uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Chrome Ring Dials Installation for MK4 (Complete)
Last post Thu, Nov 12 2009 2:06 AM by hotboy836. 39 replies.
Page 1 of 2 (40 items) 1 2 Next >
  • Sat, Mar 1 2003 4:54 AM Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Joined on Tue, Jul 23 2002
    • Posts 5,864
    Just fitted mine to my 1.6SE this afternoon, took about 40 minutes. Very easy. I managed to get superglue on my fingers (not stuck together) but apart from that it went very smoothly...cant recommend this mod highly enough, it looks the business and was pretty simple. Heres a brief how-to for those who want one but it has pretty much been covered in other threads...
    1) Disconnect the negative terminal on the battery. You will probably find like me that the central locking no longer works [:I] so if you are going inside to do the dials, dont forget to manually lock it!
    2) Pull the plastic cover above the wheel off. Its tricky and be careful not to snap the clips...theres to big ones on the left and right, and a small one in the centre.
    3) Take a T20 torx screwdriver (mine was T20 but other how-tos have said T10?) and undo the two screws underneath. This is a pain to get at and be careful not to lose the screws down there, because it doesnt look like it would be easy to retrieve them!
    4) Gently pull the cluster out. Its connected by a plug on either sidde- pull the pink plastic clip backwards and the plug comes out. I did the left side first then twisted the cluster around to undo the right.
    5) Remove the cluster and use a torx screwdriver (cant remember the size but its the smallest one) to remove the two screws on the back. Now gently unclip the clips around the edge, tear the sticker sealing the unit and gently pull apart.
    6) Put the dials to one side; I used cling film over the top to keep it clean. Its important all of these steps are done in a very clean environment and you dont get finger prints on the inside!
    7) Squeeze the rings through the back of the holes in the cluster. Its tight but a good squeeze and they go through. Once iside you will see they are a tiny bi smaller than the hole, which is a pain for alignment so do the best you can.
    8) I used superglue on the edge of a knife and applied it to the ring from the hole (ie while the ring is in the cluster). I then turned it up the right way and let the ring drop into place and left it for 10 minutes.
    9) Re-assemble the cluster, reverse the process for removing the cluster and reconnect the battery. You may need the radio code (I didnt) and will need to set your clock, but everything started fine for me and no car fires, which was nice. Admire your beautiful work. Who needs the 2002 Bora cluster?
    TIPS:
    The screws that hold the cluster in are a swine. Ipulled the wheel all the way out and down to do this, and its very tricky to hold onto the screws, especially when putting them back. But perservere and dont drop them!
    Supergule on your fingers is a weird sensation. Soak them in hot soap water for ages and it will come off with a knife.
    Hope this helps, and good luck guys its well worth it.
    Mike
    06 BMW Z4M Coupe
    Mongol Rally 2009 | Mongol Rally 2009 - The Movie | No VAG for four years but still here?
  • Sat, Mar 1 2003 5:14 AM Chrome Ring Dials Installation for MK4 (Complete)
    Foxy
    • Joined on Wed, Jun 5 2002
    • Posts 4,485
    Nice one Mike - thanks for the write-up.
    Be careful not to use too much superglue peeps - as the fumes can cause a white stain to appear around them.
    For gap bridging ability, you want the thicker superglue.
    I have some already - its available from good model shops and is used for glueing balsa wood, etc.
    Same cyanoacrylate glue but of a thicker consistency
    See my website again: http://www.foxytech.hostcell.net/
  • Sat, Mar 1 2003 8:07 AM Chrome Ring Dials Installation for MK4 (Complete)
    smithy
    • Joined on Tue, Jul 9 2002
    • Posts 134
    Got some pics mike. Must be nice to buy a mod and it fits. Not like the Gear knob we bought hey.
  • Sat, Mar 1 2003 9:19 AM Chrome Ring Dials Installation for MK4 (Complete)
    aRd
    Golf IV SDI 1.9 AQM 68PS
    • Joined on Sat, Aug 17 2002
    • Posts 2,880
    Good write up Mike, nice one mate
    I used Evo-Stik
    Here's a pic of my chome rings
    Need some help with Vagcom check, Keys/Immobilser adaption, cluster swapping, Miles till Empty/Illuminated Needles, Autowindows, ECU swapping//coding etc... PM me :) Pics of the aRd automobile http://uk-mkivs.net/forums/p/239924/1548484.aspx#1548484
  • Mon, Mar 3 2003 9:20 AM Chrome Ring Dials Installation for MK4 (Complete)
    johnbag
    • Joined on Thu, Feb 13 2003
    • Posts 6
    WHERE DO YOU GET THE RINGS FROM AND HOW MUCH ARE THEY?
