uk-mkivs » The Mk4 (MkIV) Community » MkIV (Mk4) Golf & Bora Discussion » lowering issues
lowering issues
Last post 11/08/2008 6:24 AM by cobby. 17 replies.
Page 1 of 1 (18 items)
  • 08/08/2008 11:39 AM lowering issues
    orangevanman
    • Joined on 28/04/2007
    • Posts 38
    Hi guys i have an 02 gt tdi golf which i have had lowered on full weitec springs/shocks and a h&r anti roll bar.
    my problem is that everytime i accelerate or brake i get a knocking noise. (basically every time the engine moves up and down)
    only started happening since  the lowering.
    any ideas please?
  • 08/08/2008 11:55 AM Re: lowering issues
    trogolodyte
    Golf IV GTI 2.0 8v APK 115PS
    • Joined on 16/07/2008
    • Posts 75
     No sorry, but I like those wheels, I was thinking of getting some of those and they look good. That picture of your car puts mine to shame, and makes me realuize how badly I need to give it a good clean and polish. Your pic makes me realize what mine could look like if I cleaned it. Thanks,.!!
  • 08/08/2008 12:01 PM Re: lowering issues
    rick18ts
    • Joined on 24/05/2005
    • Posts 288
     Drive shaft on arb's maybe?
  • 08/08/2008 12:57 PM Re: lowering issues
    orangevanman
    • Posts 38
    rick18ts:
    hmmm how would i cure that?
  • 08/08/2008 3:13 PM Re: lowering issues
    shammy
    • Joined on 10/03/2008
    • Posts 331
     Get new arb's. How much have you lowered by? You shouldn't get issues unless you've gone past roughly 40mm
    thanks
  • 08/08/2008 3:35 PM Re: lowering issues
    orangevanman
    • Posts 38
    shammy:
    thanks
    i did buy a new h & r anti roll bar, i think the weitec kit i bought was 55mm but the guy told me to buy the arb and that would stop any knocking
  • 08/08/2008 4:01 PM Re: lowering issues
    shammy
    • Posts 331
     Yeah that sounds right to me, I'm stuck then, sorry to not be able to help
  • 09/08/2008 4:40 AM Re: lowering issues
    willydog
    Bora Sport 1.9 AHF 110PS
    • Joined on 09/01/2008
    • Posts 133
    you could getting some front shock spacers from VW to raise you car, they sell 2 types 5mm one and a 10mm one, although you may already have the 5mm one on already as some cars have these fitted as standard
  • 09/08/2008 4:56 AM Re: lowering issues
    Hightower
    • Joined on 13/07/2008
    • Posts 34
     engine mounts?
  • 10/08/2008 3:28 AM Re: lowering issues
    orangevanman
    • Posts 38
    any one else any idea?
    its really annoying me
  • 10/08/2008 4:41 AM Re: lowering issues
    wattsygt
    • Joined on 31/05/2008
    • Posts 114
    willydog:
    what are these? and where do they fit as i lowered my tdi 35mm but the drivers side is down at least 5-10mm lower then passenger side????
  • 10/08/2008 5:25 AM Re: lowering issues
    mrmike
    • Joined on 28/01/2007
    • Posts 263
     Check the engine mounts etc, gearbox one can be common for snapping, or the roll bar supplyed was an uprated standard spec? as the drop link would have been changed to get a higher lift as well.
    Mike
  • 10/08/2008 5:33 AM Re: lowering issues
    Pat
    • Joined on 18/04/2002
    • Posts 2,889
    H&R bar won't be touching the driveshaft, but the subframe will have to have been removed to fit it. The subframe bolts might not be uber-tight and it could be moving, causing the knocking sound?
  • 10/08/2008 7:43 AM Re: lowering issues
    willydog
    • Posts 133
    wattsygt:
    willydog:
    here's a pic of them, they fit on to your shock absorber piston on top of your spring cap just below the bearing to give you more height
  • 10/08/2008 7:56 AM Re: lowering issues
    charlie123ii
    Bora Highline TDI 1.9 AJM 115PS
    • Joined on 22/07/2006
    • Posts 374
     i would say its the dogbone engine mount, the one that bolts directly underneath it. Mine "went" and jus knocks about a bit. check to see if its worn etc. If you buy an uprated one, beware that they shake the steering wheel like fook. I personally think they are horrible.
    charlie
  • 10/08/2008 8:51 AM Re: lowering issues
    Gricey
    • Joined on 04/08/2008
    • Posts 23
     did you replace the drop links and arb bushes when u changed it allthough i have to agree with above with the engine mount
  • 10/08/2008 11:12 PM Re: lowering issues
    Jambo69
    • Joined on 23/09/2004
    • Posts 379
     Mine was the front top mounts, and drop links at the rear.
  • 11/08/2008 6:24 AM Re: lowering issues
    cobby
    • Joined on 19/04/2008
    • Posts 84
     I have just bought Eibach Sportlines Springs and Anti Roll Bars for My GT TDI. It says it drops my car 25mm - 30mm but 50mm on a standard Golf. Will i have this knocking issue once mine is fitted?
