Rochdale based Custom Code Agents
uk-mkivs » The Showroom » Members Rides » Chris.'s golf build thread. Machine Polish and Pics
Last post Fri, Jul 30 2010 2:56 PM by Chris.. 743 replies.
Page 1 of 22 (744 items) 1 2 3 4 5 Next > ... Last »
  • Wed, Aug 13 2008 11:37 AM Chris.'s golf build thread. Machine Polish and Pics
    • Joined on Sat, Mar 1 2008
    • Posts 12,012
    Well, long time since ive posted any pics up here and since ive been polishing and waxing my little heart out, i thought id pop some pics up.  Ill make it a fairly lengthy thread with lots of pics of what Ive done to the car since I got it in the end of february.
    Well, the car started out as a a pretty uncared for Golf by its previous owner.  Paint lacked any depth and shine about it and this is a picture of when I first got the car.
    Pretty bad scratch down the drivers "A" pillar
    Some may say that is already got a pretty decent shine, but the paint had quite a few swirls in the paintwork.  For those who are interested, swirls are caused by using a sponge that collects pieces of grit from the paintwork and bottom of the bucket and the is dragged across the paintwork causing swirls.  You can normally see them on a really sunny day or under a halogen light. A good way to stop this is to use 2 buckets, one with soapy water and another with clean water and a really plush washmitt.
    So, out came my first decent clean of the car. This involved going to halfords and buying the megs 3 step system, from which I had read good reviews about and also some Meguairs Clay.
    So, firstly I started by washing the car and then using the clay which gave a great result as I dont think the paint had been clayed since the car was produced in 2000.  Claying removes the sharp contaminents that remain embedded into the clearcoat of the paint.  If you run your hand over a unclayed car, you will probly feel it has a slightly rough texture to it.  This is the sharp contaminents in the paintwork.  Claying will remove these and leave a good base to use any polish.
    Unfortunately I dont have any during pictures.
    The car was then polished with Step 2 of the Meguairs 3 step process by hand and then two coats of the Carnuaba wax (step 3) was applied to protect the polish and paintwork.
    After 7 hours of the process above, the car looked like this. Unfortunately, I didnt have the products to do the black trim or dress the tyres as I was just starting out in the detailing process and hadnt built up a collection yet.
    Last few pictures show the beading achieved by the Meguairs 3 step process.  Not exactly tight beading and the beads are lacking the height achieved by different waxes. I'll explain it a bit later.
    Next along came a JVC KDAVX-33 headunit to replace the standard VW Gamma radio that was fitted in the car with a lot of help from Imagewerx for helping me with the wiring to allow the headunit to save its memory.
    The headunit is a great one jammed full of features such as a AV in so rear parking cameras can be attached and also bluetooth to allow you to play audio and receive calls through the radio.
    For a full list of specs see here or here.
    Next came a little photoshoot in July. Also, a machine polsiher was bought (silverline Orange rotary and also some 3M Machine polish)  Machine polishing can remove the light swirls inflicted by a poor wash technique with a sponge.
    Also the hit 88,888 miles. Something I just had to take a picture of.
    Onto the 18th July and another machine polish and also the use of Collinite 476S wax.  This is a good wax that can produce great beading. The car had also had a black badge done in heatshrinked vinyl.  The effect and quality is amazing and it saved me a huge amount of money buying a black badge from the internet.  Also, 8000k HIDs were fitted which make a great difference to driving at night. So, after a good machine polish and some Collinite 476S the car was taken for another set of pictures.
    Onto the 20th July and the car got another coat of Collinite 476S which adds a bit more depth to the paintwork and also adds to the durability of the wax, which is a long time.  Some say it can last 6 months and not need another coat of wax, so its a ideal wax for those winter months where you need to protect your car from those nasty elements the winter brings such as road salt and other bad things.
    I decided I would remove all the stone chips and scratches from the car.  My plan of attack here was to use wetsanding.  Firstly I would touch any scratches and chips up on the car and then flatten the touch up paint back with some 2500grade wet and dry.  I wouldnt reccomend any lower grade as it just gets harder and harder to remove the scratches caused by the sandpaper.
    Heres a few during pictures of the wetsanding process.  I wouldnt attempt this unless you have read about the topic in depth as too much can cause more damage than what you intend. Such as sanding through the clearcoat and into the paint layers possibly taking it right down to the bare metal and needing a respray.
    Onto the polishing out the scratches with a machine polisher and some 3M Fast Cut Plus
    The perfect results can be achieved if you are willing to put the time into the car and do the job properly.  ive only managed to get the bonnet done so far and Ive proberly been going at the wetsanding a month.
