Try here: http://www.golfgtiforum.co.uk/index.php?topic=54324 - it's also called the "lock carrier".
You will need two pairs of axle stands - one to support the front of the car when jacked up, and the second pair to support the radiator and air con condensor assembly. If you have a GTI, and need to remove and/or replace the lock carrier, it would be wise to upgrade the standard intercooler to the better S3 one.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW,
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG, colour coded,
'03 Audi S4 4.2 V8 40v 6sp man, (gone)
