Hi Chris - Where the yellow part is - that needs a straight piece of hose - not a reducer. As the new turbo has a larger diameter inlet.
Red part - my new turbo outlet is totally smooth, no flanges or clip assembly. So that needs a larger piece of hose to slide over the metal outlet, then the old hose with the funny clip mechanism on slides into that with a jubilee clip or equivilent on.
Having said that, the turbo you get might use the standard compressor housing like the one above and then you might not need the mods.
Or it could come back different to mine and the Oe housing. The name hybrid can mean different things to different companies and of course different specs to the compressor housing ./ compressor wheel etc.
Link removed - please see rules re. advertising.
