Awesome GTI Store
uk-mkivs » Technical Community » Diesel Discussion » Using veg oil as fuel...
Last post 21/06/2008 2:46 AM by p-mwrx. 22 replies.
Page 1 of 1 (23 items)
  • 06/06/2008 6:50 PM Using veg oil as fuel...
    benjie
    • Joined on 01/01/2005
    • Posts 3,830
    (Non-PD engines only!)
    I've been reading lots of posts here, on other forums and on various info/business websites about using cooking oil as a form of fuel.  From what is said, most seem to run on a mix of 60% cooking oil (SVO) and 40% diesel in the summer months, then put the concentration of SVO right down/cut it out in winter.  There appears to be little side effects apart from smelling like a chippy and possible diesel pump wear (in the cold I expect).
    My question is, does anyone else personally use this fuel and what experience have they had with it?  I am (& mu housemate - MkIII TDI - is) seriously considering this in my non-pd MkIV as a viable alternative to £130/L+ at the pump.  I'd appreciate any advice etc. from any others who have any experiences!
    May even try it as early as next week!
  • 06/06/2008 9:35 PM Re: Using veg oil as fuel...
    davo01
    • Joined on 02/06/2007
    • Posts 429
     i personally do this on my mk3 sdi
    ive had it since jan and done 12000 miles nearly and have ran it since i had it
    at the start i was runnin 50/50 but at the moment due to weather and fuel prices im run 70%veg/30%derv
    some times in very cold weather i had to let the glow plug light go out twice but par that nothing.
    get same non existin performance,lol and same mpg
    hope this helps
  • 07/06/2008 11:52 AM Re: Using veg oil as fuel...
    Collie
    • Joined on 30/11/2006
    • Posts 251
     what about making it from waste veg oil, i have been looking at doing this.
    it doesnt appear too hard
  • 07/06/2008 12:08 PM Re: Using veg oil as fuel...
    v2brett
    Golf V GTI 2.0 200PS
    • Joined on 09/04/2007
    • Posts 475
    im running a 60% oil/ 40% derv mix in my 106 and it goes fine,and as said the only downside is the smell lol    places are realising now though and putting the price of new oil up.  it was 1.04 a litre last week in the super market
  • 07/06/2008 12:11 PM Re: Using veg oil as fuel...
    Mav18t
    • Joined on 16/07/2006
    • Posts 1,009
     I know that certain fuel pumps on the 306 didn't like it. The ones which self lubricate,
    I'm not sure on the golfs.
  • 07/06/2008 3:07 PM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    Collie:
    There's a rather intense filtration process involved here isn't there?
    As for pumps - It's Lucas(?) pumps in Peugeots that don't like it, not the Bosch in VW's I think.
  • 07/06/2008 3:12 PM Re: Using veg oil as fuel...
    Minor_Op
    • Joined on 17/04/2008
    Try this link: http://www.etruk.com/index.php
    All you need to start converting chipfat to biodiesal, an my understanding is that VW diesels will run on 100%. Thats 11p a litre.
    Only problem is that chippys are getting wise to it and starting to sell their fat and My Golf is  a V5!
  • 07/06/2008 4:33 PM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    I'm not on about making/using biodiesel, I'm literally talking about putting cooking oil straight into the fuel tank as a 60/40 mix with regular diesel.  They're 2 different things, though from similar beginnings.
  • 08/06/2008 10:16 AM Re: Using veg oil as fuel...
    Collie
    • Posts 251
     how much is the oil near you? best i found was a quid a litre
  • 08/06/2008 10:51 AM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    Yes, me too, but miffed about that.  Seems the supermarkets have cottoned on.  About 6months ago, my mate was buying it for £8 for 15L, now it's nearly doubled!  However, assume you're doing a 60(oil)/40(diesel) mix, you still save money.
    Take diesel at 1.25L and the MkIV tank is 50L.  so 1.25x50 = £62.50 a tank of diesel.
    60/40 would be a bit cheaper -
    diesel = 20L x 1.25 = £25
    oil =       30L x 1      = £30
    Which is collectively   £55.  So you save £7.50 on a tank if using 60/40.
    I only looked in Tesco though, not sure how much cooking oil would be in big wholesale places such as Costco?  I know someone who goes there regularly though, so will ask.  Asda/Morrissons are generally cheaper than Tesco too, so they may be worth a go.  I still think it's worth it, I'll save £15 a month.
