uk-mkivs » Technical Community » Diesel Discussion » Forte diesel treatment
Last post Wed, Aug 20 2008 5:58 AM by Tabs. 87 replies.
Page 1 of 3 (88 items) 1 2 3 Next >
  • Fri, Mar 7 2008 6:50 AM Forte diesel treatment
    tony_danza
    • Joined on Tue, Aug 16 2005
    • Posts 2,906
    Apparently this stuff is the shizzle - hardcore decoking style.
    Anyone know much about using it? as it isn't widely available. A brief look at the web for reviews and it would appear it does what it says on the tin.
    Mine's white and has some stuff.
  • Fri, Mar 7 2008 7:26 AM Re: Forte diesel treatment
    Archer
    • Joined on Fri, May 12 2006
    • Posts 354
    I use it on mine regularly, came highly recommended & it does do what it says on the tin.
    Get it local, from a place that specilises on anything diesel powered, think it cost me about £11.75 a bottle.
    Theres quite a lot selling it on Flea Bay, theres one with a B.I.N of a £5
  • Fri, Mar 7 2008 9:45 AM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    I wouldn't trust ebay as far as I could throw it... sadly thought here's nowhere local that sells it and everywhere online seems to think it costs upwards of £5 to send each 400ml bottle through the post.
    Fancy getting me a few bottles and sending them down if I forward you some dough Ade?
    Mike.
  • Fri, Mar 7 2008 2:03 PM Re: Forte diesel treatment
    Archer
    • Posts 354
    Yes, I don't mind doing that for you. How many do you want getting?
  • Fri, Mar 7 2008 2:17 PM Re: Forte diesel treatment
    NikB Moderator
    • Joined on Mon, Aug 5 2002
    • Posts 5,377
    Apparently there's several garages around here that sell the stuff. One of my clients was wearing a Forte jacket and I asked him about it all - apparently it really does work (but then he probably would say that!!).
    Coniston Challenge 2008
    Please donate to the Guide Dogs for the Blind - Thanks
  • Fri, Mar 7 2008 3:11 PM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    Ade - 3 bottles ok?..
    Nick - A fella at work has run it through his Vectra for 200,000 miles from new and it's the sweetest running engine I've ever heard. I've stopped the s*** coming in with the EGR bypass and Provent, so I may as well start removing the stuff clogged up around the valves and injectors. All the other stuff off the shelf isn't that different to what you already find by way of detergents in diesel apparently.
  • Sat, Mar 8 2008 9:00 AM Re: Forte diesel treatment
    Archer
    • Posts 354
    3's fine, it will be Monday before I can get them. I think they were about £11.75 a bottle - is that ok?
  • Sat, Mar 8 2008 11:17 AM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    That's cool - let me know the total cost with postage and 'll sort you the money.
  • Sat, Mar 8 2008 11:22 AM Re: Forte diesel treatment
    v2brett
    • Joined on Mon, Apr 9 2007
    • Posts 549
    its the best, my dads used it for years it goes in his golf and he put it in his peugeot until 137,000 and the engine was still sweet as when it got write off
    Candy White Mkv Gti +* 18"s * Xenons * Leather * Highline Comp * Sat Nav * Cruise
  • Sat, Mar 8 2008 11:27 AM Re: Forte diesel treatment
    maxitrol
    • Joined on Wed, Mar 29 2006
    • Posts 835
    i ave used forte for a few years now...When a diesel  fails its emissions poured it into the tank & it normally passes...pretty good stuff
    it does what it say's on the tin
    Andy
  • Sat, Mar 8 2008 11:28 AM Re: Forte diesel treatment
    austin21
    • Joined on Mon, Aug 14 2006
    • Posts 2,035
    Is this stuff better than millers then?
    I've been using that for a while as it's readably avalible.
    acceleration, its the future! OEM + a few bits.
    Pat's back Wink and heaven sent Chuckle
    Build thread here http://uk-mkivs.net/forums/t/201592.aspx
  • Sat, Mar 8 2008 11:40 AM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    Not the same stuff Greg, it doesn't up the cetane or anything... it cleans all the cack from the fuel system, injectors and decokes everything on the way out including lambda sensors.
