uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
Last post Sun, Sep 13 2009 7:48 PM by bora1. 19 replies.
Page 1 of 1 (20 items)
  • Sun, Mar 9 2008 1:45 PM Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    Woodinator
    Bora SE TDI 1.9 ASZ 130PS
    • Joined on Mon, Feb 5 2007
    • Posts 3,206
    HTML Version (Updated), clicky
    This guide is a mod that has been done by a handful of people. I saw it done on the Golf and didn't think it was fair that there wasn't a guide for the Bora, so, I bought some paint and got going taking plenty of pics along the way.
    I hope this guide is useful to lots of people!
    Tools
    Torx - T10, T20, T30
    Needle nose pliers
    A wide chisel
    Stanley knife
    A tube of SIKAFLEX* (or windscreen sealant)
    Plus your paints and sandpaper.
     *SIKAFLEX can be bought in black, which means that it's not going to stand out, very OEM. Can be bought on eBay for under £10 inc. postage.
    So, first of all, some pics of the standard light units. Nothing drastically wrong with them, but they're nothing special... let's change that shall we?
    So, lets get them out and modified shall we? First of all, 'pop the hood'... or open the bonnet if you're normal.
    The standard grille is just held in with clips, at the top on each side you need to get your finger in behind it and just pull it up and forward to unclip it, then you need to pull it vertically up to pull out two little clips that poke down into the top of the bumper. Same for both sides.
    Now for the centre clip, this is just a case of putting something blunt into the square hole at the top, pushing down relatively hard while pulling the grille towards you.
    The next bit is described as being the most difficult, but it was easy for me as I've had the grille off before and I replaced it with a clip that holds body shells on R/C cars. However, to get the OEM clip off that holds the bonnet release handle on requires some needle nose pliers and quite a lot of bending plastic (it's quite flexible though). The main problem with getting this little pin/clip thing out is that it's quite easy to loose (i lost mine, but luckily it turned up when I took my bumper off after several weeks, it must've found a nice little home on the inside of my bumper!).
    So, all you've got to do is bend each of those plastic 'legs' that are on either side of the metal arm out, and pull them off of the little pin that goes between them and through the metal arm.
    Then you just pull the grille vertically up and out (some clips at the bottom), quite easy to get out so don't use too much force. Should pop out quite nicely.
    And you should be left with you're grille out and on the floor... or maybe not. Try somewhere that it won't get stood on!
    Grilleless! Bumper next...
    The bumper is a doddle to take off. There is a guide for taking the bumper off but while I was at it I thought I'd cover it as well.
    So firstly you need to undo these three screws along where the grille sat. These are T30 Torx screws.
    And theres a T30 Torx at the top of the bumper between where the grille sat and the headlight (one each side)
    And there is one on either side behind the lower side grilles. These grilles come out by pushing down on little tabs and just pulling them out. If you're unsure it tells you how to get it out with diagrams in the handbook; you'll find it in the towing section because the screw hole for you from towing eye is behind the offside grille. Once they're off you can see where the screw is, it's the big dirty one to the top right in the picture below (the offside is shown below, the nearside is a reverse of this; it'll be on the left), these are T30s again.
    While you're in the nearside lower grille, you need to disconnect the outside temp sensor from the bumper. It's shown in the picture below. The metal clip that holds it on has curved ends at the bottom. I've found the easiest way is to use your needle nose pliers on those bits and move each side up a centimetre or two at a time (alternating sides) and it'll come off a charm.
    Now there are only 8 more screws left before the bumper can come off, these are all T20 Torx' and they are inside the front of the arches. They're just holding the arch liner into the ends of the bumper. I've tried to take pictures of them but they're easy enough to see when you do it, just four screws going up from the bottom. You'll need to turn you wheels to full lock to get at them, but you can get by with leaving it on one lock to do both sides (makes it easier if you change the direction for each side, i.e full lock left to do the offside, and full lock right to do the nearside).
    And once you've done that, you can slide the bumper horizontally forward keeping it level and straight. If you have someone hanging around, get a side each as they sometimes need a little thump forward from the wheel arch, but it's quite possible to get off by yourself (and on again, but it's harder as you have to line both sides up).
