Chipped UK - Where performance counts and dreams come true
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » lowering and adding 18" alloys (rs6)
Last post 23/07/2008 5:46 PM by R23. 5 replies.
Page 1 of 1 (6 items)
  • 01/07/2008 3:03 PM lowering and adding 18" alloys (rs6)
    greg
    • Joined on 01/07/2008
    • Posts 13
     Hi there, i`ve just bought a 1.6 Bora today and i`m wanting to lower it and add 18" rs6 alloys, colud someone tell me how much it should be lowered ,ie so the alloys dont rub or that .tyre size 225/40/18. thanks
        Greg
  • 01/07/2008 3:13 PM Re: lowering and adding 18" alloys (rs6)
    winwiz
    Bora S TDI 1.9 ATD 100PS
    • Joined on 21/02/2008
    • Posts 182
    i've been told around 50-60mm mate, just fitted RS6 wheels to my Bora and this is how they look without being lowered:
  • 01/07/2008 3:44 PM Re: lowering and adding 18" alloys (rs6)
    greg
    • Posts 13
    Thanks mate
  • 01/07/2008 3:52 PM Re: lowering and adding 18" alloys (rs6)
    borabandit2
    Bora V6 4motion 2.8 24v 204PS
    • Joined on 23/10/2005
    • Posts 715
     If you can run to the expense then coilovers are the best way to go so that you can play around with the cars stance. It all depends on what model you have as to how low it will end up as some boras are reasonably low in the first place (sports packs etc) others are sky high. So fixed drops aren't always what you expect. Check out old threads on here and you will find that quite a few people have gone for shocks and springs only to be unhappy with the look and then changed for coilovers.
  • 23/07/2008 10:07 AM RE: Rear Spoiler advice
    greg
    • Posts 13
    I`m needind some advice on which kind of boot spoiler to add to my Bora also any good sites on where to get one....???
                                                               thanks Greg
  • 23/07/2008 5:46 PM Re: lowering and adding 18" alloys (rs6)
    R23
    • Joined on 21/08/2007
    • Posts 601
    borabandit2:
    Exactly the reason I went for coilees - I would have preferred the certainty of a comefortable ride, but I have no complaints with what I have got. I have only dropped my front by about 15-20mm but the back needed 50mm or so. Don't know if this would have been achieved with a kit claiming to give -40mm? If my front WAS actuall dropped by 40mm from std then I would be bottoming out over pebbles!
    On the std suspension the car also sat lop-sided by about 10mm. This reamined when first fitting the coilovers at the same number of thread turns but I was then able to adjust to suit.
    There now seems to be a coilover kit to suit all budgest. I got mine for £220 but you can go all the way to £800+. Horses for courses...
