each corner needs to be adjusted individually as each corner has a different weight. for example the gear box is set to one side (passenger side on mk4) id imagen the fuel tank is set more to one side too. hence why the car is sitting slightly lob sided.
if i were you, id set the ride quite high at first. to allow for the suspension to settle down a bit. then after a week or so id make the final adjustments.
Luke
