VAG :: ENGINE CONVERSIONS - TUNING - STYLING - SERVICING
uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Retro fit wiper stalk with MFD control.
Last post Mon, Aug 10 2009 5:03 PM by gotgolf18. 4 replies.
  • Mon, Feb 4 2008 9:23 AM Retro fit wiper stalk with MFD control.
    • Posts 8,162
    Parts needed:
    Wiper stalk with controls for the trip computer: 4B0 953 503 H
    VW electrical repair wires for Wiper Stalk 000 979 133 (2 connectors per wire)
    VW electrical repair wires for Instrument Cluster harness 000 979 018 (2 connectors per wire)
    About 1m of 18 guage wire used if you need to extend the wires from the stalk to the cluster.
    Procedure:
    DISCONNECT THE BATTERY - If you don't then you could have air bag warning lights on afterwards as you will be disconnecting the clocks.
    It’s not necessary to take the airbag off to just do the wiring only if you are fitting the stalk. The upper and lower covers that go around the control stalks and ignition key can be removed using a Phillips screwdriver. Just twist the steering wheel around as needed to access the 4 screws. There is a 5th screw (Torx) on the bottom near the handle for steering wheel tilt adjustment.
    Some Golf's already have the 6 pin connector (connector T6e) in place. Pins T6e/5 and T6e/6 contain wires used to control the intermittent windshield wiper regulator (ref wiring diagram 52/20, tracks 253 & 254). Pins 1 through 4 were empty, and will be used for the MFI control wires.
    Disconnect the connector, pop it open, and install the 4 repair wires in slots 3 to 6 of the connector.
    6 Pin Connector (T6e) with repair wires in place
    The photo below shows connector T6e in place as found it in the car, and connector T32a Green in place behind where the instrument cluster normally goes. The repair wires need to run between these two connectors. T6e uses medium size repair wire connectors, and T32a uses the very smallest size. By using half a length of each repair wire, there should be enough overall length to complete the harness without needing additional wire in the middle.
    View with cover off steering column and instrument cluster removed, showing connector T32a
    The only really annoying part of the job is removing the existing, blank pins from connector T32a. These pins have a small barb on the left side (left side when viewed with the wires exiting from the top), and you can used the tip of a knife to press the barb to the right, while prying the pin up wards at the same time with a jeweler’s screwdriver. The photos below illustrate the process.
    Releasing the barb on the OEM blank pin
    The OEM blank pin halfway out (it slides straight up)
    What the OEM pin looks like, showing the barb on the left side
    Once the OEM blank pins are out, it is pretty easy to put the replacement pins from the stalk into the empty slots. The pin outs go as follows:
    T6E (wiper stalk 6 pin plug) T32a (Green multi plug connector on the rear of the clocks)
    T6e pin 1 to T32a pin 24 - This is the MFI call up button bottom (display switches up).
    T6e pin 2 to T32a pin 23 - This is the MFI call up button top (display switches down).
    T6e pin 3 runs to ground
    T6e pin 4 to T32a pin 25 - This is the MFI memory reset switch.
    The photo below shows connector T32a after the MFI control harness has been installed in it, but before the cover is put back on the connector. You can also see the unusual recessed bolt that holds the steering wheel in place. As mentioned earlier, you don’t need to take the airbag off if you plan to install the wire harness only. The airbag and steering wheel will need to come off when you remove and replace the control stalk.
    Wires in place in connector T32a
    The photo below is just a close-up of the finished job, again, before the cover was put back on connector T32a.Use a marker pen to put dots on the end of the wires, indicating what pin location on T6e they came from.
    Close-up of T32a with cover off connector
    When you are putting the wires in place running along the channel from T6e along the existing wire bundle in the steering column, be sure that the wires don’t foul when the steering column is moved up and down, and also in and out. Be especially careful to be sure that the wires are not crushed against a large metal flange near the wire harness when the steering column is moved to the full ‘up’ position.
    HTH
  • Sun, Feb 17 2008 8:27 PM Re: Retro fit wiper stalk with MFD control.
    suj
    • Joined on Wed, Jun 21 2006
    • Posts 781
    Awesome post will definitely be needin this when I finally get my new cluster! (so £!)
    Retrofit := Armrest, Cupholder, MFA with lit-needles and MTE, MFA Stalk, Auto lock/unlock, Spare key, OEM style remote locking inc. flip and startable key
    To do := Install OAT sensor, Chrome rings
    Coming soon := New cluster needles
  • Sat, Jan 10 2009 8:38 AM Re: Retro fit wiper stalk with MFD control.
    suj
    • Posts 781
    Anyone know which earth point I can use behind the cluster? Just wired up the plug fine but now need to attach a wire to an earth and not really sure which to use and how to attach it...
  • Sat, Jan 10 2009 8:47 AM Re: Retro fit wiper stalk with MFD control.
    winwiz
    Bora S TDI 1.9 ATD 100PS
    • Joined on Thu, Feb 21 2008
    • Posts 492
    If you remove the plastic under the steering wheel, you will see a big nut with a load of brown wires attached to it. You can use this as an earth....
    Bora Sports Clocks | 18" RS6 alloys | Retrofit Trip Computer | Miles to empty | GLI Tail Lights | Rear lip spoiler | Full Closure |Blue LEDs in both doors | JVC AVX-33 DVD | Bluetooth | Aero wipers | GTI steering wheel | Optic trim | Retrofit Armrest | Debadged | Stubby Aerial | Recaro headrests | W8 Light with super bright LEDs| Auto locks enabled | Toad Ai606 | Coming home headlamps | more to come!
  • Mon, Aug 10 2009 5:03 PM Re: Retro fit wiper stalk with MFD control.
    gotgolf18
    • Joined on Sun, Mar 22 2009
    • Posts 198
     Hey a just spottet some thing on your thread.(T32A PLUG) Now is the pug where the 3 wires go from the green plug too get all your info up on your full FIS? Is there any more info on how to put them 3 cables into the T32A plug? Please Pleas help!
    Thanks Chris
    Golf anniversary GTi TDI 1410, W8 light, Full Screen full FIS clocks, Built in sat nav, mark 5 rear window wiper, Milltex down pipe stright through with milltex 180 anni siliencer and back box with tail with 180 rear valance! :) Ebach front and back roll bars (rear still too fit). 4 pot brakes and discs ready too fit! R8 oil cap! Ecu software map, bora vents, r32 door triggers (still too fit) Nearly forgot Heated anni seats!
