TTS Roadsport - Parts, Accessories, Styling and Performance Tuning
uk-mkivs » Technical Community » VAG Diagnostic Software Discussion » Urgent help required with codes
Last post Fri, Sep 19 2008 3:01 AM by Welsh_Dave_TDi. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Jul 11 2008 12:43 PM Urgent help required with codes
    Welsh_Dave_TDi
    • Joined on Thu, Jun 26 2008
    • Posts 125
    Hiya guys,just ran a fault code check on my Tdi 130 2002 golf and the following have come back any one able to tell me what they mean
    17672  Valve for pump inj. CYL2 control limit exceeded
    P1264 Error Intermittent
    17675  cyl3 P1267
    17678 cyl4 P1270
    17669 cyl1 P1261
    01314 Engine ECU read trouble codes. Error occurs intermittent
    Sad
  • Fri, Jul 11 2008 1:46 PM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Any one? Or any one know of any websites that would have the codes listed?
  • Fri, Jul 11 2008 1:55 PM Re: Urgent help required with codes
    pobmk4
    Golf IV TDI 1.9 AHF 110PS
    • Joined on Wed, May 9 2007
    • Posts 328
     they r telling you that your injectors are running outside there tolerance, Is it having running problems? Ive seen this before, i replaced the wiring loom for the injectors and it fixed the problem!
    Mods : .:R32 front bumper, 18" RS4's, 130 turbo, chipped NI remap, anni headlights, debadged rear, sharan badge mod, german plates, black grille - with more to come
    VW technician - complete with mobile diagnostics, all VAG work carried out.
  • Fri, Jul 11 2008 2:37 PM Re: Urgent help required with codes
    kalu
    • Joined on Sat, Apr 21 2007
    • Posts 611
     +1, this fault is normally the injector loom!
    Need some help? with...Vagcom, Keys/Immobilser adaption/defeat, Ecu/Cluster Swap. Miles to Empty/Illuminated Needles, Autowindows etc... PM me :)
  • Fri, Jul 11 2008 4:36 PM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     No only problems i have are traction control light comes on at 50mph and the whole car judders once the lights on...apparantly something to do with the ABS and the other problem i have is the car is only doing average 33mpg
  • Mon, Jul 14 2008 11:27 AM Re: Urgent help required with codes
    Bazmcc
    Bora S TDI 1.9 ATD 100PS
    • Joined on Tue, Jun 14 2005
    • Posts 5,239
     Yip - looks like the injector loom needs replacing.
    PD100 injectors - £80 for the set of 4.
    Silicone hoses for bike or car engine bay group buy - 35% off http://uk-mkivs.net/forums/p/226937/1460796.aspx#1460796
  • Tue, Jul 15 2008 3:05 AM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Cheers Bazmcc. Is this an expensive job?
  • Wed, Jul 23 2008 2:51 AM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Hiya guys,just thought i'd pop a quick little message up to say that i've had my car in @ a local VW specialist since Monday morning and he's been running tests on it. He has had to replace the wiring loom for the injectors (like you guys so wisely said) and apparantly that has stopped the horrible shaking of the car at speeds above 50mph,how ever he's still getting the traction control light coming on so he's still looking into that. Hopefully i'll be getting the car back tomorrow morning and i'll be able to see if it has stopped shaking :D
  • Wed, Jul 23 2008 5:09 AM Re: Urgent help required with codes
    Bazmcc
    • Posts 5,239
     The traction control light is usually caused by a faulty abs sensor.
  • Wed, Jul 23 2008 6:01 AM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Cheers Baz i'll make sure he checks them.
  • Thu, Sep 18 2008 10:45 AM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Well its been a long and nervous 2months but finally its fixed. Im told it was 1 of the injectors causing all my problems. So ive had a new wiring loom for it and a new injecter. Am picking it up tomorrow morning so hopefully it will be fixed
    Cheers for all the advice & help guys
  • Fri, Sep 19 2008 3:01 AM Re: Urgent help required with codes
    Welsh_Dave_TDi
    • Posts 125
     Picked it up this morning and drove it to work...drove perfect. Its smoother drive up the revs,quick acceleration and the mpg looks alot better now :D Now let the modding begin
