uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - Engine and Exhaust » Lumpy engine on tickover and acceleration TDI
Last post 28/07/2008 1:43 PM by Gloves. 9 replies.
  • 03/02/2008 7:01 AM Lumpy engine on tickover and acceleration TDI
    James_E
    • Joined on 04/02/2005
    • Posts 51
    Hi,
    I am the proud owner (2 weeks now) of a mk5 Golf GT TDi, I love it to bits but there seems to be a problem with the engine (I think). It is very lumpy on tickover and I have to give the throttle a poke when I start it just to get it up to a reasonable speed so it is not coughing and spluttering. Can anyone help me to identify the problem before I take it to a garage and have to sell a kidney on ebay to pay for the work ;)
  • 03/02/2008 7:05 AM Re: Lumpy engine on tickover and acceleration TDI
    yass066
    Golf IV 1.6 8v APF 100PS
    • Joined on 27/05/2007
    • Posts 284
    Once up to temperature does the car run fine?
    Yass
  • 04/02/2008 6:10 AM Re: Lumpy engine on tickover and acceleration TDI
    James_E
    • Posts 51
    Hi Yass,
     Yes it does seem to be fine when it warms up a bit, is that normal then? I had a Bora TDi before the Golf and it didn't used to do it so I assumed it had aproblem.
  • 04/02/2008 6:50 AM Re: Lumpy engine on tickover and acceleration TDI
    yass066
    • Posts 284
    I would firstly change them temperature sender. This unit controls the automatic choke in these cars and if its faulty when the engine is cold it will not have set the choke correctly.
    Have you had the car scanned with vag com?
    What i suugest is,first scan the car for any faults,if non appear change the temp sender.
    Easy fix not more than £30
    Yass
  • 04/02/2008 9:48 AM Re: Lumpy engine on tickover and acceleration TDI
    James_E
    • Posts 51
    I have had a vag com scan which came up with one fault but it did not give a name or description of the fault so I just wiped it. I  had a scratch touched up in the body shop so the battery has been disconnected so I just thought it was that but maybe not?
    I will see if I can get a new temp sender from VW. Is there a guide or some instructions I can follow.
    Thanks Yass
  • 05/02/2008 5:17 AM Re: Lumpy engine on tickover and acceleration TDI
    James_E
    • Posts 51
    Ok this morning it was lumpy again and I drove my girlfriend to work and in every gear when I put my foot down it was just totally flat no accelration what so ever, really really slow. I stopped the engine for about 20 mins and when I started it again it was fine?
     Do you think this is to do with the temp sender too?
  • 05/02/2008 5:18 AM Re: Lumpy engine on tickover and acceleration TDI
    James_E
    • Posts 51
    James_E:
    Ok this morning it was lumpy again and I drove my girlfriend to work and in every gear when I put my foot down it was just totally flat no accelration what so ever (ok a little bit), really really slow. I stopped the engine for about 20 mins and when I started it again it was fine?
  • 05/02/2008 5:19 AM Re: Lumpy engine on tickover and acceleration TDI
    yass066
    • Posts 284
    I would personally change the temp sender. Call the stealers and ask them how much one is for your car.
    Yass
  • 08/07/2008 4:29 PM Re: Lumpy engine on tickover and acceleration TDI
    ishyz
    • Joined on 29/06/2008
    • Posts 85
    may be airflow mass sensor. have a scan done
  • 28/07/2008 1:43 PM Re: Lumpy engine on tickover and acceleration TDI
    Gloves
    • Joined on 27/07/2008
    • Posts 14
     I had a similar problem recently. From cold my car would struggle to run clean for about 10seconds especially if not used for a few days. After the initial start it would be ok for the rest of the day. As it was still under warranty, took it the dealer in St.Albans and they cured it first time and the problem has not reappeared since ( about 6 weeks) .They told me there has software update of the ECU which they did  and all has been ok since. Hope this is some interest to you
