Hampshires Premier VAG Servicing, Diagnostic and Tuning Centre
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Engine, Turbo and Exhaust » water pump
water pump
Last post Sun, Aug 13 2006 10:51 AM by cmgreen. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Apr 28 2005 1:07 PM water pump
    snafu
    • Joined on Thu, Sep 26 2002
    • Posts 44
    Hello all. Could anyone tell me if the water pump with the metal impeller is a genuine vw part or an aftermarket part.
    If it is genuine, does anyone know what the part number is.
    I'm having the cambelt changed and i believe it is wise to do the water pump at the same time. My car has done 21000 miles and is 5 years old so not sure if replacing the water pump is over the top. Any thoughts?
    Thanks.
  • Thu, Apr 28 2005 3:56 PM Re: water pump
    v6rkc
    • Joined on Sun, Jun 6 2004
    • Posts 196
    Hi mate, i'm pretty certain that the w/pumps with metal impellors are an aftermarket item, i'm sure somebody will correct me if im wrong.  Changing the waterpump is a very wise move, given the reliability of them.
    2006 RACE BLUE OCTAVIA VRS
  • Fri, Apr 29 2005 12:45 PM Re: water pump
    Rsteel
    • Joined on Sun, Dec 5 2004
    • Posts 37
    nope its deffo an aftermarket part but well worth it,
    i changed mine when i did my cam belt, good job as most of it was missing :S
  • Fri, Apr 29 2005 3:22 PM Re: water pump
    snafu
    • Posts 44
    Ok, thanks for your replies.
    I will get it done!
  • Sat, Apr 30 2005 5:36 AM Re: water pump
    bobseptic
    • Joined on Wed, Jun 23 2004
    • Posts 827
    any ideas where to get this part. Im due a timing belt in 3000 and it seems it is wise to get pump changed.
    ta
    Satin Silver GTTDI
  • Sun, May 1 2005 11:46 AM Re: water pump
    Rsteel
    • Posts 37
    I got mine from GSF - http://www.gsfcarparts.com/ i think it was £28 +vat from memory
  • Sun, May 1 2005 12:30 PM Re: water pump
    Gary Cundliffe
    • Joined on Mon, Dec 1 2003
    • Posts 2,334
    check your parts dept i've a sneaky feeling the part was modified because the plastic impeller was a silly idea!
    21k in five years-well low miles!
    I've nowt to drive. Oh great!
  • Wed, May 4 2005 6:10 AM Re: water pump
    tylerama
    • Joined on Thu, Feb 19 2004
    • Posts 7,999
    I'm not sure i'd be doing mine if it's only done 21000 miles. I think vw recommend 80,000 though most on here have done there's around the 60,000 mark. That's when I did mine. Seems silly to do it if it's only done just over a third of when most do theirs !
    Def. do the water pump and belt tensioner at the same time though, if you do. Smile [:)]Big Smile [:D]
    Tylerama is well wikkid, innit ! - Sloganizer.net
    VAG spottin in West London..
  • Sat, May 7 2005 4:51 AM Re: water pump
    snafu
    • Posts 44
    Thanks for your replies. Just an update. Couldn't confirm from the dealers that the genuine VW water pump has a metal impellor, but they did say the part number for this item has recently changed. Anyway got them to change it with the cam belt and a few other items (tensioner,damper etc) stressing i wanted the latest water pump fitted and not old stock. Also asked them to leave all the old bits in the boot, which they did. Close inspection of the old water pump showed a crack starting to appear! Only minor at the moment but wouldn't like to say how long it would of lasted. Quite surprised really because if the pump cost more than £25, because of the low miles i probably would not of had it done!
    Cheers,
    Ian.
  • Sun, May 15 2005 6:15 AM Re: water pump
    Carlos Moderator
    • Joined on Tue, May 6 2003
    • Posts 4,340
    I got my waterpump and cambelt done at 80k for about £250
  • Sat, Aug 12 2006 1:43 PM Re: water pump
    zerouk
    • Joined on Tue, Jul 18 2006
    • Posts 8
    the genuive pumps my stealer had in stock were plastic so i got a metal from gsf for 25quid.
    when my mechanictook the plastic original off and put it on the floor it fell to bits :(
  • Sat, Aug 12 2006 1:59 PM Re: water pump
    Dsgwagen
    Golf V GT Sport TDI 2.0 140PS
    • Joined on Thu, Jun 30 2005
    • Posts 1,005
    I haven't seen a genuine one with metal yet.
  • Sun, Aug 13 2006 7:13 AM Re: water pump
    Jammy B
    • Joined on Sun, Feb 12 2006
    • Posts 3,045
    Dsgwagen:
    mines a genuine one with metal impellor.
    they showed me the two parts to my old impellor, thats correct, it had shattered!
    jammy
  • Sun, Aug 13 2006 10:51 AM Re: water pump
    cmgreen
    • Joined on Sat, Oct 23 2004
    • Posts 507
    All Water pumps from dealers should be metal, I got quoted £17 plus Vat Plus a £30 surcharge.
    'I can accept failure, but I can't accept not trying'
