Seems a bit of a grey area to me or am I missing the point somewhere
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
Is it road legal then to drive a car with aftermarket Xenons (without washers and a self levellling system) ?
Quote :
"Anyway some of what was said by the DfT:
"Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which would cause a vehicle to fail to comply with the construction and use standards. A headlamp which has been approved to European Regulations for use with a HID light source is fine, provided the installation criteria are met. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some cars have "self-levelling suspension" and that is adequate). These items are not checked at the MoT. However, failure to comply may lead to enforcement action by the police and may invalidate your insurance. Also the dipped beam must stay on with the main beam. The headlamp must be maintained in good working order, kept clean and aligned/adjusted correctly like any other headlamp. "
http://www.theminiforum.co.uk/forums/index.php?showtopic=58740
http://www.honestjohn.co.uk/forum/post/index.htm?t=57768
