North East based VAG performance, tuning, suspension and styling specialist
uk-mkivs » The Mk4 (MkIV) Community » MkIV (Mk4) Golf & Bora Discussion » Majour Majour problem please help!!!
Last post 12/08/2008 4:18 PM by Dent Reform. 30 replies.
Page 1 of 1 (31 items)
  • 08/08/2008 12:11 PM Majour Majour problem please help!!!
    basscrazy
    • Joined on 02/02/2008
    • Posts 635
    Went into the garage cos was having a lot of banging got loads done r32 arb and bushes throughout car they did a great job for great price and they found what was causing the banging which only started in last two days
    HERE!!!!!!!!!!!!!
    somethings got to have shifted hes saying i need a shoot load of work to rectify the problem which he cannot do so hes not saying it just to get money wtf could of happened he said the engine needs to be 30mm roughley backwards for the drive shaft to be straight like it should be!!!!
  • 08/08/2008 12:36 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    Plus this was defo like this before i took to garage it wasnt them theyve looked after me for years but  didnt crack and bang untill recently ive done 800 miles since conversion
  • 08/08/2008 12:44 PM Re: Majour Majour problem please help!!!
    GavNayshGTTDI115
    • Joined on 02/04/2008
    • Posts 313
     have you checked mounts?? if engines moved might have a knackered mount somewhere id check the bottom back one first? also have you checked the inner joint where the shaft is bent is still in one piece?
  • 08/08/2008 12:53 PM Re: Majour Majour problem please help!!!
    vdubben
    • Joined on 20/12/2006
    • Posts 176
    yeah check the mounts can't think of anything else that woulds cause that. shouldn't be that much work involved in sorting it
  • 08/08/2008 1:35 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    the drive shaft has no play in it he says but he also said that could be due to so much strain on it
  • 08/08/2008 1:48 PM Re: Majour Majour problem please help!!!
    alleyroo
    • Joined on 14/01/2007
    • Posts 1,952
     Another vote for the engine mount or mounts here. Did the garage check them at all? There are only three, the dog bone at the bottom rear of the engine, and one at either side on top of the engine.
    Andy
  • 08/08/2008 1:52 PM Re: Majour Majour problem please help!!!
    • Joined on 09/04/2007
    • Posts 4,932
     Hmmmm maybe the engine mounts arn't as strong on a 1.4? You now have the S3 engine which will be putting a hell of a lot more strain on them?
    If someone could check if all engine mounts are the same throughout the range,but i suspect not.
  • 08/08/2008 1:53 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Joined on 28/02/2006
    • Posts 6,800
    Have a look to see if an engine mount has shifted .....
    in the pics i take it that is the the drivers side shaft?
    at worst case it could even be an inner CV joint that had blown and as you said the garage told you there was no play in it Confused
    Tell me something was the dog bone mount fitted in that picture?
    it really looks like the engine has shifted forwards but i cant see how Confused
    Can you get some pictures of the top of the engine for me mate?
    Andy
    P.S i am running 1.6 mounts with a V6 so cant see that is the problem
  • 08/08/2008 1:56 PM Re: Majour Majour problem please help!!!
    • Posts 4,932
     Had a quick look on Euro parts,and they are infact different from a 1.4Sad
  • 08/08/2008 1:58 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    we know that the part numbers are not the same patch btu in real life terms the 1.4 and 1.6 mountings are the same so if i can run a V6 on 1.6 monts then there should not be a problem using them on a 1.8T
    Andy
  • 08/08/2008 2:03 PM Re: Majour Majour problem please help!!!
    • Posts 4,932
     Strange one of the mounts is more expensive on the 1.4 and is made by a different manufacturerConfused
  • 08/08/2008 2:04 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    Craig, jump on MSN or skype mate Yes
  • 08/08/2008 2:17 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    on
  • 08/08/2008 3:31 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    what a DRAMA queen Chuckle
  • 08/08/2008 3:32 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    oh sod off your not right yet
  • 08/08/2008 3:35 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    You KNOW i am Cool
  • 08/08/2008 3:36 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    yea yea
  • 08/08/2008 3:40 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    Ja Ja heißt leck mich am arsch
    pbren
    • Joined on 17/05/2008
    • Posts 87
     please tellBig Smile
  • 08/08/2008 3:41 PM Re: Majour Majour problem please help!!!
    maxitrol
    • Joined on 29/03/2006
    • Posts 772
     come on andy what is the problem
  • 08/08/2008 3:42 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    he says my drivers mount has shifted
    Dent Reform
    • Posts 6,800
    engine mount bolts have shifted causing the engine to come forwards about 10mm
    will put some pics up to see
    Andy
  • 08/08/2008 3:43 PM Re: Majour Majour problem please help!!!
    basscrazy
    • Posts 635
    if you all think hes wrong do chirp up
  • 08/08/2008 3:46 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    basscrazy:
    you know i am on the money with this one Cool
    get´s on my box with brass band and TRUMPET Chuckle
  • 08/08/2008 3:48 PM Re: Majour Majour problem please help!!!
    Dent Reform
    • Posts 6,800
    you can see in the first pic how much it has shifted and teh bottom one has also moved a few mm
  • 08/08/2008 4:01 PM Re: Majour Majour problem please help!!!
    maxitrol
    • Posts 772
     think  you might be right andy...will you put  strengtheners  inside the bolt holds
