Suppliers of customised car mats and VAG parts
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Clutch and Gearbox » VW Golf GTI 150 - Flywheel & Clutch Kit
Last post Sat, Sep 6 2008 12:25 PM by saads7. 3 replies.
Page 1 of 1 (4 items)
  • Fri, Aug 22 2008 5:45 PM VW Golf GTI 150 - Flywheel & Clutch Kit
    saads7
    • Joined on Wed, Nov 21 2007
    • Posts 15
    Just taken the car to the 'stealers' for service and they have diagnosed rough idling and judder from the engine as a suspect flywheel.
    On this basis I am now looking to replace the flywheel and clutch plate and I have a few questions:
    1.  Has anyone done this before and can recommend a particular brand or kit to purchase?
    2.  Cost involved?
    3.  Is the fly wheel a single or dual mass?
    I have been told that I require a kit for engine code ARL as mine is a 150bhp GT TDI and should have the following part numbers:
    Dual Mass Flywheel part No: 2294 003 341
    Clutch Kit Part No: 3000 990 043
    Should I replace the bearing at the same time, this is something someone has recommended I have should done?
    Any thoughts and comments would be appreciated.
    Cheers.
  • Thu, Aug 28 2008 2:11 PM Re: VW Golf GTI 150 - Flywheel & Clutch Kit
    saads7
    • Posts 15
    Have had the job done, and now my pocket is £500.00 lighter... lol
    Went for a SACHS Dual Mass flywheel and Clutch Kit and you know what, the difference is AMAZING!
    No more judder, vibrations or issues whatsoever.
    It puts the powerdown so much smoother and easier its unbelieveable!
    Thank God I had it done before it caused serious issues with my gearbox Big Smile
  • Thu, Sep 4 2008 3:41 PM Re: VW Golf GTI 150 - Flywheel & Clutch Kit
    big_h
    • Joined on Fri, Aug 29 2008
    • Posts 51
     where did you get it from mate?
    pd tdi 150 ARL, kw v2's, allard delete pipe.
  • Sat, Sep 6 2008 12:25 PM Re: VW Golf GTI 150 - Flywheel & Clutch Kit
    saads7
    • Posts 15
    Local garage supplied, fitted and did a pretty damn good job I must say!
    From what he told me, he sourced the parts from local Dealers and rekons they the original VAG parts?