    And find somewhere suitable to leave your bumper, like a stack of wheels...
    Now to get those lights off. Each light is held on with four T20 Torx screws, two at the top (vertical) and two underneath (horizontal). Below is two pictures of the top ones and one of the bottom ones (all of the offside light).
    After disconnecting the plug at the back, you can take them out, et voilà!
    (the plugs have a little tab on then, if you just put you thumb on this while trying to pull the plug apart, then natural force that you'll put on the tab will release it. DON'T USE ANY TOOLS to try and force the tab, you'll break it like I did once before (twice actually, once on one of my headlights and once on a wiper mech... I've learnt now))
    Both off:
    And out:
    I put the bonnet back down as she would be like this for two nights.
    I connected the bonnet release handle back on because the clip i was using was a lot easier than the OEM on, you might want to bend one section of  a paper clip straight, put it through, then bend it back round again. I think you could reach the metal arm without the grille there so it might not be necessary to put the handle back on, but if you shut your bonnet and can't get it open again without the handle then it's your own fault!
    ****************** SEPARATING THE HEADLIGHTS ********************
    Ok, now for the... err.... fun bit!
    First of all, remove the metal clips that help hold the two halves together
    The easiest way that I found to get the headlights apart was to basically ram a chisel in between the lens and the projection unit.
    Here's a diagram I made to try and explain it (this would be looking through a cross section in case it's not obvious)
    In this picture you can see the glue being stretched with the chisel between the lens and the headlight. When the glue is stretched you need to cut it with a Stanley knife. This is important because this is pretty much the only way that I found to get them apart. Using a hair dryer just makes the glue more sticky, so I wouldn't bother using one.
    And when you have enough space to get your fingers in, get them in there and slowly prise it apart while cutting along the stretched glue with the knife.
    When you get to the final edge, pull it open and cut along the inside of where it's joined (because that's the part that will be stretched), no pic for that part though.
    And there we go, two separate parts! Yay!!! Now don't touch any of the silver bits if you can help it! Finger prints will come out, but they're not as easy as something like glass.
    As you will see, the silver part that will be sprayed is screwed to the lens. This is held to the lens with 4 T10 Torx screws.
    First of all, remove the little light reflector that catches any light trying to escape (you'll want to keep this bit silver). It's just 2 T10 Torx'.
    Now to get the main bit off, the remaining 2 here...
    And another 2 here...
    TA DAA. Now, go forth and spray!
    There is a little lip behind the main silver section at the bottom which will help stop any light being wasted and going into the back of the headlight, so I masked over this part to keep it silver; you can't see this with the headlight assembled so it doesn't matter. I assume that it'll just help with light reflection.
    Here's some pics of the damage that I did to my first headlight when I didn't really know how to best take them apart, I was basically attacking it with a sharp flat blade screw driver and trying to get the glue out. But if you use the method I described you should only have one side bent out a bit. They are quite flexible though and will bend back to pretty much where they were. The only side you don't want to damage is the top because that can be seen with the bonnet up.
    Anyway, you should have your chrome parts sprayed now:
    Now you just need to screw the newly sprayed sections back to the lens, an screw the little reflector back on. Looking good eh?
    And placed against the headlight:
    Now to get them glued back together; there aren't any pictures for this I'm afraid. However, it's simple enough.
    Lay a line of SIKAFLEX (I did about 2mm wide) around the full circumference of the headlight, then just place the lens in and hold it firmly in place while you clip the metal clips back in place; these will hold the two parts together while the sealant drys.
    I then left them on a table near a radiator overnight and fitted them the next day. Ideally it needs nearer 2 or 3 days to fully cure but because the clips are holding the two parts together I didn't wait.
    And with them glued (you can tell I was chuffed as there are plenty of pics!)
    Right then, refitting! This is an exact reversal of removal.
    Plug each light in and there's two screws at the top, and two at the bottom of each light (all four are T20)
    Then, line up and slide the bumper on straight. It usually takes a little thump to seat it in place.
    There's the 4 T20 screws inside the arch liners on each side.