    Another coat of Collinite was added and the car stands like this on the 6th August.  These pictures focus on the beading that Collinite can achieve.  As stated before with the Meguairs Carnauba wax and the beads being flat and not tight, this wax shows you the difference between the two products.
    As you can see, the beads are alot closer together and stand higher than those produced by the Meguairs Step 3 Carnauba Wax.
    Then, the car had the "B" pillars done.  After looking at threads with this mod done before, I decided to buy myself some black fablon and give it a go myself.  Heres the results
    And onto the 11th August where the car had got another coat of Collinite 476S and taken for a few more pictures.
    Next along came a InCarPC.  I planned to build it into the double din area of the radio cage.  The PC spec has to be good and also consume low power due to only having a limited supply of power from the cars battery before it run out.
    Basically I was looking for a OEM look screen built into the dash which would offer me music, internet access, GPS navigation, diagnostic software and monitoring tools.
    Here's the specification i have chosen for my system.
    All my goodies come today.
    I have the PC up and running Vista Ultimate. :smile:.
    I just need some PSU wire for extending the current wires, inline fuse and a few other bits.
    I ordered the non touchscreen so Im going to have to return that and get the touchscreen version instead.
    But all is running fine, heres a few pics of the board and PSU.
    Ordered my touchscreen from Linitx
    Also, got the interior part out of the car to give the PC a trial fitting to ensure I have enough room for everything.
    Heres the pictures:
    Looks like I have enough space for everything.  I need to make a MDF or plywood board, in the shape of the little door to allow me to mount all of the PC gear to that on standoffs.
    Bought a spare radio cage off a lad off here and began to get to work mounting the screen into it.
    Got the PC mounted in the dash tonight.  What a job that was having to remove all the centre handbrake and gear trim surrounds.
    While I was on that, I mounted the headunit into the glovebox.
    Thats secured the headunit in the glovebox.
    Then it was onto mounting the screen into the dash.  A lovely picture of my dash with all the wires out.
    Then it was onto reassembling.  It was tortue getting my hand up behind the glovebox to fit the Headunit wires in to their slots.
    Just got a few more nigglety bits to sort out:
    • The 'wood effect' surrounds.
    • Lengthen the cables for sub and amp
    • Modify the heater control plastic cover so that it will fit.
    I got my wire from maplins (rather generous i must add).  But i still need to get some more for powering the screen from the PSU so it doesnt suck power from the cig lighter.
    Also waiting for my audio and VGA leads coming; hopefully tomorrow Big Smile
    Anyhow, for the progress.
    I have mounted the components in the back of the cubby hole on the MDF board ive cut out.
    Still not sure what to do with the color of the MDF, i might just leave it for now, but ultimately, id want it to look as good as possible.
    I have a few more pics of the  screen mounted in the dash.  I still have to spray my aweful looking wooden surrounds black, if only BnQ would let me buy some spray paint.  Must think im gonna get high.  If i wanted, id just go to the petrol station.....
    But anyhow, heres the latest pics.
    After the carPC was installed and running well. I decided I wanted to upgrade my speakers in the doors.  For this I wanted good sound quality so decided to go for Rainbox SLX265 amped by another Vibe Slick A2 amp.
    I choose another Slick A2 amp as I decided to make a little shelf/built in look box to allow me to mount them amps on top of each other.  This would keep the boot area tidy and allow me to fit the amps in neatly.
    I measured the space between my sub and the side of the boot and fabricated a box out of 12mm MDF with a single shelf for me to mount my amps.
    (Cant find any during pics so only have finished ones)
    March 2009
    I decided I wanted to color code my bumpstrips.  I started with the bumpers and got to work spraying them.
    I still have the side rubstrips and handles to complete but need to wait for a good fine day for spraying them
    Next along came a centre armrest from Germany.
    No installed pictures :(
    After seeing a carPC install in a Octavia VRS, I decided that I wanted my screen to look a bit more OEM built in.  So I ripped my radio caging back out and put the headunit back in.  I set to work cutting down the casing of the LCD touchscreen and build it into the double din area of the radio cage instead of it also taking up the cup holder area.
    Touchscreen Update
    After see'ing a VRS with a nicely moulded touchscreen, I decided to give it a go myself.  I set about taking the monitor apart and began moulding the casing into the centre console.
    Thats the front bezel cut down to size and glued into the cage.
    That wasnt the final finish I managed to get.
