Performance tuning specialist - Offering custom remaps, turbo upgrades and performance exhausts
uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » VW MK4 Golf Bora Electric Window Regulator Repair
Last post Thu, Jul 3 2008 5:41 AM by shaner. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jan 21 2008 2:03 PM VW MK4 Golf Bora Electric Window Regulator Repair
    dirtydom
    • Joined on Sun, Sep 16 2007
    • Posts 11
    hi found this guide on the net the other day hope it helps someone out.
    PART I - REMOVING THE WINDOW REGULATOR CARRIER PANEL
    1. Remove the inner door trim panel (shown below).
    2. Once the panel is off, you should see something like this. FYI, I have aftermarket speakers, so your woofers will look different if you have stock speakers. Also, there is some Dynamat on my window regulator carrier panel (the black panel bolted to the inside of the door) surrounding the woofer. This is not present on a stock panel.
    3. Disconnect the harness connector from the top of the woofer. The approximate location of the connector on a stock woofer is shown below.
    4. Disconnect the harness connectors for the tweeter and side-view mirror, indicated by the red arrows in the picture below.
    5. Remove the harnesses from the harness carrier (indicated by the yellow arrow), as shown below.
    6. Using a screwdriver, unplug the two rubber grommets that cover the access holes for the window regulator clips. One of the grommets is shown below.
    7. If your window still works (i.e., the clips have not completely broken and the window still moves up and down), continue on with step 8 through 11 and then go directly to step 13 (skip step 12). If your window has fallen into the door, go directly to step 12.
    8. Depending on the current position of the window, raise/lower the window so that the window regulator clips at the bottom of the window can be seen through the access holes, as shown below. Since the door panel is off, you'll need to use the window controls on the 'other' door to do this.
    9. The next step is to temporarily support the window glass while the regulator clips are being changed. Place a rag over the top of the door. Apply a piece of duct tape to the outside of the window, up and over the top of the door and then to the inside of the window. I recommend doing this diagonally with two opposing pieces of tape, as shown below.
    ATTENTION: Please make sure to completely secure the window with the duct tape. The removal of the window regulator carrier panel requires that the entire weight of the window glass be supported by the tape. For this reason, I only recommend using duct tape. Other types of tape may not be able to support the weight of the window glass. Since the window may have to be supported by the tape for 1-2 hours or more, periodically check to make sure the tape is holding properly and is not peeling away from the glass. If this occurs, the window glass may fall into the door and shatter!
    10. Remove the 10mm bolt that secures each window regulator clip (two total) to the window glass, as shown below. If you are only replacing the door lock module (i.e., not replacing the clips), you do not need to remove the bolt, only loosen it.
    11. Lower the window regulator clips approximately 4-6" using the window controls on the 'other' door. The clips should disconnect from the bottom of the window - this will help in removing the carrier panel later on. Go directly to step 13 (skip step 12).
    12. If the regulator clips fail and the window falls into the door, it can be difficult to remove the carrier panel since the window often 'gets in the way'. If possible, try to remove the window from the door completely. This almost definitely requires the help of a second person. Attempt to pull the window up by its top edge. If you can raise the window nearly out of the door, it probably means that both clips have definitely failed. Try to raise the window so that the clips can be seen through the access holes described in step 8. If this is possible, remove the 10mm bolts, as described in step 10 and slide the clips off. Once the clips are off, remove the window from the door by pulling it up and out of the door. This is easiest if you rotate the rear edge out first and pivot the window around the lower front corner toward the front of the car. The window should come out of the door easily. If you're successful in doing this, put the window aside in a safe place. If you are not able to remove the window from the door (because it wasn't possible, not because you didn't try), it may mean that one of the regulator clips is still fully or partially intact. If this is the case, you may have to improvise a little during later steps to remove the carrier panel. I can't be more specific about this problem, since each different situation will have it's own solution.
    ATTENTION: Please be extremely careful when removing the window glass from the door. Make sure to have a strong grip on the glass at all times or it may fall and break.