    Now for the T30s, two at the top of the bumper just inside of each headlight,
    Three along underneath where the grille goes,
    One behind where each of the lower side grilles go.
    Now the grille just clips in place, first at the bottom, then on either side at the top, making sure to push the little clips in their slots underneath. Then a final clip in the middle.
    The bonnet pull handle then just clips on with the little pin. This is just a case of trying and trying, you'll get it in there Yes
    Finally clip the lower side grilles in and you're done!
    Now sit back, and enjoy the look of your subtly tinted headlights. They look better from a little distance Cool
    It's not just a car, it's a Volkswagen... Click pic to see her, or my Build Thread
    | Kamei Grille | GTI Recaros | Anni'd Lights | Anni BBS RCs | LCR Brembos | Coils | Full Spec.
    For Sale: Auto-Dim/Rain Sensing Mirror Kit, Bora Front Bumper. PM for info. (Bora 4Mo Rear Valance Wanted)
  • Thu, Mar 13 2008 7:08 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    Woodinator
    • Posts 3,206
    The guide is now all written up, hope it helps plenty Yes
  • Fri, Mar 14 2008 7:29 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    unitzero
    Bora SE TDI 1.9 ATD 100PS
    • Joined on Thu, Jun 14 2007
    • Posts 1,533
    YesGeekedBeer
    Good Stuff !
  • Fri, Mar 14 2008 12:01 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    Y15HAL
    • Joined on Thu, Jun 29 2006
    • Posts 5,478
    Nice one Andy, Excellent Howto! Going to give this a go when the weather improves! Yes
  • Thu, Apr 17 2008 7:11 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    benjie
    • Joined on Sat, Jan 1 2005
    • Posts 4,810
    Here's my 'attempt:'
    Note the colour inside is meant to be indigo blue, but it looks much darker for some reason!
    I also took the opportunity to do this....
    ... NEVER AGAIN!
    B6 A4 130TDI quattro Sport. Re-mapped to a safe 160bhp | 18" RS4's in black/silver | Mk1 TT V6 exhaust tips | RS4 rear ARB | Body coloured bumpers | Interior re-trimmed entirely in black | Un-scratched climate unit! | A3 8P(?) gear stick | Ambient lighting | Dension 100 iPod/Phone link | Pants boot spoiler, but not forking out £200 for a genuine S4 one just yet! | Oh, and it's not a mod, but it's quattro - epic!
  • Thu, Apr 17 2008 7:20 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    j11ajs
    • Joined on Tue, May 18 2004
    • Posts 1,303
    Very nice mod looks much better than standard
    Silver 25th Anniversary No 377 Revo stage 2
    Yellow TT Roadster Oettinger remap
    Avus TT Quattro Sport APR stage 2
  • Fri, Mar 13 2009 7:52 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    VR6Rich
    Bora V6 4motion 2.8 24v 204PS
    • Joined on Tue, Jan 10 2006
    • Posts 2,070
    Just thought i'd add my 2p to this guide to make things a bit easier for other people to do it.
    Instead of trying to prise the lense from the housing and causing damage (as Andy shows Chuckle) you are better of using the oven to separate them, as scary as it sounds its really easy.
    1) First get the oven up to temperature, 160 degrees is more than enough.
    2) Remove the metal clips like Andy said, along with the bulb covers and all the bulbs.  If you can remove the headlight leveling motors (if you have them) then all the better but I didn't when I did mine.
    3) Place the headlight, lense first, into the oven for 60-90 seconds max.  Make sure the lense is not touching anything inside the oven.
    4) Once cooked Chuckle for the 60-90 seconds remove the headlight (will be hot but not enough to warrant oven gloves) and place on a towel.
    5) Next use a paint scraper to get into the fine groove between the lense and housing and gradually work your way around the whole headlight unit you start getting a gap big enough to get some fingers in.  Once you can you should be able to just prise apart the two parts with your hands.
    6) Fit your painted bits and re-attach the lense loosely and fit the metal clips.  I did this without new sealer as I figured the next step should be ok.
    7) Put the headlight back in to the oven for another 60-90 seconds to melt the lense glue again and remove from the oven.