    I decided to give it a test run to see what it would look like....unfortunately...disaster.
    I wired it up wrong and caused the components on the board to exploded leaving my room smelling pretty funky for a while.
    I replaced the voltage regulator and the capacitior on the board, but unfortunately, this hasnt made any difference so I think the board is dead.  I have got a quote for a new board, but need to find myself the £30 to cover the costs of a new one from manufacturer.
    Accident 09/04/2009
    Had a bit of a run in with a Chitreon C5 on a roundabout who was flying round in a rush on the outside lane to go right around the roundabout.
    Fortunately, I have a independant witness who says the other driver was at fault.  I just wish my insurer would pull their finger out their rear and get on with it.  Been 2 weeks since I submitted my accident form for them to look at, and its not the 24th May.
    Color Coded Sharan Badge + Extra
    Decided I liked the look of a sharan badge, so set off to VW to order a sharan badge, and halfords for some spray paint.  Rover GunMetal grey.
    Test fitting:
    And completed.....Also color coded my GOLF badge for a bit of uniqueness Smile
    So there we have it, my car from when I bought it to todays current date.  I forgot to mention that the car has a Vibe SLR 12" sub and slick A2 amp in the post.
    So, I hope I have all the pictures in the right order, and havent duplicated some.  If you want to see all my collection of pictures, I suggest you have a look in my photobucket album or my personal website gallery where you can see higher res pics in larger dimensions found here.
    I hope I havent bored you with the write up and any comments are welcome.
    Chris
    Click for build thread.
    Dent Reform: Mate my alternator makes more power than an KO3s Big Smile
    AidenUK: Totally off topic but your sig has just nearly caused me to choke on my pizza! Yes
  • Wed, Aug 13 2008 11:54 AM Re: 1.4S golf 56k - no go!
    IbanezDan51
    Golf IV GTI 1.8T 20v Quattro APY 210PS
    • Joined on Tue, Aug 5 2008
    • Posts 3,983
     Excellent post mate! some great advice!
    I did a search on black fablen? but no results? what is it? was it used to black your b posts?
    Im looking at doing this, I heard someone used vinyl? but they didnt say if it was stick on or not? I assume it was...lol
    Any ideas would be well appreciated!
    The boring TDI build: http://uk-mkivs.net/forums/t/229650.aspx
    The Quattro GTI build:http://uk-mkivs.net/forums/t/302090.aspx
    Loads of stuff for sale:Half FIS Bora SPORT IMMO3 clcoks, bumpers, valances,seats...just pm me if you need anything.
  • Wed, Aug 13 2008 12:04 PM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    Hi and thanks for the comments.
    The product is actually spelt "Fablon" and I had made a typo which ive corrected.  The stuff is vinyl and Ive found that its self adhesive and sticks to clean paintwork well.  You can get a 1.6M Width roll from BnQ for £4.99.
  • Wed, Aug 13 2008 12:30 PM Re: 1.4S golf 56k - no go!
    IbanezDan51
    • Posts 3,983
     Thanks Chris! your a star!
    How did you find fitting it? any air bubbles seem to get trapped?
  • Wed, Aug 13 2008 12:35 PM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    Fitting was a bit fiddely. I found the rear windows the hardest to do as I couldnt get the lower seal out to get the vinyl tucked behind it.
    Air bubbles werent that difficult to avoid, if you smooth the vinyl up with your finger so you are pushing all the air to the part that hasnt been stuck down yet (if that made sense :))
  • Wed, Aug 13 2008 2:26 PM Re: 1.4S golf 56k - no go!
    chris_golfse
    • Joined on Wed, Dec 12 2007
    • Posts 1,438
    looking good! what else do you have planned for your car? its crying out for some alloys tho lol!
    Good bye golf, hello warrior!
    My build up
  • Wed, Aug 13 2008 2:31 PM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    Not sure what I have planned at the minute.  Im practically almost saving up for a 115 GT TDI for next year.
    I have some 1.8T 20V alloys in the garage, but cant get insured on them, so in contact with the insurance asking them why when they could be bought as a optional extra.
  • Wed, Aug 13 2008 2:47 PM Re: 1.4S golf 56k - no go!
    chris_golfse
    • Posts 1,438
    yeh i thought about that, but by the time i change my car..
    £80 plate transfer
    £50 advertsing
    £ money lost in car
    £all teh mods ive done
    £insurance increase
    i thought id keep with mine for a while!
    id change insurers next year then, my insurance company didnt even charge me extra for mine!
