uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - I.C.E and Electronics » Hi-Line retro fit?
Hi-Line retro fit?
Last post Fri, Aug 8 2008 2:00 PM by chowells. 9 replies.
  • Thu, Jul 31 2008 6:36 AM Hi-Line retro fit?
    Animal
    • Joined on Tue, Jul 5 2005
    • Posts 65
    While it's not a deal breaker, I'm trying very hard to find a Golf with a Hi-Line display. Should I have to go without, just how difficult and expensive is it to retro fit - are the clocks/dash all one unit?
    I apologise if this has been covered before, please point me in the correct direction if there is info anywhere. I've had a quick scan of recent posts and couldn't find any info. Thanks.
    Shopping for 2.0 TDi to give to Allard to play with...
    Ford Focus TDCi Sport - Remapped to 149bhp
    :: ST170 brake conversion with OE discs and Ferrodo pads :: 30mm Eibach Pro springs and dampers :: B&M MTX75 shortshifter with RS lift-up collar :: ST170 intake with K&N panel filter :: Goodyear Eagle F1 GSD3 :: OE Black ST170 headlights with clean indicator mod and Hella HID conversion :: Down turned exhaust removed & replaced with RS trim :: Retro fitted VW/Audi Phat Noise Music Keg 20GB
  • Thu, Jul 31 2008 9:22 AM Re: Hi-Line retro fit?
    bacillus
    • Joined on Fri, Aug 17 2007
    • Posts 441
     can't remember the full details but the retro fit would be quite expensive.
  • Fri, Aug 1 2008 4:45 AM Re: Hi-Line retro fit?
    MrLapou
    • Joined on Mon, Apr 2 2007
    • Posts 200
    Easy fit. Need Vagcan (Not confuss with Vagcom (VCDS) to read the SKC of old clock display then install new highline display and program it with old display's SKC.
  • Mon, Aug 4 2008 7:12 AM Re: Hi-Line retro fit?
    Animal
    • Posts 65
    What does it consist of? Are the dials one complete sealed unit or is the hi-line screen a separate component?
    Can anyone offer a ballpark figure in terms of price - "quite expensive" isn't a great deal of help as this is VAG we are talking about, so it goes without saying... Ta
    And is Vagcan as widely available as Vagcom - I assume CanBus has to be coded separately, I thought Vagcom could access this?
  • Mon, Aug 4 2008 7:44 AM Re: Hi-Line retro fit?
    MrLapou
    • Posts 200
    Normally the full dial display has to be bought.
    Why not ask your dealer the price for the display.
    At the monet there's one on eBay.
  • Mon, Aug 4 2008 5:56 PM Re: Hi-Line retro fit?
    chowells
    • Joined on Sun, Jun 24 2007
    • Posts 72
    I believe this thread on vwvortex may help, though I guess it's for a US spec car
    http://forums.vwvortex.com/zerothread?id=3173886
    I'm kinda considering doing the same on my Jetta, but a bit too scared of breaking stuff. Let me know how you get on :)
    '56 VW Jetta 2.0 FSI
  • Tue, Aug 5 2008 12:14 AM Re: Hi-Line retro fit?
    mortygttdi
    • Joined on Fri, Sep 28 2007
    • Posts 212
    Ive got the tools to do it and ive got an highline unit but its not the right one??? you need an highline unit from an 05 reg car to be able to code it properly,  any thing above this ive been told has different encryption software.
    Darren
  • Thu, Aug 7 2008 8:41 AM Re: Hi-Line retro fit?
    Animal
    • Posts 65
    Cheers guys.
    However, now I'm a little confused - from the vortex post, it would seem that you need a hi-line display/screen (which I'm now assuming is a complete unit with the dials/gauges?) and the upgraded hi-line CECM to run it? It's not just a case of swapping over the dash unit for one with the full height hi-line display?
  • Thu, Aug 7 2008 8:59 AM Re: Hi-Line retro fit?
    RENT-A-GOAT
    Golf V S 2.0 SDI 75PS
    • Joined on Mon, Apr 17 2006
    • Posts 559
    I have been thinking about doing this but think it might be more effort than its worth
  • Fri, Aug 8 2008 2:00 PM Re: Hi-Line retro fit?
    chowells
    • Posts 72
    http://forums.vwvortex.com/zerothread?id=3604801
    is also interesting.
    But if anything it confuses me even more :)