    8) Lastly just give the lense/housing a good press together.
    Doing this way you dont damage the housings on the lights and retain the original lense glue/sealant.  Had mine on a week and had no issues so far.
    Another tip is to take the opportunity to clean the inside of the lense as mine had some water marks, etc so needed a good clean.
    Hope this helps.
  • Fri, Mar 13 2009 2:55 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    tomxt99
    • Joined on Fri, Dec 14 2007
    • Posts 1,106
     Nice one Rich, was planning on doing this this weekend now mine is back on standard headlights.
    Dont suppose you have any pictures do you?
    Tom
  • Fri, Mar 13 2009 4:23 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    VR6Rich
    • Posts 2,070
    You can see them in this photo
  • Fri, Mar 13 2009 4:42 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    tomxt99
    • Posts 1,106
     Looks good, are they gloss black or matt black?
    Ive got black mirrors and Im spraying my grille gloss black aswell as the lower bumper grills so was going to do the headlights the same.
    Tom
  • Fri, Mar 13 2009 4:53 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    VR6Rich
    • Posts 2,070
    I did them LC9Z metallic black as the mirrors and grill were already that colour Yes
  • Fri, Mar 13 2009 5:02 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    tomxt99
    • Posts 1,106
     Brilliant cheers for that, my mirrors are just VW Black so Im matching them to that.
    Your car looked good at UD aswell Yes
    Tom
  • Fri, Mar 13 2009 5:19 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    sharpey99
    Golf V GTI 2.0 200PS
    • Joined on Thu, Jul 10 2008
    • Posts 652
     i think il be having a go at this some time soon
  • Tue, May 5 2009 5:01 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    m11vny
    Other Models
    • Joined on Fri, Nov 26 2004
    • Posts 42
    Looks very nice, great write up. I've used the oven method for my MK3 head lights and think this is easiest but be careful not to put any pressure on the plastic parts as they will bend Tongue Tied
    I'm going to attempt this and will post some pics once done. Am considering modifying to hold Projectors in the lights for HID conversion.
    MK3 VR6 Highline
  • Tue, May 5 2009 5:17 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    tomxt99
    • Posts 1,106
     Did mine a few weeks back so not to miss a chance to whore some pics:
    Tom
  • Tue, May 5 2009 5:31 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    ajb100
    • Joined on Mon, Jan 8 2007
    • Posts 4,522
     top guide Yes
    to big see forum rules *ahem* too
  • Tue, May 5 2009 5:41 AM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    olethalb
    Bora SE 2.0 8v APK 115PS
    • Joined on Fri, Feb 6 2009
    • Posts 2,762
     few pics of mine and my recent custom job that i don't like.
    http://uk-mkivs.net/forums/t/268950.aspx
  • Sun, Sep 13 2009 3:12 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    mohsin
    Bora Sport 1.9 AJM 115PS
    • Joined on Wed, Jan 7 2009
    • Posts 299
     i have some chrome angel eye headlights, my question is that is it possible to spray the whole of the inside of the headlight black( apart from the projecter lense etc) so it looks like this:
    and can i use matt black?
    Build Thread: http://uk-mkivs.net/forums/t/298277.aspx
    VW Bora Sport 115 TDi
    Lowered 35mm - V6 front splitter - New 4motion Alloys - Debadged - Kamei Grill - Black Angel Eye Headlights - Red Calipers
    Soon to come - Dragon tuning module, v6 rear splitter, and new bulbs!
  • Sun, Sep 13 2009 5:57 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    Woodinator
    • Posts 3,206
    You can spray whatever bits you want mate.
    But if you actually look at the photos of the headlight, you'll see that the majority of the light is taken up with the reflector (which would be stupid to paint, but interesting to see the outcome!)
    The only additional parts you could paint is the part around the indicator/fog lights, and the outside-top corner of each light.
    HTH
  • Sun, Sep 13 2009 7:48 PM Re: Bora Anni Headlights (Joey Mod) - Complete (61 Pics)
    bora1
    • Joined on Sat, Sep 6 2008
    • Posts 193
    well explained, will give it a try when i get round to it!
