Hey all.
My 1999 mk4 golf gti-turbo (agu engine) has had a fault since I’ve had it and myself, or the dealer have been unable to rectify it. To give you a brief idea of the fault, the engine power violently cuts (like fuel cut) when it’s either under load, ie; a hill start or quick get away from standing, or as you back off the throttle when over taking etc. The vehicle also seems to be underpowered and a boost guage shows no more than 5psi which drops off to almost 0psi at about 5000rpm. The fault code it keeps coming up with on vagcom is “manifold absolute pressure limit exceeded”. Now being a fully trained technician and having it looked by a friend who is a master tech at V.W, we have been totally baffled by the cause after testing and replacing the following;
- New K03s turbo (old unit had a large crack through to wastegate)
- New airflow meter and wiring checked as far back as possible.
- Tested N75 boost valve (Originally had no power to it, found the feed off the fuel pump to be faulty – repaired, problem still present.)
- New water temperature sensor.
- Replacement E.C.U fitted and coded.
- New exhaust system including De-cat, in case cat blocked.
- New Forge re-circulating dump valve.
- Removed complete boost system and intercooler and checked for splits/breaks/damage etc – no faults found.
- Fuel system/pressure checked and new 4bar pressure regulator fitted.
- Checked for map sensor and wiring, but no map sensor fitted to vehicles of this age.
If you guys have any ideas I’d be extremely grateful, however I’m also considering having a 225 bhp TT conversion done on it and was wondering if anyone knew of any major problems that would urinate on mt bonfire!!!
Thanks in advance peeps.
If it aint broke, fix it till it's boke!
