ludwig:
canariesz1, sorry to hear about your problem.
On 11/11/07 on Tyresmoke, I recal, I posted:
"Froggy, that's interesting.
Do VW Assist know about this??
When my GTI started playing up with a flat battery in October 2006, VW Assist came out twice and said that there was a drain on the battery - from somewhere!
Too right there was.
On the second visit, they pulled the radio fuse out.
That stopped it draining!! Of course it would.
To cut a long story short, I've posted somewhere in the MKV GTI section here or on uk-mkvs.net that the dealer subsequently replaced the battery and the alternator. Great isn't it?
Since then no more trouble, so far.
ludwig "
I hope that is of some help.
Ludwig
Hi, thanks for your reply. I'm having a bit of a nightmare with this to be honest. Vw have had my car since friday (it is now tuesday) Yesterday i was told that it is one or both of two problems
1) Being a faultly electrical component for my interior courtesy lights, eventhough the lights are going out they are still draining on the battery. To replace this is 300+!!
2) I'm not exactly sure but could be a fault with one of the lights them selfs which is again even though to the eye is going out when i lock the car is still draining on the battery. this is 100+ As the enginneer thinks it is most likely the faulty electrical swtich component they are going to change that first.
I had spent 200 before they could even come back to me with these two faults! (What is a cheaper way of doing this? The fault finding/diagnostics check thingy? i didn't really have any other options as my car was imobile becuase of the constant flat batteries)
Just a side point i wish you could actually speak to the bloke working on your car rather than the dippy receptionist (male or female) as they are just relaying the info given to them and really don't know what there talking about (at my STEALERS anyway) Bromley, kent by the way. Anyone had any dealings with them??
I was also told that my vw sat nav mdf2 (which i put in myself as an after maket) Is causing a 0.3 amp ( i hope thats correct??) drain on the battery so if left over a long enough period would cause the battery to go flat. I think we are talking a long time though.
SO i am waiting on the phone call to say whether the component was the fault behind the flat batteries????