    13. Disconnect the harness connector from the regulator motor by pulling down on the retaining slide, as shown below.
    14. As you pull down on the retaining slide, the harness connector will slide toward the front of the car and off of the regulator motor, as shown below.
    15. Check to see if the door lock module is riveted to the carrier panel, as shown in the picture below. Normally, the lock module is riveted to the panel, but if your regulator clips have been replaced already, the rivets may not be present. VW techs are notorious for not reinstalling the rivets when replacing the regulator clips. If your lock module is not riveted to the panel, perform step 16. If your lock module is riveted to the panel, you have two options. You can (1) drill out the rivets and continue on with step 16 or you can (2) leave the rivets intact and go directly to step 17. Option 2 is the preferred method since the rivets can be reused when reinstalling the carrier panel on the door - new rivets will not need to be purchased. If you plan on replacing the door lock module, you must perform all of the related steps (16 through 24 - do not skip any of these steps).
    16. Pop off the rubber grommets for the inner door handle release cable and the door lock pin (indicated by the yellow arrows in the picture below) and then push the grommets through their respective holes in the carrier panel.
    After doing this, go directly to step 25 - Do not perform steps 17-24 unless you are replacing the door lock module.
    If you are fitting our Delock Kit perform steps 17-20 & then go to step 25.
    If you are replacing the door lock module, you MUST continue on with step 17.
    17. Remove the small plastic tab on the rear edge of the door with a screwdriver. The tab is indicated by the yellow arrow in the picture below.
    18. Behind the plastic tab is a retaining screw which is used to secure the blank in the door handle, indicated by the yellow arrow in the picture below. On the driver's side door, the screw secures the piece which surrounds the door lock key slot.
    19. Loosen (but do not completely remove) the retaining screw with a T20 Torx driver. The screw actually has a very small triple square head, but a T20 driver works perfectly. The retaining screw can be seen in the picture below.
    20. Loosen the retaining screw enough so that the handle blank slides out of the door. The passenger's and driver's side pieces can be seen in the pictures below. On my car, the screws needed to be turned approximately 13-15 turns for the pieces to slide out. Also, you may need to pull out on the door handle slightly to allow each piece to slide completely out.
    21. The outer handle is connected to the door lock module by a small cable (red arrow in picture below). The end of the cable is secured to the handle by a small plastic tab (yellow arrow in picture below) which fits into a threaded groove.
    22. Pop the tab on the end of the cable out of its retaining groove using a small screwdriver, as shown below. Before doing this, note the position of the tab in the groove so that it can be reinstalled in approximately the same position later.
    23. The picture below shows the tab detached from the retaining groove.
    24. Remove the two door lock module bolts on the rear edge of the door using the 8mm triple square tool. The bolts are indicated by the yellow arrows in the picture below. The 8mm triple square tool is also shown below.
    25. Pop off the rubber grommet and push in the wire loom retaining clip indicated by the yellow arrows in the picture below.
    26. The grommet and retaining clip should look like they do in the picture below when step 25 is completed.
    27. Put a sheet or blanket on the ground below the door and over the door sill (as shown below) to protect the sill and carrier panel when the panel is removed from the door.
    28. Remove the ten (10) 10mm bolts that secure the carrier panel to the door. The locations of the bolts are indicated by the yellow arrows in the picture below.
    29. Starting at the rear bottom corner of the panel, pull the bottom of the panel away from the door slightly, as shown below. You may have to move the panel up or down slightly to wiggle the bottom of the panel out of the door. This step may be very difficult to perform if the window glass is still sitting at the bottom of the door, especially if one of the regulator clips is still attached to the bottom of the window. If this is the case, then this is the point in the DIY that you might have to be creative in order to complete the removal of the carrier panel from the door.
    30. While holding the bottom of the panel away from the door (and also supporting its weight), reach behind the panel from below and push the six (6) wire loom retaining clips out of the panel. The locations of the clips are indicated by the yellow arrows in the picture below. If you yank on the clips from the front of the panel, you will almost surely damage them, making it difficult to reattach them when reinstalling the panel.
