uk-mkivs » Technical Community » VAG Diagnostic Software Discussion » Airbag fault code issue
Last post 22/07/2008 1:24 AM by old_n07. 4 replies.
  • 20/07/2008 4:37 PM Airbag fault code issue
    Gary Cundliffe
    • Joined on 01/12/2003
    • Posts 1,973
    Had the airbag warning come on whilst I was in Germany and got the fault code today;
    00589 - Airbag Igniter 1; Passenger Side (N131)
            32-00 - Resistance too High
    Anyone able to shed some light on this? I'm willing within reason to sort it but am tempted, if possible to disconnect the passenger airbag (as if you had a child seat in the front) to remove the warning and the fault.
    Bit lazy but don't fancy dismantling the passenger side dash.
  • 20/07/2008 4:49 PM Re: Airbag fault code issue
    Diggy
    • Joined on 19/05/2008
    • Posts 95
    Unplugging the airbag wouldnt help your situation, once unplugged the module would realise you had an airbag missing and the light would still be on and none of the airbags work when the warning light is up on the dash. I dont know what your problem might be i hope someone can shed some light on that, also before you start doing any thing to your airbags always disconnect the battery Smile
    Richard
  • 21/07/2008 1:34 PM Re: Airbag fault code issue
    Gary Cundliffe
    • Posts 1,973
     Evening bumpage
  • 21/07/2008 2:27 PM Re: Airbag fault code issue
    wellsy
    • Joined on 15/12/2002
    • Posts 1,236
    Gary,
    When you disconnect the airbag, it's done in the software i.e. probably do it with VAG COM, you don't have to physically un plug it.
    It may be worth seeing if the plug has come loose though.
  • 22/07/2008 1:24 AM Re: Airbag fault code issue
    • Joined on 03/02/2006
    • Posts 4,881
     It could be faulty wiring, plug loose or even a faulty ignitor on the air bag which would in the case of the ignitor being faulty probably mean a new unit Tongue Tied
    http://wiki.ross-tech.com/index.php/00589
