Hi all, friday just gone, was driving to work and my cooling light came on and beeping etc, i looked at the gauge and the temp was just below max 130 degrees, so i pulled over about a mile later looked under the bonnet and everything looked fine. Started the car and the temp was at 90 degrees again strange, drove about a mile again and it went all the way up to max again.
So thinking it was the thermostat i replaced that and also noticed the fan wasnt coming on so i tested it by bridging the connections so it was on full and then drove for about 15 minutes last night and the light came on again.
So i was thinking why isnt the fan coming on and i checked the pipe that comes from after the termostat to the bottom of the radiator and it was cold, strange?? I have tested both my old thermostat and new thermostat in a pot of boiling water and they do open.
So the next thing i have tried is to remove the thermostat completely and now that pipe is hot but the fan still isnt coming on, so i guess i do need to replace that sensor but im not sure if it was the waterpump,
I would of thought that if the waterpump wasnt working then the water wouldnt be getting to the radiator even without the thermostat?
Any help would be great