    31. A close-up of one of the wire loom retaining clips is shown below. The clips are held in place by small tabs on opposite sides of the clip, indicated by the yellow arrows. Push in on these tabs simultaneously and push the clip out of the panel.
    32. Once the tabs are out, lift up on the panel slightly, pull the bottom of the panel away from the door, and then lower the panel toward the ground and toward the front of the car. It is necessary to do this because the window tracks extend above the top of the carrier panel inside the door (blue arrows in picture below) and the door lock module extends to the right of the panel inside the door (red arrow in picture below). If you are removing the carrier panel with the door lock module still bolted to the edge of the door, you do not need to slide the carrier panel toward the front of the car when removing it since the lock module is not attached and will not impede its motion. You'll only need to lower the panel so that the window tracks clear. Also pay careful attention to the inner door handle cable and door lock pin when removing the panel as they are attached to the door lock module and must slide out of the panel.
    33. Once the panel is removed from the door, disconnect the harness connector for the door lock module by pressing down on the tab indicated by the yellow arrow in the picture below and then sliding the harness connector away from the lock module. (FYI, the lock module on the driver's side door is shown in the picture below in case someone notices some inconsistencies in the appearance of the harness/lock module relative to the carrier panel.)
    34. Pull the door lock module wire bunch (indicated by the yellow arrow in the picture below) and harness connector through the hole in the carrier panel. The panel should now be completely disconnected from the door.
    35. If you plan on replacing the window regulator clips, go directly to Part II (below).
    As always, do this procedure at your own risk. I am not responsible for any mistakes in the procedure or those that you make while performing it.
    PART II - REPLACING THE WINDOW REGULATOR CLIPS
    Steps 1 through 5 provide some background info on how the old-design window regulator clips break, the differences between the old- and new-design clips and how the window regulator assembly works. The actual replacement of parts begins with step 6.
    1. An intact, old-design window regulator clip can be seen in the picture below. The old-design clips are a two part design - a metal clamp (which attaches to the bottom of the window glass) which slides into a plastic support. The plastic support slides up and down the window regulator track via an L-groove (right angle) in the support and is connected to a motor by a set of opposing cables - one moves the clip down the track and one moves it up the track.
    2. A broken, old-design window regulator clip can be seen in the picture below. The old-design clip fails when the plastic support cracks and pieces break off. This allows the metal clamp portion of the clip to fall out of the plastic support, often resulting in the window falling into the door (usually when both clips fail). My original clips were replaced after 4.5 years. On both the driver's and passenger's side doors, one of the two clips was found to be broken when the window regulator carrier panel was removed. I have no idea how long the clips were broken and how much longer the remaining intact clips would have lasted. I consider myself extremely lucky not to have had a window fall into the door. Only closing the doors with the windows fully closed (I was afraid of the clips breaking) probably had something to do with the clips lasting this long.
    3. The differences between the old- and new-design regulator clips can be seen in the picture below. While the old clip is a two-piece metal/plastic design, the new clip is a one-piece metal (pot metal) design with a small plastic L-groove sleeve insert to allow for easy sliding on the window track. The new-design clip is considerably stronger than the old design and should have been used from the beginning (would have saved VW and its customers a zillion headaches).
    4. The colorized image below illustrates how the window regulator system works. The window glass is raised up and down by a set of clips (yellow) that attach to the bottom of the glass. The clips are raised up and down by a set of opposing cables (blue) which travel around a set of pulleys (red) and are controlled by a drive unit which consists of a cable take-up reel (green) and an electric motor (behind the take-up reel on the other side of the carrier panel). The cable network is setup (uses a criss-cross pattern) so that both clips move up and down at the same time.
    5. The colorized image below illustrates how the take-up reel unit works. Inside the unit is a wheel (yellow) which has the opposing cables (blue and red) wrapped around it in opposite directions. Therefore, as the window motor rotates the cable wheel, one cable is let out while the other is wound in around the wheel. The springs on either end of the take-up reel unit assure that the cables always remain tight (even when the clips fail and the window falls into the door) and that the window operates smoothly.