    ALSO I THOUGHT YOU COULD GET AN ALLOY TRIM FOR THE MIDDLE OBLONG PART?
  • Mon, Mar 3 2003 9:56 AM Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Posts 5,864
    I got them from the group buy organised by Toff- well done again mate, amny thanx. They were £21 and yes a centre piece was available but it doubled the cost as I recall and looked cheap IMO...the two rings alone look more OEM to me. I am thrilled with the result, highly recomended
    06 BMW Z4M Coupe
  • Mon, Mar 3 2003 10:15 AM Chrome Ring Dials Installation for MK4 (Complete)
    allmond10
    • Joined on Tue, Dec 3 2002
    • Posts 40
    Where can they be bought now that the group buy has finished?
    GTi TDI 150 [Blue Footwell Lighting][Red-Clear-Reds][GTi Grill Badge]
  • Tue, Mar 4 2003 12:33 AM Chrome Ring Dials Installation for MK4 (Complete)
    ICEMAN
    • Joined on Sun, Mar 2 2003
    • Posts 167
    The thread suggests that it may be possible to do another GB of them. Have a look in the group buy section.
    I hope another one is done, cause I'd love some...
    Pete
    Platinum Leon Cupra R,
    LOADS OF ICE
    My ICE Magazine site www.icecavern.com
  • Wed, Mar 5 2003 8:12 AM Chrome Ring Dials Installation for MK4 (Complete)
    Chris
    • Joined on Thu, May 16 2002
    • Posts 2,357
    Just fitted mine, thanks for the guide Mike! Smile [:)]
    Really is very straightforward, just make sure you follow the exact instructions in the how-to above. Be very careful about the environment you do this mod in tho, as Mike says.... i have a couple of white specks on the inner of the glass, which is a pain, but not a big enough pain to do the whole thing again! Wink [;)]
    I was worried that removing the cluster would knack up my immobiliser, with my Golf being a very early model.. however, it was fine, so do this mod without worry!
    Diamond Black 06 MKV GTI - 18" MonzaII - Winter Pack - Cruise
  • Wed, Mar 5 2003 9:30 AM Chrome Ring Dials Installation for MK4 (Complete)
    dieselman
    • Joined on Mon, Jul 15 2002
    • Posts 12
    quote:
    I hope not, but does this invalidate the warranty?
  • Wed, Mar 5 2003 12:50 PM Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Posts 5,864
    Well you could probably peel it back carefully and not tear it...then reapply it. Mines out of warranty though so I didnt bother
    06 BMW Z4M Coupe
  • Tue, Mar 11 2003 6:09 AM Chrome Ring Dials Installation for MK4 (Complete)
    UB
    • Joined on Wed, Aug 28 2002
    damit... i made a bit of a mess with the super glue and now theres white stains all around the rings
    Anyone got tips for me on how to remove the stain!? maybe some metal polish?
    also got the clear screen all dirty and smudged arghhhh Sad [:(]
  • Thu, Mar 13 2003 3:20 AM Chrome Ring Dials Installation for MK4 (Complete)
    Mark Mc
    • Joined on Mon, Oct 7 2002
    • Posts 19
    heres a pasted version of what I put in the group buy topic:
    Woohoo! Fitted, and I'm made up with them!
    BAsic instructions as follows:
    1. Make sure you have some super glue. (I used Loctite Superglue from B&Q. very thin and clear, and sets quickly) I ended up having to walk to B&Q when the glue I had ran out after glueing one cluster!!! and also a torx driver and maybe even a flex drive( flexible screwdriver with socket attachment on the end).
    2. Disconnect battery!!!!!!!!!!
    3. drop steering wheel right down, and remove plastic trim with leather attachment for steering column. Have to play around, but it is push fit in the left middle and right.
    4.remove the 2 torx bolts from under the cluster. I used a flexi drive to get at these.
    5. pull cluster forward, and then unclip both plugs from behind cluster.
    6. take cluster away and lock car up( in my case anyway!
    7. slowly prise the clear front off the cluster. its spot glued all the way around. I did crack bit of it, but only where you cant see. This is the fiddly bit!! any other options would be advised, but I tried dismantling the cluster and that didn't work.