    My build up
  • Wed, Aug 13 2008 4:56 PM Re: 1.4S golf 56k - no go!
    IbanezDan51
    • Posts 3,983
     Well Chris...I can tell you now...ill take you for a ride in mine if you clean my car like you have yours! lolol
    Superb job mate, id go as far to say one of the cleanest cars on here lol
  • Wed, Aug 13 2008 5:17 PM Re: 1.4S golf 56k - no go!
    mr_wigster
    • Joined on Mon, Nov 6 2006
    • Posts 10,644
    Hi Mate,
    I've always thought the quality of the car is 90% in its overall condition and yours looks absolutely mint now.  Top work.  Yes
    Wigster.
  • Wed, Aug 13 2008 7:31 PM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    IbanezDan51:
    Thank you very much for the really kind comment.
  • Wed, Aug 13 2008 7:32 PM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    mr_wigster:
    Hi Mate,
    Wigster.
    Thanks Wigster.  Id never believe the cars paintwork was 8 year old.  Spending a little time can transform a car 110%
    Thanks again! Beer
  • Wed, Aug 13 2008 8:27 PM Re: 1.4S golf 56k - no go!
    sr2005uk
    • Joined on Wed, Aug 13 2008
    • Posts 57
    Nice car!
  • Sat, Sep 13 2008 11:10 AM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    Few more pics after I went over it with Autoglym SRP, Megs #7 Show car glaza and some colly
  • Sat, Sep 13 2008 1:09 PM Re: 1.4S golf 56k - no go!
    trogolodyte
    Passat Models
    • Joined on Wed, Jul 16 2008
    • Posts 159
     That is some effort there mate, looks really good though man, the perfect reflections your getting on there are lookin pretty sweet.
    Turbo 1.8 Passat Estate!
  • Sat, Sep 13 2008 6:35 PM Re: 1.4S golf 56k - no go!
    shain
    • Joined on Wed, Sep 10 2008
    • Posts 12
    you got some skills mate. . want to clean mineSmile. . . only joking
  • Sun, Sep 14 2008 6:07 AM Re: 1.4S golf 56k - no go!
    AlexMK4
    • Joined on Thu, Apr 17 2008
    • Posts 92
     Your front badge looks really cool but to be honest I don't think your car suits the B-pillar mod.
    Ever thought about debadging the Golf of the back? Smile
  • Sun, Sep 14 2008 7:49 AM Re: 1.4S golf 56k - no go!
    • Posts 12,012
    Thanks for the comments.
    No I havent thought of debadging the back, but I did want a black badge to go on the back.  Doesnt it leave a recess when the badge has been taken off?
  • Sun, Sep 14 2008 7:56 AM Re: 1.4S golf 56k - no go!
    shammy
    • Joined on Mon, Mar 10 2008
    • Posts 1,248
     Awesome write up fella. Your doing some good stuff when it comes to your cleaning skills, fair play Yes
  • Wed, Mar 18 2009 6:15 PM Re: Chris.'s 1.4S golf build thread.
    • Posts 12,012
    Updated from the Car PC installation.
    No dates as this wasnt a build thread until tonight Smile
  • Sat, May 23 2009 8:07 PM Re: Chris.'s 1.4S golf build thread.
    Tribal
    • Joined on Mon, Apr 6 2009
    • Posts 60
    Just wondering how this is getting on at the moment?
  • Sun, May 24 2009 8:23 AM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    • Posts 12,012
    Updated from Touchscreen update. Wink
  • Mon, Jul 27 2009 12:06 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    Golfedd
    • Joined on Wed, Mar 4 2009
    • Posts 3,869
     GET OVER HERE
    http://uk-mkivs.net/forums/t/287982.aspx
    Pleaaaaaaase
    Offset is nothing without width and drop
    1.8T Conversion
    *A-Video-A-Day*
  • Mon, Jul 27 2009 12:27 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    alex-atari
    Golf IV 1.6 16v BCB 105PS
    • Joined on Sat, May 24 2008
    • Posts 5,216
    good write up Chris, added some nice touches to the motor.
    Particularly like the colouring of the badge and GOLF badge and the nice big screen to Yes
    Lovely colour that green to In Love
  • Mon, Jul 27 2009 12:38 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    Antvw
    • Joined on Mon, Jun 23 2008
    • Posts 2,078
    Looks soooooooooooo clean!
    In the first pic, did you get that scratch out yourself?
    Ant Yes
    Genuine R32 wheel for sale mint condition. 14th july. 2010.
  • Mon, Jul 27 2009 12:47 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    • Posts 12,012
    Its not totally out, but looks alot better.
