fenwick458:
I'm currently in the process of upgrading my brakes, and i have been trying to find out as much as possible from this forum, but there does not seem to be a lot of info on it, so i thought it would be a good idea to get all the info in one place.
Heres all the brake sizes on the VAG range, and what they are fitted to as standard.
VW Golf R32 | Audi TT 3.2 Quattro
The Front brakes are 334mm x 32mm Vented 2-piece Discs, Twin piston calipers
The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas singles
Seat Leon Cupra R
The Front brakes are 323mm x 28mm Vented (grooved/drilled option) discs with 4 pot Brembo calipers The rear brakes are 256mm x 22mm Vented , with 38m Lucas single piston calipers
Audi TT-Quattro (225hp) | VW Golf Anni | Skodá Octavia VRS | VW Golf V5 170 | VW Golf V6 4 Motion
The Front brakes are 312mm x 25mm Vented Discs, 54mm ATE single piston calipers
The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas single Piston calipers
Audi TT (180hp)
The Rear brakes are 232mm x 9mm Solid Discs,
Golf 1.8T | Golf 130/150 TDI | Seat Leon 130/150 TDI and 1.8T
The Front brakes are 288mm x 25mm Vented Discs, 54mm ATE single piston calipers
2.0 8v | TDI 115 | TDI 110 | TDI 100 | TDI 90
The Front brakes are 280mm x 22mm Vented Discs, Single piston calipers, caliper carrier integrated into hub
The Rear brakes are 232mm x 9mm Solid discs
Golf 1.4 16V | Golf 1.6 16v | Golf 1.6 8v | SDI
The Front brakes are 256mm x 22mm Vented Discs
BRAKE DISC INFO
Heat capacity
Heat capacity is the amount of energy that can be absorbed by the disc before the temperature gets high enough to cause brake fade. The mass of the disc is proportional to the heat capacity. Therefore, a lighter disc will not allow as much energy to be absorbed as a heavy disc.
Solid vs Vented
Vented discs are hollow with internal vanes. This increases the surface area of the disc and allows air to cool the disc mass more effectively. A 5Kg vented disc will cool much quicker than a 5Kg solid disc. In many cases, a vented disc can weigh less than a solid disc and still provide more effective braking because of the cooling effects alone.
Curved vs straight vanes
The vanes inside vented discs provide structural integrity to the disc itself as well as cooling. There are several different styles of vanes:
Straight vanes are the most common because they are easy to manufacture.
Curved vanes are common in higher performance cars as they promote better cooling better than straight vanes.
Where does the air go?
For solid discs, all the air travels over the surface of the disc - the same surface as the brake pads.
For vented discs, a considerable amount of air flows through the interior. Because it's spinning so fast, it creates a vacuum and air is sucked into the center of the disc and forced out through the edges. The air follows the pattern of the internal vanes.
Drilled discs
A common misconception is that the purpose of drilled discs is to promote cooling. This couldn't be further from the truth, The real purpose is to reduce weight.
Drilling can allow brake dust and gases to escape, but with modern brake pads, this usually isn't a problem. Choosing a drilled disc for that purpose doesn't make a whole lot of sense.
Many high performance cars like Porsche and Mercedes AMG come with drilled discs from the factory. For these cars, the drilling is mainly about the looks, just like bright red calipers. When people do serious high-performance driving on a trackdays, they usually swap to regular plain discs.
Drilled discs generally wear out brake pads faster and produce much more brake dust as a result.
Drilled discs have a shorter service-life than plain discs and tend to develop stress fissures/cracks over their lifetime
Grooved Discs
Grooved Discs are great for shedding water and mud off the rotor surface as in Rally racing or wet-weather racing. For street driving they may make a marginal improvement in initial brake "bite"
Grooved Discs do accelerate pad wear and produce more dust just like drilled discs do. They also add noise and vibration into the system. For many these issues are annoying enough to not choose grooved discs, unless you do alot of rallying!