  • Sat, Mar 8 2008 11:45 AM Re: Forte diesel treatment
    BoraDave
    Bora Sport 1.9 ASZ 130PS
    • Joined on Tue, May 29 2007
    • Posts 1,206
    How is the Forte used? do you add it to the tank or is it ran like a purge in neat form?
    2002 Bora Sport PD130
    2003 Golf 1.4e - GONE
  • Sat, Mar 8 2008 11:55 AM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    Bang a 400ml bottle in the tank at service time, every 10k - doesn't need anything more.
  • Sat, Mar 8 2008 12:00 PM Re: Forte diesel treatment
    BoraDave
    • Posts 1,206
    tony_danza:
    Cheers.
    Doesn't VW put some sort of engine/fuel cleaner in the system at the Service, I remember being told this when I dropped my mum's polo off a couple of months ago, although that was petrol and I don't remember them mentioning anything like that to me when I dropped the TDI off a month ago
  • Sat, Mar 8 2008 12:13 PM Re: Forte diesel treatment
    austin21
    • Posts 2,035
    Ah ha sounds like I might need to get hold of some of this too.
    Mine has just clocked 60k so could probably do with a bit of a clean.
    Mike
  • Sat, Mar 8 2008 12:24 PM Re: Forte diesel treatment
    tony_danza
    • Posts 2,906
    Could well be the same stuff Dave?.. I've read stuff about a few dealerships using it online.
    Sheesh, maybe I should start working for these people as a sideline Stick out tongue
  • Sat, Mar 8 2008 12:26 PM Re: Forte diesel treatment
    Yohan
    • Joined on Sat, Aug 27 2005
    • Posts 1,760
    Is there a petrol version?
    The 1.6
    "Since light travels faster than sound, people appear bright until you hear them speak."
  • Sat, Mar 8 2008 12:33 PM Re: Forte diesel treatment
    maxitrol
    • Posts 835
    yeah thier is a petrol version of this www.forteuk.co.uk
    Andy
  • Sat, Mar 8 2008 1:54 PM Re: Forte diesel treatment
    kalu
    • Joined on Sat, Apr 21 2007
    • Posts 580
    Forte have set up a scheme with many garages called 'The Good Garage Scheme'.
    All of their agents use Forte products as its part of the scheme so you can get it at any local participant.
    Use the postcode search on their website to find an agent in your area
     http://www.goodgaragescheme.co.uk/service.html
    Need some help? with...Vagcom, Keys/Immobilser adaption/defeat, Ecu/Cluster Swap. Miles to Empty/Illuminated Needles, Autowindows etc... PM me :)
  • Thu, Mar 13 2008 1:23 PM Re: Forte diesel treatment
    Diesel
    • Joined on Sun, Apr 4 2004
    • Posts 784
    Nice one kalu have located a bottle from your link. Chucked the lot into just under 1/2 a tank of diesel.   Im trying anything at the moment as I have the sticking turbo vane problem occasionally & im trying to fettle it my own way.  If it doesnt work its going to be decision time to either part ex the car or go through the hassle of a replacement/refurb turbo.  Hope this helps too!
    Golf 130TDI PD
    Fabia 1.4MPI
  • Thu, Mar 13 2008 5:09 PM Re: Forte diesel treatment
    unitzero
    Bora SE TDI 1.9 ATD 100PS
    • Joined on Thu, Jun 14 2007
    • Posts 845
    i used it in mine and managed to get a few more mpg on my trip to work and it feels less "juddery" if you get me.
  • Thu, Mar 13 2008 5:33 PM Re: Forte diesel treatment
    tdi_gti
    • Joined on Sat, Jan 12 2008
    • Posts 17
    You might wanna consider trying this:
    http://www.innotecworld.com/c-1057-turbo-clean-set.aspx
    ...apparently it has good results and could save turbo replacement/refurbishment depending upon how far it's gone.
  • Thu, Mar 13 2008 6:30 PM Re: Forte diesel treatment
    Diesel
    • Posts 784
    tdi_gti:
