I have the following fault with my recently purchased V6 4 Motion - when the engine's cold and the climate control is switched on the air con compressor pulley and its inner centre rotates fine. However, when the engine gets hot the outer pulley turns fine but the inner centre starts continually sticking, consequently making a noise every time it sticks, until finally the inner centre starts jamming. Let the engine go cold again and the inner centre turns normally as the air con pump clutch cuts in and out as normal, with no noise.
There is no cold air anyway so the air con obviously needs a re-gas, question is could the lack of pressure due to no gas cause the inner centre of the pulley to stick/jam i.e would re-gassing cure it? Or is the air con compressor simply knackered (not sure why there's no inner centre sticking problem when the engine's cold though)? Obviously if the pump's knackered I'd rather not waste my money re-gassing it until the compressor's changed!
Anyone had similar problems? Scanned the other threads but couldn't find this particular fault.
Any thoughts most welcome!
Cheers!
