Might be stuck down with tree sap...
Get someone to pull the lever while you pull the bonnet up or even push it down and it might pop up.
If not, the cable may have snapped inside the mechanism point or mechanism is broke... but unfortunatly, there is a protector around the actualy mechanism to prevent theives from teevin you engine (well.....its like that on my mums old bmw so assuming its the same.)
To open the bonnet, you have to pull a little rubber bit that pops out. try see what that attches to and yank that with some plies.
When you pull the lever inside the car, does the bonnet pop up at all ?
If this is the case, there's not a lot you can do
