uk-mkivs » Technical Community » FAQ Forum » Vag-Com
Vag-Com
Last post Wed, Feb 13 2008 3:19 AM by Pauls1820VTGolf. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Feb 12 2008 12:58 PM Computer [co] Vag-Com
    • Posts 5,857
    What is VAG-Com?
    It is a Windows® based diagnostic software suite written by Ross-Tech for the VAG platform of vehicles (VW, Audi, SEAT, Skoda)
    What cable do I need?
    You will need an interface cable that connects to the vehicles on-board diagnostic connector. The genuine cable can be purchased from the Ross-Tech web site or one of their authorised distributors, these cables will have built in activation for the software which enables you to use the latest versions automatically.
    There are “dumb cables” available through sites like Ebay that don’t have activation built in and will only work on versions of VAG-Com prior to version 5, un-activated these cables allow the software to be used in shareware mode with reduced functionality but the software can be activated through the Ross-Tech web site to give the full functionality of the version.
    Ross-Tech does state that only versions 7.xx and newer of the software is Windows Vista® compatible.
    What is the difference between the Shareware version and the registered version?
      VAS-505x   $4-15k (VW Computer)
    VAG-COM Shareware
    Release 311 or 409
    VAG-COM Fully Registered V5.x - Current Release
    00  Auto-Scan
     No
    Yes
    01  Control Unit Info
    Yes
    Yes
    02  Read Fault Codes
    Limited
    Yes
    03  Output Tests
    No
    Yes
          Selective Output Tests
    No
    Yes
    04  Basic Settings
    No
    Yes
    05  Clear Fault Codes
    Yes
    Yes
    06  Close Controller
    Yes
    Yes
    07  Code Module
    Yes
    Yes
          Code Slave Modules
    No
    Yes
    08  Measuring  Blocks
    Limited
    Yes
    09  Single Reading
    Yes
    Yes
    10  Adaptation
    Limited
    Yes
    11  Login
          (called Coding II under KWP-2000)
    Yes
    Yes
    15  View Readiness
    Yes
    Yes
    16  Security Access
    No
    Yes
    18  Supported Codes
    No
    Yes
    33  Generic OBD-II
    No
    Yes
    Freeze-Frame Data
    No
    Yes
    Dual K-Line Support
    Yes
    Yes
    7-Digit PINs (VAS only)
    No
    Yes
    Code Database current through MY 2007
    Limited
    Yes
    Diagnostics via direct CAN connection
    No
    Yes
    (with CAN Interface)
    Transport Mode (VAS Only)
    No
    Yes
    (with HEX+CAN Interface)
    Advanced Measuring Blocks
    No
    Yes
    Data Logging
    (Factory tools cannot do this!)
    Limited
    Yes
    HighSpeed DataLogging
    No
    Yes
    Real-Time Graphs
    Limited
    Yes
    Real-Time Gauges
    Limited
    Yes
    Graphic TDI Timing Checker
    No
    Yes
    Control Module Finder
    Yes
    Yes
    (mis)Guided Fault Finding
    No
    No
    Which cable do I need for my car?
    To check which cable you will need for your car check this web page on the Ross-Tech web site. Generally there are two types of cable, the Key cable(K Line communication) and the CAN cable(Can Bus Communication). The MK4 platform uses the KEY cables and the MK5 platform uses the CAN cables which is also backwards compliant with the older KEY system so the one CAN based interface can be used on both platforms.
    What interface should I get, COM port or USB?
    If you're using a modern PC running Windows XP or Vista, then you should probably get a USB interface.   Although USB interfaces are no faster than serial versions, it's becoming increasingly difficult to find new PC's with serial ports, so a USB interface is more future-proof , also COM ports are not supported under Windows Vista®
    Can I use my Vag-Com cable with VAG-Tacho software?
    No, VAG-Tacho uses a proprietary interface that activates the software in a similar way that the Vag-com interface activates the software.
    Where can I find diagnostic procedure and search for what the fault codes mean?
    The Ross-Tech Wiki site has diagnostic procedures and fault code references.
    Can I enable miles to empty or auto windows using Vagcom?
    NO - These functions can't be enabled using Vagcom as they need other software and cables to perform the modifications. Miles to empty can be done via Vagtacho and a dedicated cable where as auto windows needs a serial ODB cable and a laptop with a COM port to run VDS Pro in DOS mode.
    HTH
  • Wed, Feb 13 2008 3:19 AM Re: Vag-Com
    Pauls1820VTGolf Moderator
    Bora SE TDI 1.9 AJM 115PS
    • Joined on Fri, Feb 17 2006
    • Posts 6,378
    Good write up Neil Yes
    Bora SE 115 PD TDI | Upsolute Remap to 153bhp | Cruise Control | 6000k HIDs | Coilovers and 312mm Brakes to come
    UK-VWs - A place for all VWs
    Anni Owner? Click here (25th and 30th)