    6. The replacement of the window regulator clips begins with the determination of whether or not the cable/take-up reel assembly supplied in the Window Regulator Repair Kit will also be replaced. The cable/take-up reel assembly is not an improved part - only the regulator clips have been redesigned. The cable/take-up reel assembly only needs to be replaced if the cable or take-up reel unit was damaged if/when the original clips broke and the window fell into the door. If your existing cables are OK, you do not need to replace the cable/take-up reel assembly when replacing the regulator clips.
    7. The cable/take-up reel assembly supplied with the Window Regulator Repair Kit can be seen in the picture below. The take-up reel assembly comes with a steel bracket attached which is used to keep the adjusting springs compressed while the assembly is not installed on the carrier panel. This bracket makes it significantly easier to replace the regulator clips and is why VW supplies it with the new cable/take-up reel assembly. It is still possible to change the regulator clips without the bracket, but doing so requires that the springs be compressed manually while trying to reinstall the regulator cables around the pulleys (this will make more sense later on).
    8. If you are replacing the cable/take-up reel assembly, leave the bracket in place on the new assembly and go directly to step 9. If you are not replacing the cable/take-up reel assembly, remove the bracket from the new assembly (be very careful - the springs are under considerable tension) and slide it onto the old cable/take-up reel assembly which is attached to the carrier panel, as shown below. If you're doing this step, make sure that the bracket is slid onto the old assembly completely. You don't want the bracket to accidentally pop off the assembly when the tension is off the cables and the cables are removed from the pulleys (this will also make more sense later on). Go directly to step 10 (skip step 9).
    9. Remove the regulator motor from the front side of the carrier panel (the side opposite where the clips, cables, etc are) so that the take-up reel unit on the back side of the panel can be removed. To do this, remove the three (3) T30 Torx screws indicated by the yellow arrows in the picture below and pull the motor assembly off of the carrier panel. Do NOT attempt to remove the cable/take-up reel assembly off of the other side of the carrier panel at this time.
    10. Using a screwdriver, pry the cable off of one of the pulleys on the carrier panel, as shown below. The bottom rear pulley (closest to the rear of the car when the carrier panel is installed and closest to the ground) is shown in the picture below. Once the cable is removed from one of the pulleys, there should no longer be any tension on the cable and it can be easily removed from around the other pulleys. If you are replacing the cable/take-up reel assembly, remove the cable from the bottom front and top rear pulleys only - the cable can be left in place around the other two pulleys (top front and bottom rear). If you are not replacing the cable/take-up reel assembly, you only need to remove the cable from one of the pulleys - it doesn't matter which one you choose. Note: It will be more difficult to remove the cable from the first pulley with the screwdriver if you are planning on replacing the cable/take-up reel assembly and did not slide the steel spring bracket off of the new cable/take-up reel assembly and onto the old assembly.
    11. Steps 12 through 22 deal with the removal of the old-design clips and the installation of the new-design clips. I RECOMMEND that you remove and reinstall each clip completely before attempting to remove and reinstall the other clip (i.e, perform steps 12 through 22 on only one clip at a time). It's possible to do the procedure on both clips at the same time, but doing it on only one will help insure that the cable routings remain in the correct position, something that may save some time when the cables need to be reinstalled on the pulleys. Note: If you are also replacing the cable/take-up reel assembly, you MUST remove both clips from their cables so that the cable/take-up reel assembly can be replaced.
    12. The schematic below shows a cross-section of a new-design clip in place on the window track (the old-design clip attaches to the track in exactly the same way - the only difference in the schematic would be the design of the clip itself). The schematic clearly shows how the window track fits into an L-groove in the clip body (on the new-design clip, the L-groove is in a plastic sleeve that is an insert in the clip body, as shown below).