    8. glue the rings and let them set in place.
    9. wipe them clean.
    10. clean the inside of cluster front.
    11. spot glue the cluster front and then let it set in place.
    12. refit the cluster in car. refit both plugs.
    13. place the cluster and tighten the torx screws.
    14. cross fingers.
    15. reconnect battery.
    16. turn ignition on, and allow the stereo etc to reboot.
    17. check all in well.
    18.refit the plastic trim around steering column.
    19. readjust steering wheel.
    20. clean the cluster front off all greasy finger prints!
    21. just stare at them for a while until you get bored!
    22. Then drive!!!!
    please understand though, that I cant be held responsible for your actions. this is a description of how I fitted mine, and my car is fine.
    Hope it helps, sorry theres no pics. havent got a digi camera
  • Sun, Apr 27 2003 5:55 PM Chrome Ring Dials Installation for MK4 (Complete)
    EddyH
    • Joined on Tue, Aug 13 2002
    • Posts 1,409
    I used Mike's method of installation and the clocks look great. For some added peace of mind I put half a sheet of kitchen roll inside the cluster to protect the inside face of the clear front whilst working. I think the hardest part was removing the small cover above the steering wheel, it has to be pulled quite firmly and away from the face of the clocks.
    EddyH
    Boxster S
    Mazda Bongo Campervan
  • Mon, Jun 16 2003 7:38 AM Chrome Ring Dials Installation for MK4 (Complete)
    4motion
    • Joined on Sat, Nov 16 2002
    • Posts 48
    Have just fitted my rings, courtesy of Toff's Group Buy.
    Prefer Mike's method of installation i.e. installing them through the backs of the dials, as opposed to remvoing the plastic facia, which appears pretty tricky!
    Everything went fine, except the car wouldn't start afterward! Left it for a while, tried to start it again and it eventually struggled in to life, ran it for a few mins and after that it was fine. Odd...??!!
    ...gonna buy a fast car, put on my lead boots and take a long, long drive...I may end up spending all my money but I'll still be alive...
  • Thu, Jul 31 2003 6:27 AM Chrome Ring Dials Installation for MK4 (Complete)
    Toff
    • Joined on Thu, Jul 11 2002
    • Posts 362
    Hi Guys,
    Just a reminder to those reading this thread thinking "oooh must get me some of them apples" I have lots in stock now.. so PM me if you want more details.
    Cheers - Toff.
    [ Current Car: 2003 A4 1.9 TDI Quattro Sport Avant 6-Speed ]
    [ Past Golfs: Mk1 GTI Cabrio | Mk3 2.0 Cabrio | Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Supercharged 2.0 6-speed ]
    [ Past Audis: A4 3.0 V6 TDI Quattro S-Line Saloon | S6 4.2 Quattro Saloon | A4 2.5 V6 TDI Quattro Sport Saloon ]
  • Fri, Oct 17 2003 12:20 PM Chrome Ring Dials Installation for MK4 (Complete)
    Toff - any pics of the 3 piece ring ie the fuel dials etc?
    let me know mate!
  • Tue, Dec 23 2003 12:56 PM Chrome Ring Dials Installation for MK4 (Complete)
    GaryM
    • Joined on Thu, Aug 28 2003
    • Posts 7,852
    Anybody got any pics of the chrome rings fitted?
  • Tue, Jan 20 2004 2:11 AM Chrome Ring Dials Installation for MK4 (Complete)
    rd20vturbo
    • Joined on Tue, Dec 23 2003
    • Posts 281
    I'm assuming they're the same as these:
    http://www.tachoringe.de/Fotogalerie/VW_Golf_IV/vw_golf_iv.html
  • Sun, Feb 1 2004 9:08 PM Chrome Ring Dials Installation for MK4 (Complete)
    Toff
    • Posts 362
    Sorry not to respond sooner..
    Yup, they are identicle to those above, cheers rd20vturbo.
  • Sun, Feb 1 2004 11:26 PM Chrome Ring Dials Installation for MK4 (Complete)
    GaryM
    • Posts 7,852
    Just to add that they look much better in the real, a photo does them no justice at all.
  • Sun, Feb 1 2004 11:37 PM Chrome Ring Dials Installation for MK4 (Complete)
    Toff
    • Posts 362
    Ahh..
    And the newer type have rounded edges, not square. I'll see if I can dig out some better pictures (sorry!)
    - Toff.
