uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Suspension, Brakes and Chassis » Top mount Bushes - FIXED
Last post 22/07/2008 5:35 PM by R23. 21 replies.
Page 1 of 1 (22 items)
  • 22/05/2008 7:38 AM Top mount Bushes - FIXED
    cliff_tdi130
    • Joined on 13/02/2007
    • Posts 142
    when the strut is assembled with a new bush with the strut off the car...should there be any play in the bush with respect to the the spring plate?
    I have replaced the bushes and there was abit of play, so if this isnt normal, does anyone know why this is ?
  • 22/05/2008 8:03 AM Re: Top mount Bushes
    haf1zur
    Golf IV R32 3.2 240PS
    • Joined on 03/08/2005
    • Posts 3,775
     as long as you torque it to the right specs, then you should be ok
    i dont think i had any play in it till after they got bedded in, even then it just turns rather than move about
    hafizur
  • 22/05/2008 8:13 AM Re: Top mount Bushes
    Red Eye
    Bora Sport 1.9 ASZ 130PS
    • Joined on 11/03/2004
    • Posts 90
     Hi mate, do you have the part numbers for the bushes & bearing, going to replace mine when I change the shocks.
    Cheers.
  • 22/05/2008 12:33 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    I got mine from GSF (just asked in there).  I think I am going to take it apart again at the weekend and double check.  If its not that then its my wishbone bushes.
    My steering is abit flappy and vaugue at the moment
    I hate suspension problems
  • 22/05/2008 1:02 PM Re: Top mount Bushes
    haf1zur
    • Posts 3,775
     check this thread out
    http://uk-mkivs.net/forums/t/160597.aspx
    all mounts are the same i believe
    hafizur
  • 22/05/2008 4:41 PM Re: Top mount Bushes
    haf1zur
    • Posts 3,775
     sorry, wrong thread, hold on
  • 22/05/2008 5:55 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    I assume 21 is the nut although its called a threaded bush ??
    There was no 28 when I took it apart, do I need this, I am confused ??
    Apart from that I put it all back together as the order in the above diagram
    Just checked ETKA myself and for the ASZ engine (130TDI) which mine is that is the right diagram.  So where the hell is that spacer and why don't I have it?
  • 22/05/2008 6:36 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    my suspicions are the spacer got stuck to the bearing and I threw it out when I changed the bearings.  I have just check Noah's suspension guide and have seen a pic of the spacer and I am missing it.
    So it looks like I will be ordering a pair from VW tomorrow, hopefully pick them up friday and then fix it over the weekend.
    I do hate it when these things happen.
    cheers guys for your help, I'll let you know how I get on
  • 23/05/2008 12:20 AM Re: Top mount Bushes
    haf1zur
    • Posts 3,775
     from what i noticed, 28 is not needed unless you got an R32, its a spacer.
    18, 14 and 21 should be the ones you need to replace, along with 17 just to be on the safe side
    hafizur
  • 23/05/2008 2:30 AM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    well if the spacer was there originally and I had no problems and now its not there and I have problems then surely the problem points to this spacer ?.
    I shall check with the stealers to see what they say.
    I replaced 18  and 14 but I never replaced 21,  this nut seemed fine to me, should this have been replaced.
  • 23/05/2008 2:33 AM Re: Top mount Bushes
    haf1zur
    • Posts 3,775
    cliff_tdi130:
    etka clearly states the spacer is for an R32 only, unless your car is in disguise?
  • 23/05/2008 5:53 AM Re: Top mount Bushes
    AJ68
    • Joined on 11/08/2006
    • Posts 222
     Hi
    Just to clarify, i recently changed my suspension along with the top mounts and bearings and i never had a spacer in the old or new kit and iv'e not had any problems
    I have the asz too
       Andy
  • 23/05/2008 6:01 AM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    just been to the stealers and guy there reckons there is supposed to be play in the between the bush and the spring plate when the strut is off the car.
    He also comfirmed what the the above comments that the spacer is not needed, it will just raise the suspension up a few mm.
    So its back to square one, maybe the wishbone bushes are indeed nackered, though its abit of a coincedence that I took the strut apart and now there I get this problem.
  • 27/05/2008 7:41 AM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    Ok replaced (passenger side ) wishbone, got the other side to do, will report back once its done.  Still getting some brake judder at high speed hard breaking.
  • 30/05/2008 3:41 PM Re: Top mount Bushes
    red-jeffers
    • Joined on 05/05/2005
    • Posts 908
     I have got a 10-15mm gap between the limt stop and the chassis leg is this normal, sorry for the hi-jack but i never noticed this gap before on the standard suspension
  • 30/05/2008 6:42 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    red-jeffers:
    I actually put another post up asking the same thing, and according to the guys here its normal.  Mine has a gap too.
  • 31/05/2008 2:15 PM Re: Top mount Bushes
    red-jeffers
    • Posts 908
     Well i have just taken my limit stops off and both the top mounts have split all the way round and i have noticed that when turning the wheel side to side the thread sticking out the top moves around
  • 31/05/2008 6:16 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    New top mounts then methinks
  • 31/05/2008 6:18 PM Re: Top mount Bushes
    cliff_tdi130
    • Posts 142
    Just completed the replacement of both wishbones.  Steering and suspension is much tigher and smoother, big difference.  The old bushes were shot.  I also replaced the ARB drop links.
    However I am still getting judder in the steering when braking, however its not happening all the time so its not warped dics.
  • 05/06/2008 11:35 AM Re: Top mount Bushes - UPDATE
    cliff_tdi130
    • Posts 142
    Update
    Just picked up a new set of VW bushes from the stealers and they are different (only slightly) to the GSF bushes I put on a few weeks back.  With the GSF bushes the bearing didnt seem to sit 100% snug but I thought at the time this is normal.  With the VW bushes and bearings they sit properly.
    So it means taking it all apart again to swap over the top mounts and bearings
  • 06/06/2008 4:05 PM Re: Top mount Bushes - UPDATE
    cliff_tdi130
    • Posts 142
    Fixed
    Replaced the GSF top mounts and bearings with VW stuff, took me 3hrs in total to do both sides.  Took it for a test drive and its much much better, not wobbly handling or juddering braking.
  • 22/07/2008 5:35 PM Re: Top mount Bushes - FIXED
    R23
    • Joined on 21/08/2007
    • Posts 606
     I have now realised that I have this 10mm ish gap at the top of my strust now. I put the spacer back in as it was in the original kit (L20 spec std suspension) thinking that the bearing needed it to work on.
    Looking carefully at the set up now though it would appear that when the car is jacked up the top plate inside the engine bay rests nicely on the top of the boidywork but is proud by 10mm when the car is lowered - me thinks thereofre that this spacer REALLY should come off as otherwiset the suspension is lose, although never going to fall out. Think I could hear it rattly about a bit over bumps today so I will be taking the spacer out asap.
