Custom-Code - The Latest Innovation in Serial Port Chip Tuning Technology. Remap VW - Audi - Seat - Skoda
uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - Engine and Exhaust » mk5 tdi 140 turbo whistle?
Last post 08/07/2008 6:53 PM by vw kid. 10 replies.
Page 1 of 1 (11 items)
  • 21/03/2008 3:30 PM mk5 tdi 140 turbo whistle?
    M11CGY
    • Joined on 26/11/2007
    • Posts 15
    hi i have just recently (today) bought a 2005 2ltr gt tdi 140, and noticed a turbo whistle, i had a 2000 1.9 mk4 gttdi 130 before this and the noise is totally different , with the 130 it was more of a hissing noise but with the 140 its a hiss and and a whistle just wondering if this is normal i can hear it inside the car and louder with the window down should i take it back?????
    is it the turbo?????
    i will be thankful for any help
  • 21/03/2008 4:09 PM Re: mk5 tdi 140 turbo whistle?
    Rustynuts
    • Joined on 29/05/2005
    • Posts 1,011
     Have a look here, see if that answers your questions.
  • 22/03/2008 9:38 AM Re: mk5 tdi 140 turbo whistle?
    M11CGY
    • Posts 15
    thanks rusty i was just a bit concerned but now feeling a little better Big Smile
    thanks
  • 10/04/2008 6:11 PM Re: mk5 tdi 140 turbo whistle?
    M11CGY
    • Posts 15
    whilst driving the car lost all power on the motorway (limp mode) just had the car on a diagnostic machine and came up with fault code p0234 (overboost) either caused by turbo vacuum pipes or the turbo wastegate ...
    i had all pipes checked and came back with the wastegate is sticking causing the turbo to overboost, which i was told by the mechanic has caused the whistle on the turbo having new turbo and wastegate fitted now they gave me a courtesy car which is a gt tdi 140 which has no turbo whistle and a hell of alot more power!
    so things look good
    will let you all know how i get on
  • 13/04/2008 11:20 AM Re: mk5 tdi 140 turbo whistle?
    mickymunn
    • Joined on 22/11/2007
    • Posts 18
    I get the "owling" noise from mine and had it in vw but they say its normal, Im not clued up on cars at all, can only drive them( well some say my driing is terribe ) Indifferent. So am i right in thinking its nothing to worry about? Car seems to drive fine
  • 13/04/2008 3:15 PM Re: mk5 tdi 140 turbo whistle?
    M11CGY
    • Posts 15
    had new turbo and wastegate on now for a couple of days just been bedding it in for 150 miles..
    gave it some before and i cant believe the difference no whistle and a hell of alot more power, if you have this problem then i would get the fault memory read and if it says p0234 then its a deffo turbo/wastegate problem....
  • 13/04/2008 4:47 PM Re: mk5 tdi 140 turbo whistle?
    Rustynuts
    • Posts 1,011
     Actually, there isn't a wastegate on your turbo, it has a variable vane system instead. But they both control boost, just in a different fashion.
  • 14/04/2008 4:05 AM Re: mk5 tdi 140 turbo whistle?
    damianmkv
    Golf V S 2.0 SDI 75PS
    • Joined on 28/04/2005
    • Posts 6,673
    mickymunn:
    its a "feature" of some cars, definately. I've had it from new on my car ( now at 50k ) and even had a new turbo and still have it.
    PS - my car makes 191 bhp so its certainly not causing any performance problems
  • 16/04/2008 12:32 PM Re: mk5 tdi 140 turbo whistle?
    M11CGY
    • Posts 15
    hi rusty...
    my turbo had a wastegate actuator on the side when they removed it because they showed it me ?????
    anyway happy with car now noise gone , no limp mode , and more power (we like)
    thanks everyone
  • 16/04/2008 12:43 PM Re: mk5 tdi 140 turbo whistle?
    Rustynuts
    • Posts 1,011
    M11CGY:
    hi rusty...
    Did they tell you it was a wastegate actuator? Because it's actually a Variable Nozzle Turbine (VNT) actuator.
    Basically, a wastegated turbo makes full boost all the time (at least when it can) and when the boost reaches the ecu's maximum for the revs  etc. the wastgate opens and dumps the excess boost. A VNT turbo uses variable geometry inside the turbo to only make as much boost as the ecu requires, and as such doesn't need to dump any excess. The benefit is that a VNT makes boost lower down the rev range and then adjusts to keep the maximum boost right up through the rev range. A wastegated turbo will generally make boost further up the rev range but not lower down.
    To simplify: - A wastegate turbo makes lots of boost and only uses some of it while a VNT turbo makes just enough boost and uses all of it.
    But it's a pedantic point I'm making I suppose. Yes
  • 08/07/2008 6:53 PM Re: mk5 tdi 140 turbo whistle?
    vw kid
    • Joined on 31/12/2005
    • Posts 42
     Just bought my MK5 GT TDI 140 yesterday and it has a mental whistle not the norm but it drives as quick as all the others I have driven and is returning the correct mpg?? I'm concerned but it drives spot on performance etc etc. It does give me a judder through the seat on tick over sometimes does anyone have any idea's??
