The UK's Leading Volkswagen Parts Trader
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Suspension, Brakes and Chassis » Help!! 4motion wheel spin
Last post Fri, Oct 10 2008 2:18 PM by Jambo69. 69 replies.
Page 1 of 2 (70 items) 1 2 Next >
  • Thu, Aug 7 2008 1:11 PM Help!! 4motion wheel spin
    L8nitescallywag
    • Joined on Tue, Oct 30 2007
    • Posts 63
    hey there..In a bit of a state with my motor. The front wheels are spinning in the wet from take off in 1st gear. Also having this loss of traction and spinning of front wheels when I rev up to take a turn in 1st and 2nd gear.The esp light flashes a couple of times then goes off and the car jerks a bit. this hasn't  happend before and now i'm wondering if the 4motion system is working or is there a fault somewhere. Tyres are in good nick. How do check if the 4motion system is working without hooking it up to vagcom. I dont have any warning lights on as well. Thanks for any and all info.
  • Thu, Aug 7 2008 1:31 PM Re: Help!! 4motion wheel spin
    Cheeky Chappers
    • Joined on Sat, Jan 12 2008
    • Posts 3,108
    Get VAGcom on it ASAP.
    This was happening to me.....I had to buy a new Haldex Module (£600 new) but I was lucky and found one on Ebay for £80.
    It may be something like the Haldex fuse has blown (side of dash) or Haldex connector/sensor.
    Go to the Resource facility on top of the page, select download and open the VAGcom User Location List and PM anyone who lives near you.  Dealer will charge you £60+ for VAGcom.
    Sorry mate Sad
    Hayley
  • Fri, Aug 8 2008 9:01 AM Re: Help!! 4motion wheel spin
    L8nitescallywag
    • Posts 63
    Thanks for the info Hayley. What faults codes would come up on vagcom?
  • Fri, Aug 8 2008 9:15 AM Re: Help!! 4motion wheel spin
    R32Pete
    • Joined on Tue, Jan 29 2008
    • Posts 958
     1st place i would check is the FUSE BOX,
    cant remeber wich one though as my cars not here,
    as hayley said could be the unt itself in which case its a good opertunity to upgrade or see if amd have the one they took of mine when i upgraded a few weeks ago,
    Rotrex stage 2! Bored 2.9l V6, Full low comp internals, Custom Miltek Hi-flo Exhaust system with de-cat, Sachs Performance Clutch, KW V3 coilovers, R32 Brakes, R32 ARB, Cupra MK2 Front buckets,
  • Fri, Aug 8 2008 9:20 AM Re: Help!! 4motion wheel spin
    Cheeky Chappers
    • Posts 3,108
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.lbl
    Part No: 1C0 907 379 F
    Component: ESP ALLRAD MK60 0103
    Coding: 0023046
    Shop #: WSC 31414 000 00000
    4 Faults Found:
    01324 - Control Module for All Wheel Drive (J492)
    004 - No Signal/Communication - Intermittent
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    003 - Mechanical Failure - Intermittent
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    01314 - Engine Control Module
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    1 Fault Found:
    49-10 - No Communications - Intermittent
  • Fri, Aug 8 2008 9:28 AM Re: Help!! 4motion wheel spin
    haf1zur
    Golf IV R32 3.2 240PS
    • Joined on Wed, Aug 3 2005
    • Posts 4,023
     i have a spare if your after one
  • Fri, Aug 8 2008 10:16 AM Re: Help!! 4motion wheel spin
    bouncerMk4
    • Joined on Mon, Apr 30 2007
    • Posts 1,497
     When was the oil and filter changed last
    bouncerMk4
    2003 Mk4 TDi 130ish ps
    2005 A3 SE 2.0TDi 140 ps (the wife's!!)(but mine from Monday) - (but she didn't say which Monday
    I'm VAGnostic - thank God
  • Fri, Aug 8 2008 11:45 AM Re: Help!! 4motion wheel spin
    L8nitescallywag
    • Posts 63
     changed haldex filter and oil at 40k service. now doing 56k. Haf I would be interested in getting that off you if mine is knackered. heading down to london on 22nd August to have my motor checked and serviced. would appreciate it if you could hold on to it till then. cheers for all the advice and info.
