uk-mkivs » The Mk5 (MkV) Community » Mk5 Performance and Technical Area » Mk5 - I.C.E and Electronics » Anyone know how to fix this MFD readout?
Last post Tue, Aug 19 2008 7:39 AM by ronime. 4 replies.
  • Thu, Aug 7 2008 9:23 AM Anyone know how to fix this MFD readout?
    bacillus
    • Joined on Fri, Aug 17 2007
    • Posts 441
     Had to disconnect my battery today.
    Now that everything is sorted and the battery reconnected, where I used to see MPG in the display, I'm now seeing the "engine on" uptime (the 1h 11min readout above the temperature).
    Can't really see any option to change this back in the settings menu. Help...
  • Thu, Aug 7 2008 10:31 AM Re: Anyone know how to fix this MFD readout?
    PJ Moderator
    • Joined on Tue, Jun 10 2003
    • Posts 2,454
    Is it not selectable on the stalk like the MKIV?
    1.8T | Leather Recaros | Eibach Pro -30mm Springs & Shocks | Xenons | Upsoluted
  • Thu, Aug 7 2008 11:12 AM Re: Anyone know how to fix this MFD readout?
    chowells
    • Joined on Sun, Jun 24 2007
    • Posts 72
    Surely it's just a case of pressing the up and down arrows on the right hand stalk as PJ said.
    My midline cycles through MPG, speed warning, distance possible on tank, uptime, etc.
    '56 VW Jetta 2.0 FSI
  • Thu, Aug 7 2008 1:48 PM Re: Anyone know how to fix this MFD readout?
    bacillus
    • Posts 441
    chowells:
    well strike me down with a feather, I was looking under the settings menu and couldn't see anything to change the screen. Just pressing on the arrows without entering the settings menu like you said sorted it.
  • Tue, Aug 19 2008 7:39 AM Re: Anyone know how to fix this MFD readout?
    ronime
    Golf Match 1.9 TDI 105PS
    • Joined on Fri, Aug 8 2008
    • Posts 16
    There are also two separate memories.
    Memory 1 is the "trip" memory which resets after you have left the vehicle with the ignition switched off for two hours or more.
    Memory 2 resets after 999,999 miles or something like that.
    On cars with steering wheel mounted controls, pressing the "OK" button briefly will alternate between displaying memory 1 and memory 2. Holding the "OK" button down for two seconds will reset the currently selected memory.
    I presume that stalk controlled cars have an equivalent to the "OK" button.
