uk-mkivs » Technical Community » VAG Diagnostic Software Discussion » Newbie Vagcom Question
Last post 06/08/2008 5:22 PM by Bradmax. 4 replies.
  • 06/08/2008 2:27 PM Newbie Vagcom Question
    Bradmax
    • Joined on 14/02/2007
    • Posts 26
    So I finally bit the bullet and got the full version of vagcom to go with the cheapo cable ive had for ages, its version 409.1 and it seems to work just fine, but ive no idea how to actually use it and id like to do the following to my wifes pd150
    miles to empty & auto locks.
    Can anyone point me in the right direction please
  • 06/08/2008 2:57 PM Re: Newbie Vagcom Question
    Bradmax
    • Posts 26
     just checked i have immo 3 VDO cluster if that helps?, even if miles to empty cant be done how about the auto door locks?
  • 06/08/2008 4:09 PM Re: Newbie Vagcom Question
    mattytdi
    • Joined on 09/01/2006
    • Posts 353
    Need VAG-TACHO(?) for miles to empty & illuminated needles. Locking as per below;
    Selective Unlocking:
    [Select]
    [46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
    So, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
    Lock/Unlock Horn/Flash:
     [Select]
    [46 - Cent. Conv.]
    [Adaptation - 10]
    Channel (03..08)
    Adaptation Value (1 = on, 0 = off)
    [Save]
    Channel 03 Auto Lock
    Channel 04 Auto Unlock
    Channel 05 Unlock, horn sounds
    Channel 06 Lock, horn sounds
    Channel 07 Unlock, turn signals flash
    Channel 08 Lock, turn signals flash
  • 06/08/2008 4:10 PM Re: Newbie Vagcom Question
    Kaed
    • Joined on 07/03/2008
    • Posts 14
    I don't believe the 'miles to empty' is a function of Vag Com.  Think you need something called Vag-Tacho for the miles to empty mod.
    Edit - Meh, beaten to it by a minute! - I must of been typing at the same time, I was just being slow researching :(
  • 06/08/2008 5:22 PM Re: Newbie Vagcom Question
    Bradmax
    • Posts 26
    mattytdi:
    [Select]
    [Recode - 07]
    [Do It!]
     [Select]
    [46 - Cent. Conv.]
    [Adaptation - 10]
    Channel (03..08)
    [Save]
    Cheers for that, typical having just bought vagcom lol!