  • Wed, Feb 11 2004 1:55 AM Chrome Ring Dials Installation for MK4 (Complete)
    LiQuOrIcE
    • Joined on Tue, Oct 29 2002
    • Posts 1,440
    ive just ordered me some. whats the best way then?? through the back squeezed through holes or getting the clear front off?
    Fully Loaded & APR Stage 1
  • Wed, Feb 11 2004 2:34 AM Chrome Ring Dials Installation for MK4 (Complete)
    DDX
    • Joined on Wed, Oct 29 2003
    • Posts 192
    I took the clear front off, was finding it hard to squeeze the rings through the hole with out bending them which I didn't want to do.
    Be really gentle when taking the front off as it seems that it can crack easily. Let everything dry properly before re-installing them - I noticed a few white marks the next morning when I got in the car from the fumes of the super glue.
  • Wed, Feb 11 2004 4:12 AM Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Posts 5,864
    TBH I stick by the squeeze through the back method, if you take the front off and get it wrong you need a whole new cluster - lots of money.
    06 BMW Z4M Coupe
  • Wed, Feb 11 2004 4:13 AM Chrome Ring Dials Installation for MK4 (Complete)
    LiQuOrIcE
    • Posts 1,440
    think ill try that way first, but like ddx, if all seems a little too much squeezing then the front will be off!
  • Thu, Feb 19 2004 7:29 AM Chrome Ring Dials Installation for MK4 (Complete)
    Lewie
    • Joined on Fri, Oct 31 2003
    Slight spin on this, I used my wifes "tit" tape (used to hold loose tops to her breasts !!) Cut to the correct width.
    I put 3 turns of this around the inner edge, not only did this bridge the gap as the rings are slightly smaller than the hole, and hence no allignment problem. It also stopped the risk of fumes and splashes. Stuck perfectly no fuss, no fear factor.
    Tit tape available from Superdrug stores. Stickier than you would think.
    Cheers Lewie.
  • Thu, Feb 19 2004 8:28 AM Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Posts 5,864
    LOL excellent! Id love it if its actually labelled 'tit tape' too !
    06 BMW Z4M Coupe
  • Sat, Apr 30 2005 4:07 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    phonebug
    • Joined on Fri, Jul 16 2004
    • Posts 39
    Wink [;)]
    you can get super glue remover from good harware shops ,
  • Tue, Feb 13 2007 12:19 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    elio
    • Joined on Wed, Jan 24 2007
    • Posts 77
    Nice instructions friends. But all pics are "X" can post newer ones or refresh old links.
    Thanks,
    Elio
    _________________________
    Making my dreams a reality
    ElioT
  • Tue, Feb 13 2007 4:05 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    Mikedav
    • Posts 5,864
    elio:
    Thanks,
    Elio
    LOL I posted this nearly 4 years and 4 cars ago....Ill have a dig to see if I can still find the pics though!
    06 BMW Z4M Coupe
  • Wed, Mar 7 2007 12:08 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    Jatie 150
    • Joined on Mon, Aug 22 2005
    • Posts 381
    Any luck finding the pics Mike ?
    I cant afford the bora sport clocks etc thought this might be the cheaper way round !
    Pearl magic, THE DE-LOCK MOD & more to come so watch this space !!!!!!!!!!
  • Sat, Oct 31 2009 2:56 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    Scotty2Hotty18t
    • Joined on Sat, Oct 4 2008
    • Posts 73
     Hey Guys thought I'd give this a go...
    Only problem is now it's dried out it's stained all inside the cluster with white fume marks Crying
    anyone got any ideas on removing the white marks?
    Scotty
    Scotty
  • Sat, Oct 31 2009 3:42 PM Re: Chrome Ring Dials Installation for MK4 (Complete)
    hotboy836
    • Joined on Thu, Aug 30 2007
    • Posts 8,433
    gonna break ur heart mate. u cant. i did this to mine 2 years ago thinking i was being smart. and it went badly wrong.
    the fume marks were there when i woke up. then i tried glue remover to get them off and that meltd thru the clocks. had to buy donor clocks to obtain the glass.
  • Sun, Nov 1 2009 1:31 AM Re: Chrome Ring Dials Installation for MK4 (Complete)
    Scotty2Hotty18t
    • Posts 73
    God damn it! I thought that...how are people getting round this then i don't wanna do it again and have the same happen? Has anyone got a set of clocks 4 sale...or how much would i b looking 4 @ a scrappys? Scotty
    Scotty
