uk-mkivs » The Mk4 (MkIV) Community » MkIV (Mk4) Golf & Bora Discussion » PD engine or not?
PD engine or not?
Last post Sun, Aug 24 2008 1:20 PM by pobmk4. 38 replies.
Page 1 of 1 (39 items)
  • Fri, Jul 11 2008 6:58 AM PD engine or not?
    shanevo6
    • Joined on Sat, Feb 10 2007
     Hi,
    I have a 2001 GT TDi 130, when I had it serviced the mechanic, who definately knows his stuff swore blind that my engine is not a PD & didn't require the special oil. All I can say is it goes like one & sticker in the boot says ASZ. So what is the difference?
    Shane
  • Fri, Jul 11 2008 6:59 AM Re: PD engine or not?
    AwesomeSarah Advertiser - Role Icon mapping
    • Joined on Mon, Mar 6 2006
    • Posts 2,492
     ASZ IS a PD engine
    Sorry
    Sarah
  • Fri, Jul 11 2008 7:07 AM Re: PD engine or not?
    AidenUK
    Golf V GT Sport FSI 1.4 170PS
    • Joined on Wed, Oct 4 2006
    • Posts 3,976
    It does require the special oil, ASZ is a PD engine i used to own an 02 GT TDI 130. Your mechanic is wrong this time, and if he doesn't think it's a PD then he won't have put PD oil in it, i would drain out the existing oil and refill with PD spec oil or take the car back and insist he uses PD oil in the car. It's important the correct oil is used on a PD engine.
    Yes
    Some say that each of his toenails are exactly the same as a woman's nipples. And that he thinks the credit crunch is some kind of breakfast cereal..
    All we know is, he's called..
    The not so mighty Leeds United - Firstly, beaten by a TOWN, now beaten by a VILLAGE - At what point will it stop being funny to the scum suffer?
  • Fri, Jul 11 2008 7:08 AM Re: PD engine or not?
    Pauls1820VTGolf Moderator
    Bora SE TDI 1.9 AJM 115PS
    • Joined on Fri, Feb 17 2006
    • Posts 6,366
    It's a PD as Sarah has said.
    Someone will know what the difference, but I dont lol
    Bora SE 115 PD TDI | Upsolute Remap to 153bhp | Cruise Control | 6000k HIDs | Coilovers and 312mm Brakes to come
    UK-VWs - A place for all VWs
    Anni Owner? Click here (25th and 30th)
  • Fri, Jul 11 2008 7:12 AM Re: PD engine or not?
    AidenUK
    • Posts 3,976
    PD stands for Pumpe Deuse..
    That's all i know.. Chuckle
  • Fri, Jul 11 2008 7:14 AM Re: PD engine or not?
    • Posts 6,366
    Doesn't a PD engine have a higher compression or something like that?
  • Fri, Jul 11 2008 7:16 AM Re: PD engine or not?
    Syncopix
    Bora S TDI 1.9 ATD 100PS
    • Joined on Mon, Apr 16 2007
    • Posts 312
    PD stands fo Pumpe Deuse as mentioned above. It's a type of high pressure diesel injection, although the more modern MK5 uses a common rail.
    Custom-Code stage 1 | Audi TT special ed. 'Votex' alloys | H&R Cup Kit | Highline heated leather interior | Boot lip spoiler
  • Fri, Jul 11 2008 7:21 AM Re: PD engine or not?
    Jamesg83
    • Joined on Tue, Jun 19 2007
    • Posts 359
    The PD system is VW's branding of the unit injector. Each injector has it's own injection pump. The fuel is supplied to the injectors at low pressure then injected into the cylinders at a much higher pressure. The ASZ engine is definately PD and will require special oil.
    GT..... It's good to torque
  • Fri, Jul 11 2008 7:44 AM Re: PD engine or not?
    maciek
    Bora SE TDI 1.9 ASZ 130PS
    • Joined on Wed, Mar 12 2008
    • Posts 56
    2.0TDI are common rail. All 100,105,115,130,150 tdi's are PD, 90 and 110 are not.
  • Fri, Jul 11 2008 7:47 AM Re: PD engine or not?
    • Posts 5,853
    "The unit injector combines a high-pressure pump and nozzle with a solenoid valve to form compact assembly. As a result, high-pressure lines are no longer necessary and injection can be controlled by the integrated and extremely precise solenoid valve at pressures of up to 2000 bar. Each cylinder has a unit injector fitted between the valves in the cylinder head."