    There is the option of getting used oil from somewhere, but I'm not sure about the filtration/cleaning process.  Also, I've a feeling that oil suppliers are demanding the oil they supply is returned when used.  May be worth investigating though.
  • 08/06/2008 11:03 AM Re: Using veg oil as fuel...
    • Joined on 03/02/2006
    • Posts 4,757
     The thing to thing about Benjie is the £7.50 you save on a tank worth the chance of a shafted fuel pump which will probably cost £300 to sort out. I know "Dirty Diesel" as my mate who runs a pump repair shop calls it is his friend as he gets loads of work from it including non PD diesel VW's Wink
    Also if you are using waste veg oil from a chippy you need a waste license to legally collect it.
  • 08/06/2008 11:36 AM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    Is it bad for the pump?  I thought the Bosch ones used in VW were ok with oil?
  • 08/06/2008 1:21 PM Re: Using veg oil as fuel...
    gary l
    • Joined on 11/03/2007
    • Posts 99
     Some interesting comments here, not read it all but it would seem many people use biodiesel in pd engined cars with no power or mpg loss, although if you read further down someone did have power loss from in a car with an aftermarket oil filter but when VW changed it to a bosch one, all was well.
    http://biodiesel.infopop.cc/groupee/forums/a/tpc/f/584106403/m/610104208
  • 17/06/2008 4:37 PM Re: Using veg oil as fuel...
    dja121
    • Joined on 12/02/2008
    • Posts 33
    I used 50:50 in my Gt tdi 110 bhp (non PD) engine for months and months.. it was totally fine.. Ive heard that the PD engine doesnt like SVO so ive not tried it in my gt tdi 150 bhp Dan
  • 17/06/2008 6:55 PM Re: Using veg oil as fuel...
    Mister_E
    • Joined on 14/03/2004
    • Posts 2,385
     Benje, there's a place in thatcham that does ready made bio-diesel for £1.10 a litre and you don't need to process or clean it etc.
  • 20/06/2008 3:38 PM Re: Using veg oil as fuel...
    p-mwrx
    Golf IV TDI 1.9 AGR 90PS
    • Joined on 02/05/2008
    • Posts 21
     What is pd??
  • 20/06/2008 3:57 PM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    PD stands for 'Pumpe Deuse,' a literal translation is 'Pump Jet.'  It's the newer type of diesel engine used by VW from 2000-2004* (well, it was, they've moved to commonrail now).  PD engines run under incredibly high pressure on each injector - part of the reason they switched to commonrail I think.
    From what I've read, PD engines don't like SVO at all!  Probably due to the pressure in the injector and viscosity of the oil.
    For reference, PD enines are 100bhp (engine code ATD - yours p-mwrx), 115bhp  (AJM), 130bhp (ASZ) and 150bhp (ARL)
    Mister_E - got anymore details on that place that sells BioDiesel?
    * = Dates are approximate!  We all know they vary by model/manufacture etc.!
  • 20/06/2008 4:00 PM Re: Using veg oil as fuel...
    Dod 1396
    • Joined on 16/05/2006
    • Posts 1,190
     PD= pumpe deuse.
    It is/was the new diesel engine which came in 100/115/130/150 hp.
    Which took over from the 90/110 hp engine which can use the Veg oil where Pd's can't(or not recommened).
  • 20/06/2008 4:01 PM Re: Using veg oil as fuel...
    Dod 1396
    • Posts 1,190
     Damn those teachers with the quicker typing skills!
  • 20/06/2008 4:11 PM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    Don't make me correct your spelling and punctuation young-ish man!
  • 20/06/2008 4:13 PM Re: Using veg oil as fuel...
    p-mwrx
    • Posts 21
     so i can use veg oil in mine then?
  • 20/06/2008 4:24 PM Re: Using veg oil as fuel...
    benjie
    • Posts 3,830
    Well I would say "No" because in your signature area you say you have a 100bhp ATD engine which, as I said above, is PD.
    But I also notice in your signature that you say you have a T reg Golf TDI, which wouldn't be PD.  Go and look under your boot carpet and if the 3 letter engine code is AGR, ALH or AHF then yes you can.  Any other's, you can't.
  • 21/06/2008 2:46 AM Re: Using veg oil as fuel...
    p-mwrx
    • Posts 21