  • Sat, Aug 29 2009 10:49 AM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    JDB_91
    Golf IV Match 1.6 16v BCB 105PS
    • Joined on Sat, Apr 11 2009
    • Posts 285
    whats the Vibe slick sub like? Also how does your headunit/pc work? did it cost much to do? im intrigued! great work youve done on the car mate its looking good
  • Sat, Aug 29 2009 12:14 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    • Posts 12,012
    Vibe sub was good.  nice amount of bass behind the music.  Great if you dont want all bass.
    THe PC audio is connected to the AV audio inputs on the headunit.  Now everything is amped. I could get 4.1 surround sound and wire them up to the amps with an external soundcard.
    ICE install  has all changed now.
    Will update laters.
  • Sat, Aug 29 2009 5:14 PM Re: Chris.'s 1.4S golf build thread. Updated from Touchscreen moulding into dash. + accident
    • Posts 12,012
    Well, I was getting a bit sick of the old Vibe sub and amp so decided to go for the new SNG Audio JATT series sub for £100.  Paired with a Vibe Black Box Bass 4 pushing 900WRMS at 2 ohms, this would be more than enough to give the sub the juice it needs.
    Having ran the sub in a small 1.5cuft sealed box, it didnt really feel up to the job at all.  So, to keep me out of boredom, designed a 2.5CuFT ported box to the manufacturer specs.
    I got the wood cut by a local sawmill/timber yard.  Alot easier than trying to do it yourself.
    A quick mock up of the box
    Began to build the box up.  It was clamped tight with some sash clamps while the screws were screwed in to make it nice and airtight.  It was also glued with glue.
    The front hole was also cut out by my dad with a router.
    Trial fit of the brace to stop box flex
    Got the rest of the box screwed up and painted the port insides
    Top gets screwed on
    Sub was carefully moved into the car, it only goes in one way and is more tighter than erm....cant think of anything Big Smile
    Wiring is a lovely mess.  but there are too many amps to try and keep it tidy.
    Sub is a great fit for the golf boot.
    Still need to get the sub carpetted and also im wanting to test the DB that its kicking out.  Shame I dont know anyone with a meter.
  • Sat, Aug 29 2009 5:18 PM Re: Chris.'s 1.4S golf build thread. New custom sub box.
    • Posts 12,012
    You can see the full sub box build thread here
  • Sat, Aug 29 2009 6:20 PM Re: Chris.'s 1.4S golf build thread. New custom sub box.
    nickturbo
    • Joined on Wed, Jan 7 2009
    • Posts 2,333
     WOW!!!!
    amazingly clean. well done on the pc build, id be absolutely lost in trying to do something like that.
    how come you wax it so many times if it lasts for 6 months or so???
    does adding another coat make it bead better?
    My build thread
    IT'S NOT A RACE IF I'M ALREADY ONE STEP AHEAD !
  • Sat, Aug 29 2009 6:33 PM Re: Chris.'s 1.4S golf build thread. New custom sub box.
    drfeelgood
    • Joined on Sat, Feb 21 2009
    • Posts 3,085
    Wow I missed your PC install, nice work there. What's happening with that now then, going back in?
    Chris.:
    Blasphemy Christopher! I've seen the entire area where back seats used to be full of amps and not an out of place wire in sight. If you have the patience to do the amount of tidying up that you've done to your bodywork, getting down to business with some cable ties should be pretty painless.
    Is it wrong that I look at that pic and can imagine where every wire SHOULD be and try to figure out the neatest path to take lol. Embarrassed
    • Posts 12,012
    It just keeps the depth to the paintwork and keeps the beading nicely.
  • Mon, Sep 28 2009 5:37 AM Re: Chris.'s 1.4S golf build thread. New carPC monitor has arrived. :)
    • Posts 12,012
    Well, good news.  Another monitor is here ready for me to butcher and mould into the dash.  I took plenty of pictures this time so I dont get the wiring wrong Big Smile  Ive learned from that foolish mistake that cost me £180. Sad
    The entire monitor needs dismantling so I can get to the front bezel (unfortunately I smashed old one out and could have used that, so need to make a new one instead.
    Going to start moulding it in again today.
  • Mon, Sep 28 2009 10:13 AM Re: Chris.'s 1.4S golf build thread. New carPC monitor has arrived. :)
    • Posts 12,012
    More progress.  Got the monitor cut down to double din size so it fits between the cup holder and the fan controls.
    Trial fit before gluing the surround in.
    And glued.