    13. To remove the old clip from the window track, rotate the clip body away from the window track (A) and then slide the clip off of the track (B), as shown in the schematics below. In some cases, the carrier panel itself may interfere with the rotation of the clip illustrated in schematic (A). You may need to slide the clip up or down the window track (depending on which clip and which pulley the cable was removed from) to an area where rotation is unimpeded. If this is not possible, you may need to remove the cable from another pulley to create some more slack in the cable. If it's still not possible to remove the clips, you can always remove the cable from around all of the pulleys - this should allow you to move the clips fully up or down the window track.
    14. The picture below shows a side view of an old-design clip body where the cables attach (actually one of the broken clips). The cables fit into grooves on the underside of the clip body. One of the grooves is deeper than the other - the cable in the deeper groove needs to be removed last and installed first.
    15. A picture of the underside of the clip body (below) shows how the cables are secured in the body. There is a small cable stop on the end of each cable which fits into a hole on the underside of the clip body.
    16. To remove the cable ends from the clip body, remove the cable from its groove (start with the cable in the more shallow groove) and rotate the cable around the stop until the cable is roughly perpendicular to the clip body, as shown below. Then simply pull the cable stop out of the clip body.
    17. If you are replacing the cable/take-up reel assembly, remove the old assembly from the carrier panel (it should just pop off) and then install the new one in the same spot. Before doing so, take notice of how the cables coming out of the cable/take-up reel assembly are routed. When installing the new assembly, make sure to route the cable that comes out of the top of the assembly underneath the diagonal cable between the top front and bottom rear pulleys. Once this is done, reinstall the window regulator motor on the front side of the carrier panel. If you are not replacing the cable/take-up reel assembly, go directly to step 18.
    18. Before installing the cables into the new-design clip body, make sure that you have the correct clip for whatever door and window track you are working on. The four regulator clips (both new and old) are all different and will only work on their corresponding window track. The new clips are labeled with a code that indicates the door and window track that the clip should be installed on. 'L' and 'R' indicate that the clips are for the left and right doors, respectively. 'A' and 'B' indicate that the clips are for the front (towards the front of the car when the carrier panel is installed on the door) and rear window tracks, respectively. For example, a clip with the code 'R-B' should be installed on the right door on the rear window track. Similarly, a clip with the code 'L-A' should be installed on the left door on the front window track. Also, before installing the cables on the new clip, make sure to loosen the T30 Torx screw on the clip so that the window will slide into it easily later on. Do not remove the bolt completely - only loosen it.
    19. Install the cables into the new-design clip body by following step 16 in reverse. Remember to install the appropriate cable into the deeper groove first. The cables should appear as they do in the picture below after being installed.
    20. On the side of the clip, there is a small tab which separates the two cables and keeps them from rubbing against each other. Make sure that one of the cables runs on one side of the tab and the other cable runs on the other side of the tab.
    21. Now it's time to install the new-design clip onto the window track - the schematics below indicate how to do this. The process is basically the exact opposite of the removal of the old-design clips from the window track. Simply insert the edge of the window track into the plastic L-groove insert in the new clip (A) and then rotate the clip body into place on the track (B).
    22. The picture below shows a new-design window regulator clip installed onto the window track.
    23. If you did not remove and replace both regulator clips at the same time (for whatever reason), remove and replace the regulator clip on the other window track by following steps 12 through 22.
    24. Once both regulator clips have been replaced, it's time to reinstall the regulator cable on the pulleys. Make sure that the cable is installed correctly on three of the four pulleys and then use a screwdriver to pop the cable onto the fourth and final pulley. Make sure that the cable guide (indicated by the yellow arrow in the picture below - there is one for each pulley) is in position. This procedure should be relatively easy if the steel spring bracket is in place on the cable/take-up reel assembly. If it is not, you'll need to compress the springs on the assembly by hand to provide enough slack for the cable to be installed on the final pulley. It helps to have a second person compress the springs while you install the cable on the pulley. Newer pulleys have a cam pulley molded on top of each cable pulley which can be used to assist in reinstalling the cables if need be (Sorry. I don't have a picture). To use the cams, install the cable on one or more of the cams instead of directly on the main pulleys - use as many cams as necessary to provide enough slack to get the cable on all four cams/pulleys. Once the cable is in place on the four cams/pulleys, pull down or push up on the two regulator clips simultaneously. This will force the clips to move and will cause the cables to rotate on the cams/pulleys. After moving the clips a short distance, the cams will pop the cable onto the main pulley - move the clips until the cable is correctly installed on all four main pulleys.
