Chipped UK - Where performance counts and dreams come true
Break Bleeding.......help
Last post 19/05/2008 8:16 PM by Gti Fly. 13 replies.
Page 1 of 1 (14 items)
  • 11/05/2008 5:37 PM Break Bleeding.......help
    blackmk4
    • Joined on 28/02/2008
    • Posts 18
    hi all,
    i no this is a stupid question, but how do i bleed my breeks. does anyone have know of a good 'how to' that i can look at.
    thanks
    ryan
  • 11/05/2008 6:02 PM Re: Break Bleeding.......help
    Sprog
    • Joined on 04/10/2005
    • Posts 921
    Gunson Eezibleed is what I use - makes the job so much simpler.
    Doing it old school is a bit trickier - there is sequence to do them in. And you need a mate to help you. but i can explain the process if need be....
  • 12/05/2008 4:48 PM Re: Break Bleeding.......help
    blackmk4
    • Posts 18
    thanks, i ordered mine to day, but do i need to do any thing to the master thing.
  • 12/05/2008 5:23 PM Re: Break Bleeding.......help
    Sprog
    • Posts 921
    The eazibleed thing screws onto the top of the resevoir and pushes the fluid through. Pay VERY close attention to the level of fluid - you can't get air in the lines!!
  • 13/05/2008 8:09 AM Re: Break Bleeding.......help
    blackmk4
    • Posts 18
    What is the order that i should bleed my breaks?
  • 16/05/2008 4:56 AM Re: Break Bleeding.......help
    Sprog
    • Posts 921
     Bleeding sequence
    1. Rear right
    2. Rear left
    3. Front right
    4. Front left
    Says it the fluid pressure unit should be no more than 1 bar. So if you're using an eezibleed and a tyre - make sure its no higher than 14.5psi
    Yes
  • 16/05/2008 7:19 AM Re: Break Bleeding.......help
    goody_gti
    • Joined on 17/03/2007
    • Posts 2,229
    Sprog:
     Bleeding sequence
    1. Rear right
    2. Rear left
    3. Front right
    4. Front left
    Yes
    Good bit of advice that... Yes
  • 19/05/2008 7:40 AM Re: Break Bleeding.......help
    cliff_tdi130
    • Joined on 13/02/2007
    • Posts 139
    ez-bleed rocks, can bleed an entire system in 20mins
  • 19/05/2008 8:01 AM Re: Break Bleeding.......help
    veedubdude
    • Joined on 01/05/2006
    • Posts 1,477
    On the MK4 golf, you need to use vag-com to get air out of the master cylinder and/or the ABS pump after a brake fluid change. Do not attempt to pump the brake pedal like on other cars, as you will bugger the seals in the master cylinder! Always use a pressure bleeding kit like you have bought Smile
  • 19/05/2008 12:39 PM Re: Break Bleeding.......help
    Sprog
    • Posts 921
    If you're doing a simple fluid change (without dropping the previous fluid); air shouldn't even get into the master cylinder/abs pump because you are just pushing new fluid through over the top. But yeah - good call veedubdude.
  • 19/05/2008 1:52 PM Re: Break Bleeding.......help
    Gti Fly
    Golf IV Estate E SDI 1.9 AQM 68PS
    • Joined on 11/09/2002
    • Posts 4,299
    Sprog:
     Bleeding sequence
    1. Rear right
    2. Rear left
    3. Front right
    4. Front left
    Yes
    It's supposed to be furthest from master cylinder first, so really it should be
    1)  Rear Passenger side
    2) Rear Driver side
    3) Front Passenger side
    4) Front Driver side
  • 19/05/2008 1:58 PM Re: Break Bleeding.......help
    goody_gti
    • Posts 2,229
    veedubdude:
    I do hope that doesn't happen 100% of the time as we were doing this to mine yesterday Tongue Tied
  • 19/05/2008 4:52 PM Re: Break Bleeding.......help
    Sprog
    • Posts 921
    In my defence - my sequence was copied fromk the ElsaWin Workshop Manual.
    Guess it depends which way you look at the car. The sequences tie together if you look from the front LOL - but that would be a bit retarded. But then again most of the mechanics at the dealers are!
  • 19/05/2008 8:16 PM Re: Break Bleeding.......help
    Gti Fly
    • Posts 4,299
    Sprog:
    My guess is that ElsaWin is written for cars in LHD format (ie most of the world!), as the master cylinder would be on the other side to our RHD cars.   :)