Two-piece discs
Two piece discs have several advantages including lower weight while maintaining most of the heat capacity and better cooling by having a more open center section
Two piece discs increase costs and generally a poor choice for street cars. For racing, they are great!
Plain discs
Plain rotors are the best choice for 99.9% of applications
Name brand vs non-name discs
Why pay double the money for a Brembo discs vs. GSF cheapo's? You guessed it there is pretty much no benefit. Its all the same stuff, Spend you money on brake pads
Specialist Discs (carbon, carbon-ceramic, carbon-kevlar, etc.)
Some really expensive cars come with an option for fancy brake materials. These brakes are excellent for trackdays since they are relatively lightweight but can withstand extreme temperatures without brake fade. This provides a competitive advantage for racing.
For the street, it doesn't help much at all, and they squeal alot and wear fast.
Warped discs
if your discs are warped its because you have heated them up too much during hard breaking. probably nackered but you might be able to get them skimmed.
BRAIDED BRAKE LINES
Braided Brake hoses
Braided brake lines don't expand or bulge out, therefore reduce pedal travel, and increase the force applied to the brakes.
BRAKE FLUID
If you want to improve your braking power on a budget, try using a Performance brand of Brake fluid and bleed your brakes. it makes alot of differance!
Chances are your fluid now is old and has absorbed some water and air and is not as good as it should be so the pedal will feel spongy. Sort this by bleeding your brakes and use a decent brand of fluid, ATE Super Blue Racing sounds good, and it's blue! how cool is that! anyway, it does make it easier to see when the new fluid has come through, and it has a low viscosity, it resistant to absorbing water, and has a boiling point of 200°C, which means less brake fade.
BRAKE PADS
There's lots of different types of these on the market, EBC, Mintex, Tarox, Pagid, Black Diamond, Brembo to name a few.
They are just made better, and depending on what you go for, they will provide better braking power / low dust etc..
They come in different levels of agressiveness, for example the EBC range is as follows:
EBC Blackstuff - Standard use
EBC Greenstuff - Street
EBC Redstuff - Fast Street
EBC Yellowstuff - Track
EBC Bluestuff - Race
if you go for the "race"option be prepared to get more dust, squealing/vibrations and accellerated pad wear and a harsh feel to the brakes - unsuitable for normal driving so thats why theres a range.
buying performance brake pads will make a difference to your braking power, for not alot extra cash over the standard pads.
BRAKE BIAS
Ever wondered why the front brakes are always bigger? By design most original factory brake systems do not split the brake force 50/50 between the front and rear axles. This is because under braking the front tires offer increased traction as weight is transferred forward. This additional traction can be utilized by increasing the brake force applied to the front axle vs. the rear. The outcome is a bias split that is more in the order of 70 front/30 rear resulting in shorter and more controlled stops.
BIGGER IS NOT ALWAYS BETTER........
Putting bigger brakes on may not always be a good idea.
For chipped/re-mapped cars the obvious upgrade is 312mm fronts because it's so easy, and only requires carriers and discs for most models(not SDI, TDI 90, 100, 110, 115, 2.0 8v, 1.6 8v, 1.6 16v, 1.4 16v,).and because you have increased the power of the engine, the power to wheel will not be de-creased as it would if you just put bigger brakes on.
But, putting the 312mm conversion on a 1.4 for example, along with bigger wheels than standard and you will be adding alot of weight to your wheels, and the engine will be put under more strain, therefore reducing your accelleration. and Big brakes, contrary to popular beleif, don't actually do as much as people think in terms of stopping power increase, it's mainly that the disc heats up less, cools faster and therefore can stop the car more effectively, corner after corner without getting brake fade. IMO, the best brake mod for the smaller engined cars would be Performance pads and Performance Brake fluid, I wouldn't bother with drilled and grooved discs they just make your wallet lighter.