  • Fri, Aug 8 2008 11:58 AM Re: Help!! 4motion wheel spin
    Cheeky Chappers
    • Posts 3,108
    Can you see my VAGcom report with fault codes above?  People are having problems viewing my attachments at the min.
  • Fri, Aug 8 2008 12:01 PM Re: Help!! 4motion wheel spin
    wellsy
    • Joined on Sun, Dec 15 2002
    • Posts 1,616
     I can see this one H.
    2002 TDI 150 : 3 DR : Reflex Silver :: 2007 GTI DSG : 3 DR : Blue Graphite
  • Fri, Aug 8 2008 1:27 PM Re: Help!! 4motion wheel spin
    L8nitescallywag
    • Posts 63
     yeah i can see it. thanks for that. printed it off. will compare it the printout i get when i hook it up to vagcom.
  • Sun, Aug 10 2008 2:51 PM Re: Help!! 4motion wheel spin
    Jambo69
    • Joined on Thu, Sep 23 2004
    • Posts 454
     I still have this issue, been a long time, check out my link at the bottom.
    The fuse is no 30 looking at the vagcom print out first thing is to check the plug to the haldex controller, then clear all the faluts and see what comes back. mine shows nothing at all on vagcom the only one i ever got was the "no communication" one which was a poor connection in the plug, have sorted that but still have a 2motion!
    Car modification database profile No1
  • Mon, Aug 11 2008 2:13 AM Re: Help!! 4motion wheel spin
    haf1zur
    • Posts 4,023
    Jambo69:
    Have you checked your dogbone mount?
    Maybe need to change the bushes, sorted mine out good and proper that did
    Hafizur
  • Mon, Aug 11 2008 2:44 AM Re: Help!! 4motion wheel spin
    bouncerMk4
    • Posts 1,497
    L8nitescallywag:
    Audi used the change Haldex oil and filter every 10k on the old quattro
    bouncerMk4
  • Mon, Aug 11 2008 2:46 AM Re: Help!! 4motion wheel spin
    haf1zur
    • Posts 4,023
    bouncerMk4:
    L8nitescallywag:
    There was some sort of advisary somewhere suggesting filter every 20k and oil every 10k, rather than filter every 40k and oil every 20k, i just do both at 10k intervals
    Hafizur
  • Mon, Aug 11 2008 7:09 AM Re: Help!! 4motion wheel spin
    L8nitescallywag
    • Posts 63
    what would be the symbol for the fuse? Also i've read about some connection between the haldex and the brake light switch. If the brake light switch is faulty, would the brake lights still work??
  • Mon, Aug 11 2008 7:27 AM Re: Help!! 4motion wheel spin
    Jambo69
    • Posts 454
    haf1zur:
    Jambo69:
    Hafizur
    The dogbone mount, really? how would that stop the Haldex?
  • Mon, Aug 11 2008 7:29 AM Re: Help!! 4motion wheel spin
    bouncerMk4
    • Posts 1,497
    L8nitescallywag:
    From what I understand if the brake light switch is faulty it could cut the power because the ECU thinks the brake is on and you can't accelerate and brake at the same time
    bouncerMk4
  • Mon, Aug 11 2008 7:37 AM Re: Help!! 4motion wheel spin
    Jambo69
    • Posts 454
     Brake switch will disable Haldex, but it shows a fault code on vagcom. they are only £6 though
  • Mon, Aug 11 2008 7:38 AM Re: Help!! 4motion wheel spin
    haf1zur
    • Posts 4,023
    Jambo69:
    haf1zur:
    Jambo69:
    Hafizur
    oops, wrong thread, lol
  • Mon, Aug 11 2008 7:40 AM Re: Help!! 4motion wheel spin
    L8nitescallywag
    • Posts 63
     ok so there is a link between the 2, but will the brake lights still work if the switch is faulty? the reason i ask is because all my brake lights are working.
  • Mon, Aug 11 2008 7:42 AM Re: Help!! 4motion wheel spin
    bouncerMk4
    • Posts 1,497
     What about the two outer ones on the third hi-level light?
    bouncerMk4
  • Mon, Aug 11 2008 7:47 AM Re: Help!! 4motion wheel spin
    Jambo69
    • Posts 454
     the switch can stop operating the lights, i had it once ( on my 3rd switch) where if you braked too hard the lights went back out, really safe! If any one of the 3 lights dont work its the light itself. the switch send a signal to all 3 at the same time
