uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » Replacing LED Alarm Cap
Last post Fri, Sep 5 2008 4:00 AM by 20vturbz. 12 replies.
Page 1 of 1 (13 items)
  • Fri, Mar 28 2008 4:29 AM Replacing LED Alarm Cap
    markmark4
    Golf IV TDI 1.9 AGR 90PS
    • Joined on Sun, Jun 3 2007
    • Posts 355
    For this operation, you will need:
    1x car
    1xPhillips screwdriver
    1x Flatblade Screwdriver
    1xT20 torx driver
    1x Replacement LED Cap - (Bright blue and white versions available from me!!!)
    And you may need an assistant.
    Step one:
    Find car, unlock and open door
    Step two:
    Gently push the flatblade screwdriver upwards, from underneath the door handle and then lever it away from you.This should now be free and fall off.
    Step three:
    The handle with switches will now, with a slight bit of force, pull up and off
    Step four:
    Unclip the connector and put the handle somewhere safe, but not so safe you loose it!!
    Step Five:
    Locate the 3 brassy colours philips headed screws, and using the corrosponding screwdriver, undo and remove screws.
    Step six:
    Locate the black headed philips headed screw at the top left of the door card, next to the wing mirror. Undo and remove screw.
    Step seven:
    With the T20 torx driver, you can now locate the 3 t20 torx screws at the bottom of the door card, undo and remove these screws.
    Step eight:
    With all the screw out  the door card will now just pull off. Do this with force and at the same time care. there are popper type fixings on the left and right side that will "pop" off and release it.
    on the top of the card it is cliped into corroponding clips across the length of the door window. Lift the whole door card up slowly to release it from the door frame.
    Using your assistant or not support the door card.
    Step nine:
    Unplug the Led door cap connector, and with your fingers gently push in the two clips securing the cap to the door card, and then push it out.
    Step eleven:
    Install New Led cap and plug in.
    Step twelve:
    Reverse steps 2-8 to re fit the door card.
    Step thirteen:
    Stand back and admire your hard work with a brew!
    Small print:
    The author accept no responsibility for any damage caused while carrying out this operation.
    Colours may vary from guide to your actual car.
    Credit to vwvortex for the last image as my camera battery went flat
    For a blue or white LED cap PM me and I will sell you one or more!
    Coloured LED Caps
    Keep Working - Those on benefits depend on you!
  • Fri, Mar 28 2008 5:45 AM Re: Replacing LED Alarm Cap
    boranik
    • Joined on Thu, Mar 13 2008
    • Posts 5,363
    Can you fit these on the passenger door lock too? How much are you asking for a blue cap?
    NIK Yes
    WANTED 4X MONTREAL 2 (MONTY2) WHEELS PM ME
    Link to DFT laws on illegal HID conversions CLICKY CLICKY CLICKY
  • Mon, Aug 25 2008 3:27 PM Re: Replacing LED Alarm Cap
    bonny
    • Joined on Sat, Jul 26 2008
    • Posts 270
    boranik:
    That's what i want to know! Can you fit these on the passenger side??
    The more you pay The faster you go.....
  • Mon, Aug 25 2008 3:32 PM Re: Replacing LED Alarm Cap
    golfgt150
    • Joined on Sun, Jul 6 2008
    • Posts 181
    wow that is one long process i can do that in about 5 minutes !!!
  • Mon, Aug 25 2008 3:41 PM Re: Replacing LED Alarm Cap
    markmark4
    • Posts 355
    yes these can be fitte to the pssenger side aswell, though you will need to run a 2 core cable from the drivers door through the dash into the passenger door for it.
    HTH
    Coloured LED Caps
  • Mon, Aug 25 2008 3:53 PM Re: Replacing LED Alarm Cap
    bonny
    • Posts 270
    Will that be a 2 core cable from the drivers LED alarm plug?
  • Mon, Aug 25 2008 4:00 PM Re: Replacing LED Alarm Cap
    markmark4
    • Posts 355
    yes thats it, just connect it in parrellel to the existing one.
    Coloured LED Caps
  • Mon, Aug 25 2008 4:08 PM Re: Replacing LED Alarm Cap
    bonny
    • Posts 270
     Cheers Mark Yes
  • Mon, Aug 25 2008 4:48 PM Re: Replacing LED Alarm Cap
    • Joined on Mon, Apr 9 2007
    • Posts 13,099
     Did this very job the other day,to me 45mins to do both sidesYes B&Q Doorbell wireYes
    R-Tech Powered
    Sad people complain about sigs,get a life.
  • Mon, Aug 25 2008 5:53 PM Re: Replacing LED Alarm Cap
    StevenW007
    • Joined on Sat, Feb 18 2006
    • Posts 417
    You got any pics of how/where you ran the wire from the drivers side to the passengers at all Patch?
    Ste
  • Mon, Aug 25 2008 6:03 PM Re: Replacing LED Alarm Cap
    nimz
    • Joined on Fri, Aug 17 2007
    • Posts 5
     got any picture of the fitted LED's?
  • Tue, Aug 26 2008 3:31 PM Re: Replacing LED Alarm Cap
    • Posts 13,099
    StevenW007:
    Ste
    No pics,but i ran up the pillar,along the roof lining and back down to the other door.The hardest part is feeding the wire from the door into the car.
    Took a little vid of them flashing,it's poor though
    http://s192.photobucket.com/albums/z215/Patch27/VW%20Festival/?action=view&current=DSCI0063.flv
    R-Tech Powered
  • Fri, Sep 5 2008 4:00 AM Re: Replacing LED Alarm Cap
    20vturbz
    • Joined on Fri, Apr 4 2008
    • Posts 434
    Why didn't i think of that. I just cut the wires off my original and soldered the new one on. lol
    Factory Spec: Electronic Climate Control, Electric Sunroof, Heated Leather Recaro's. Mods: KO3s, Red Dot Custom Map, CAI, Forge 007p DV, FMIC, Torque Exhaust De-Cat, Vortex, & Hidden Pipes, Lenso Spark Plugs, N75K Valve, G60 Fly/VR6 Clutch, Anniversary Kit + R32 Front, FK Coilies, TT Brakes, Eibach ARB's, Polybushes, Brora vents + Sport Clocks... The List Goes On! Up For Sale Very Soon
