OK - so one rolling road session later and I have some numbers!
In short 130bhp engine (100 @ wheels) and 130Nm.
Had a fairly good chance to try different settings on adjustable cam gear and will post curve pics (when i've sorted my new hosting). Could get 133bhp with 2deg of retard but the only improvement to curves was above 6k rpm and much worse below. Tried +2 and +5 and settled on +5. Less top end power but higher bhp + torque over rest of curve and especially low rpm range (which I need to turn the big heavy 18"s I have).
Fuelling checked and all fine even at 3.0bar, but running 3.1 for nicer top end. Guy who did tuning v helpful and said I prob wouldn't see much more power from chip but ignition timing might help smooth curves/better drivablity,etc.
Trogolodyte - my P-Flow isn't strictly a CAI but a short-ram system. Replaces air box with BIG open filter oval-cone where air box was. OEM cold air feed does point at it nicely but planning to add additional cold feeds from lower bumper intakes soon. Fraid I can't really say how much power this alone would make, but Neuspeed reckon 1-3 gain for their K&N panel filter so probably a bit more than that for the short-ram.
Ramble over, pics & curves to follow. Maybe even the full mod list in XLS format.
Too much to list here - perf wise: TT260 cam, Neuspeed adj Cam Gear, EuroSpec variable FPR, Neuspeed P-Flow Intake, Simota solid intake pipe, Scorpion 3" piped Cat-Back, TSR 200CPI Hi-Flow Cat, Iridium plugs & Neuspeed leads, A/F Gauge. Next - ... suggestions welcome (charger ideas)