  • Fri, Jul 11 2008 1:30 PM Re: PD engine or not?
    flashbsd
    • Joined on Tue, Mar 22 2005
    • Posts 487
     hey now im confused, my old mans got a 140bhp 2.0Tdi passat, and that is a PD engine looking at it, and the oil specification.
    Is it or not! lol as ive just put PD oil in it!
  • Sat, Jul 12 2008 7:50 AM Re: PD engine or not?
    gtitdi
    • Joined on Fri, Mar 7 2008
    • Posts 22
    that's one of the newer common rail engines
  • Sat, Jul 12 2008 8:59 AM Re: PD engine or not?
    rob_arthur
    • Joined on Mon, Sep 18 2006
    • Posts 864
     yeah defiently put the correct oil in it or you may be in for the camshaft lobe problem which can happen to the tdi engines
    New Forum For All VAG Enthusiasts.
  • Sat, Jul 12 2008 9:05 AM Re: PD engine or not?
    GavNayshGTTDI115
    • Joined on Wed, Apr 2 2008
    • Posts 388
     id say your mechanic is wrong if it is defo 130 it is defo pd id tell him to use the pd oil or sign the reciept to say if you experience trouble he will pay for parts and sort it free of charge
  • Sat, Jul 12 2008 9:31 AM Re: PD engine or not?
    LukeG
    • Joined on Thu, Oct 25 2007
    • Posts 138
     Go and ask him to point out the fuel pump or the injectors.
  • Tue, Jul 15 2008 3:25 AM Re: PD engine or not?
    shanevo6
     Just found this, it is defo a PD engine. Off to see mech at lunch time
    http://www.tdi-tuningbox.co.uk/pdvp.asp
    Thanks for your replies
    Shane
  • Tue, Jul 15 2008 10:04 AM Re: PD engine or not?
    sjb1781
    • Joined on Fri, May 9 2008
    • Posts 38
    ...sorry if this is bit of a hijack but shanevo6 have you bought one of those tuning boxes off that site you inserted your link from?
    PM me...
  • Mon, Aug 4 2008 1:19 PM Re: PD engine or not?
    Morry
    Bora Sport 1.9 ASZ 130PS
    • Joined on Fri, Sep 21 2007
    • Posts 17
    the 2.0 tdi is a pd the new audi a4 is the first common rail.
    Koni Shocks and Springs Lowered 40mm, Custom Stainless with de cat
  • Mon, Aug 4 2008 1:25 PM Re: PD engine or not?
    AdyAde
    • Joined on Tue, Jul 22 2008
    • Posts 55
     So what is the correct oil for a PD engine?
  • Mon, Aug 4 2008 1:30 PM Re: PD engine or not?
    pc.iow
    • Joined on Sun, Oct 3 2004
    • Posts 2,502
    AdyAde:
     .,... About fifty squids.
    http://img.photobucket.com/albums/v239/levicaymen/avitarpic.jpg
  • Mon, Aug 4 2008 1:33 PM Re: PD engine or not?
    Filby1
    Golf IV V6 4motion 2.8 24v AQP 204PS
    • Joined on Mon, Dec 10 2007
    • Posts 857
     what spec is pd oil 5w30?
    What I Got: 2001 Silver 2.8 V6 4Motion | 3 Dr | Sun Roof |Full sports leather | Multi Function wheel | Heated Seats | Winter Pack | Aero Wipers | Stubby Aerial | Phillips Xtream 80%+ | Diodems | TT Quick Shift | Rear ATB Spoiler | R Line Gear Nob and surround | Full R32 Alloy | Gamma + DSP | Full FIS | Rain Sensing Wipers |
  • Thu, Aug 7 2008 2:42 PM Re: PD engine or not?
    producedapples
    • Joined on Fri, Apr 20 2007
    • Posts 113
    Lok at rocker cover...black is PD, silver is non PD..standard rotary :)
    1999 Golf Gt tdi laptop tuned to 158bhp... bellers rodders :)
  • Thu, Aug 7 2008 2:45 PM Re: PD engine or not?
    producedapples
    • Posts 113
    rob_arthur:
    Probs find long life servicing causes hydraulic followers to fail, causing an almighty rattle, then ur cam lobes break :) use longlife oil on standard fixed servicing on pd150s...see how ya go
    HTH
  • Thu, Aug 7 2008 3:00 PM Re: PD engine or not?
    Rustynuts
    • Joined on Sat, May 28 2005
    • Posts 1,056
    producedapples:
    rob_arthur:
    HTH
    Nope, the failure of the camshafts was due to a faulty
