0W0339909
    It would be cool to get that display in the middle, and maybe justify the lightning on the gauges and needles.
    I have that old one without any display in the middle at all. Just the 5-6 functions in the left little display together with the clock.
    Is it possible to change, and what do I actually need?
    Thanks!
  • Fri, Jan 9 2009 8:38 AM Re: Speedo \ Instrument Cluster
    Lasse
    • Joined on Tue, Dec 23 2008
    • Posts 16
     I'm one of the unlucky ones that has a non CAN-bus car, and I still would like to install a instrument cluster with MFA or FIS and everything.
    I came across the following: http://www.tixxon.de/CAN-BUS-Interface-fuer-Nachruestung-VW-Audi-Tacho
    Has anyone tried that?
  • Tue, Jan 13 2009 12:09 PM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
    Alright all. I want to fit bora sport clusters to my mk4 golf but don't have the tools to remove the steering wheel. My mate does but he lives in surrey. So I was thinking that  I could use one of your vagcoms / tachs? to see if my car is immo2 CAN based. If it is then I would go in search of the clusters (1J5 920 926 A) by VDO, wiper stalk (4B0953503H) with computer controls on it and an outside tempreture sensor probe with bracket. (if if the car is non can based then how would I go about this? all suggestions welcome)
    Once I have all the parts , Maybe one of you will be able to help me fit it all up I can pay you cash / beer tokens or both.
    Cheers, Thanks for reading ,
  • Tue, Jan 13 2009 12:12 PM Re: Speedo \ Instrument Cluster
    • Posts 8,162
     What year is you car?
    Do you know if the immobiliser symbol is in the rev counter or speedo?
  • Tue, Jan 13 2009 7:28 PM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
    Neil my car is a 2001(Y) plate model. The immobiliser symbol is in the rev counter. At least I know the car is Immo2. Yes
    I just need to check if its CAN based.
  • Wed, Jan 14 2009 1:27 AM Re: Speedo \ Instrument Cluster
    • Posts 8,162
  • Wed, Jan 14 2009 3:52 AM Re: Speedo \ Instrument Cluster
    moosebumps
    • Joined on Mon, Jan 12 2009
    • Posts 20
     hey no 7, i have an 02 plate 1.6s, my immo symbol is in the speedo, but my cluster looks like the one in the last picture, the middle panel has 7 or 8 symbols at the top of it but looks like theres nothing at the bottom, does this mean theres no computer in it? could be a daft question but i know b***ger all about this sorta thing! help!
  • Wed, Jan 14 2009 5:17 AM Re: Speedo \ Instrument Cluster
    geezer_3000
    • Posts 140
     even though mine is the bog standard one with no half fis?