    25. Once the cable has been reinstalled on pulleys, double check to make sure that the clip replacement process has been done correctly. First, make sure that the new regulator clips line up with the access holes in the carrier panel (red arrows in picture below). If they do not, you'll need to reinstall the clips in the correct locations. Next, make sure that the cable coming out of the top of the cable/take-up reel assembly passes underneath the other diagonal cable, as indicated by the blue arrow in the picture below. Finally, make sure that the cables sit on opposite sides of the small tab on the edge of the clip bodies, as described in step 20. If the above three conditions are met, then the new regulator clips should be installed correctly.
    26. Remove the steel spring bracket from the cable/take-up reel assembly. The window regulator system should now be fully operational.
    27. Reinstall the carrier panel back onto the door
    i do have the whole guide with pictures too but i cant figure how to get it on the forum if anyone can help as i have about 30 guides to post .
    cheers dom
    Dom
  • Tue, Jan 22 2008 11:54 AM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    Pauls1820VTGolf Moderator
    Bora SE TDI 1.9 AJM 115PS
    • Joined on Fri, Feb 17 2006
    • Posts 8,613
    to add images, store them on something like photobucket, then take the image code and paste it into here,
    so you get something like {img}URL.com/locations of image/name of image{/IMG}
    with [ and ] not { and } though
    PD150 ARL engine | fk highsport coilovers | TT 6 spoke alloys | remap to come | 288mm brakes
    My Build Thread - Slowly getting there!
  • Wed, Jan 23 2008 1:36 PM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    dirtydom
    • Posts 11
    cheers for that i will get them uploaded asap
    dom
    Dom
  • Wed, May 7 2008 3:12 PM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    wafers
    • Joined on Sun, Dec 9 2007
    • Posts 23
  • Wed, May 7 2008 3:13 PM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    wafers
    • Posts 23
     Hi Dom,
    Any chance of those pics - I need to do this job this weekend :(
    Cheers!
  • Thu, Jun 12 2008 3:42 AM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    jamiesGTI
    • Joined on Wed, May 10 2006
    I need to do the rear window regulator is it the same? or at least very similar?
  • Thu, Jun 12 2008 7:14 AM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    Matt20vt
    • Joined on Sun, Aug 5 2007
    • Posts 486
     http://forums.vwvortex.com/zerothread?id=1015107
    ^^ Above write up and pictures there.
    Looking for Business Insurance? Look here! www.click2compare.com
  • Fri, Jun 13 2008 12:47 PM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    Turbo-GT
    Golf V R32 3.2 250PS DSG
    • Joined on Tue, Nov 8 2005
    • Posts 203
     id rather give my mechanic £20 to fit it in for me :)
  • Mon, Jun 16 2008 4:00 AM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    Matt20vt
    • Posts 486
     I've been quoted £130 inc parts for the job of a lock mechanism change :s
  • Mon, Jun 16 2008 1:08 PM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    • Posts 17,906
    Turbo-GT:
    What mechanic would do that job for £20? I did one today (supply and fit) at a good rate for a very reugular customer and it was £140.
  • Thu, Jul 3 2008 5:41 AM Re: VW MK4 Golf Bora Electric Window Regulator Repair
    shaner
    • Joined on Thu, Jul 3 2008
    Hi guys,
    Nice guide, i think this guide (with pic's) will help to understand the process also.
    check it out -
    http://www.fixya.com/support/t735283-power_windows_replacement
    Good luck,
    Shane