PICTURES
.:R32 Fronts
312mm and 256mm Setup from an Octavia VRS
288mm Fronts
280mm FS-III Fronts
256mm FS-III Fronts
256mm vented rears
232mm Rears
PART NUMBERS
256mm Rear splash Guards 1J0615609 & 1J0615610
256mm Caliper Carrier right 1JO 615 425 E
256mm Caliper Carrier left 1JO 615 426 E
256mm Caliper right 8NO 615 424 C
256mm Caliper left 8NO 615 423 C
256mm Discs 8LO 615 601
256mm OEM Pads 4BO 698 451
Rear Wheel hub with bearing 1JO 501 477 A
Front left 312mm Shield 1J0615312B Front right 312mm Shield N90305302
UPGRADES
Front
The easiest upgrade of all is the 288mm to 312mm front setup. All this requires is 312mm Carriers and Discs(splash guards if you want, but they are not essential)
Upgrading 280mm FSIII's (AKA un-moddable without major work) take a bit more work as you have to change the hubs. these can be acquired from a breaker for relatively cheap, if the bearings have a little bit of play in, thats OK they will tighten up once the driveshaft is in place. if in doubt consult a garage. You can get new bearings fitted for relatively cheap so it might be worth it in the long run to get them changed whilst they are off the car. then once you have the hubs, you will need 312mm Calipers, Carriers, Pads and Discs, and splash guards.
Upgrading 256mm FS-III's to 280mm can be done by changing the hubs and discs alone, the calipers and pads are the same.
Rear
The standard 232mm Solids can be upgraded for the 256mm Vented setup, the bigger caliper just bolts straight on. If the calipers/carriers have come off a Quattro/4 Motion then you will need some 6mm spacers.
You will need to modify your standard splash guards as they curl in over the top of the std disc, and would catch on the new, larger disc. or alternatively you can fit 256mm splash guards, but to do the hub has to come off and if the bearings are seized it will mean shelling out for new bearings/ fitting. and is it really worth it?
Upgrading the rear brakes does not do much in terms of braking power, reducing your stopping distance. The rear brakes only account for about 30%. Most people upgrade just for looks.
AFTERMARKET UPGRADES / BIG BRAKE CONVERSIONS
Kits like this are the ultimate in braking performance, and normally fitted to performance modded cars. but to get the most out of the braking power you are gonna need to have the rest of the car "equally modded!" it's no good fitting a set like this to a n otherwise std car with a remap, thats just overkill!
parts that need to be looked at are tyres, as wide as possible, and as sticky as possible to get some eye popping stops!
also the suspension will nose dive like crazy unless a decent "stiff" coilover set is fitted.
WHEEL CLEARENCE
Before you get excited and rush out to buy some 6 pot 358mm brembo's, you gotta think about your wheel clearance.
***NOTE*** rims are different sizes,different thickness walls, and therefore some may not fit.
these are the minimum wheel sizes, some may be very close, and may need the wheel re-balance with the weights put on the outside(not the rim face, but just not in the way of the caliper)
also some rim designs may require some spacer to fit around the caliper.
334mm R32 brakes require 17"wheels
312mm TT brakes require 16"wheels (Not BBS RX-II's)
288mm Brakes require 16" wheels
280mm Brakes require 15"wheels
256mm Rears need a 16"to clear the caliper(15"spare doesn't fit)
PAINTING CALIPERS
most people paint there calipers to make them look better, the general consensus on the forum seems to be with big brakes go Anni Red or .:R32 Blue, but if you have standard calipers then a more subtle tone(black, silver, gunmetal grey) might be in order, because nothing looks more "max power" than small bright red/orange/yellow calipers.
before you paint them you will have to remove all the brake dust and the majority of the rust. then mask up the area you don't want paint on and paint. Hammerite smooth and B&Q Japlaq seem very popular. these are cheaper than a special caliper painting kit, which is just in a smaller pot and probably comes with a tin of brake cleaner worth a fiver, and costs more than twice the price.
give them a few coats and for best results don't drive in-between!
For the full thread see here
For any update / corrections then please PM me
