North East based VAG performance, tuning, suspension and styling specialist
uk-mkivs » The Mk5 (MkV) Community » MkV (Mk5) Golf, Golf Plus & Jetta Discussion » Poor cold starting and auto lights
Last post Tue, Sep 2 2008 1:23 PM by Gloves. 16 replies.
Page 1 of 1 (17 items)
  • Mon, Aug 25 2008 10:26 AM Poor cold starting and auto lights
    gmac00
    • Joined on Mon, Aug 25 2008
    • Posts 9
    Hi,
    I have had my 2007 JettaTDi 140 Sport for over a week now and I am really enjoying it.
    I have moved over from a Mazda RX8 and although I do miss the handling of the Rex the torque from this car more than makes up for it, had to use the gears constantly to get anywhere in the Mazda, also 45mpg compared with 18mpg puts a smile on your face
    Anyway...my questions.
    1. Cold starting:
    When I start the car in the morning more often than not the engine stalls, it will move to about 600rpm then just dies. When it does start OK it goes to 600rpm for a second the moves to normal idle speed. Once it is running I have no further problems.
    Any thoughts on this?
    2 Auto lights???
    What is up with them? I was driving along the M8 yesterday and it was sunny day which makes a change and they come on. Turn them of for a bit then back onto auto to see if that corrects them but no, they are still on
    On the flip side of that, this morning it was dark and miserable, raining and horrible........British Summer Time and they would not come on??
    Again any thoughts?
    gmac00
    Jetta 2.0 TDi Sport
  • Mon, Aug 25 2008 12:33 PM Re: Poor cold starting and auto lights
    golfgtdude
    • Joined on Tue, Aug 22 2006
    • Posts 238
    hello matey,
    right, cold starting issue. I have this intermittently 1st thing in the morning on my mk5 golf gt tdi and have done since new. Start in the very same way, sluggeshly fits low rpm them conks out. However on restart it sounds groggy then as the revs climb to 1000.
    VAGCOM reports and has done from new, that I have malfunctioning glow plug and that will probably explain why cold starts on mine are sometimes odd. Possibly the same on yours??
    As for the auto lights, check there is no dirt on the wind screen out the outside inline with the area where the rear view mirror fits - this is where the sensor lives to detect light. I know there have been some issues on here where peeps have had their windscreens changed and it's messed up the sensitivity of this sensor.
    You can (i think) use VAGCOM to tweak the sensitivity so they don't come on so easy.
  • Mon, Aug 25 2008 12:38 PM Re: Poor cold starting and auto lights
    C7KWC
    • Joined on Wed, Jun 11 2008
    • Posts 242
    Auto lights on my Golf come on automatically when i go above 60mph regardless of the weather
    Think its supposed to be a safety feature!
    Your car will be under warranty wont it?
    Golf Mk5 GT Sport 140 Tdi 08
    Golf Mk5 Gt 140 Tdi 05
    Vauxhall Vectra Club 120 Dti 53
    Ford Escort 1.8 Si 97
  • Mon, Aug 25 2008 12:40 PM Re: Poor cold starting and auto lights
    radox
    Golf V SE 1.9 TDI 105PS
    • Joined on Sun, Jun 13 2004
    • Posts 339
    Can't help with your car's cold starting problem. Does not sound normal to me.
    Regarding your auto-lights. I think the system is based upon detecting a difference in UV light levels from the front and back of the rear view mirror (where the sensors are located). At dawn and dusk, when the sun level is low and there are large shadows, this does seem to trick the auto lights into coming on and staying on. I don't believe this is a fault - rather, it's just the way the system works.
    Similarily, even though it might be quite cloudy, light levels may still be high enough to prevent the auto lights coming on.
    Personally, I find the auto-lights work very well most of the time but sometimes I need to manually force them to come on.
    Enjoy your new car,
    Stuart
    http://www.stuartdalby.co.uk/vwgolfmk5
    2005 model year Mk 5 VW Golf 1.9 TDI SE, 5 door.
    With Shadow Blue metallic paint and Luxury Pack 1 (Surrounding Area Lighting and Electrically folding mirrors)
  • Mon, Aug 25 2008 12:58 PM Re: Poor cold starting and auto lights
    gmac00
    • Posts 9
    golfgtdude:
    Sounds like my problem!!
    The car is only a year old so is still under warranty, will get it checked out.
    gmac00
    Jetta 2.0 TDi Sport
  • Mon, Aug 25 2008 1:04 PM Re: Poor cold starting and auto lights
    golfgtdude
    • Posts 238
    recently i've noticed mine becoming more regular now with higher mileage. starts okay when warm. only seems to be evident when it's been sitting overnight or for a long period.
    I used had use of a another gt tdi prior to my current and it used to be exactly the same, used to crank over a coupe of times then conk out just as you though it would start.
    Like you say, runs fine when it's on though.
    I'll probably mention it at my next service but obviously can't tell them i've been checking it out with VAGCOM or they'll think i'm a fiddler!
  • Mon, Aug 25 2008 1:14 PM Re: Poor cold starting and auto lights
    gmac00
    • Posts 9
    I will wait for a week or so before taking it to the dealers to see if any other little problems pop up.Hmm
    thanks for the advice.
    gmac00
    Jetta 2.0 TDi Sport
  • Mon, Aug 25 2008 2:53 PM Re: Poor cold starting and auto lights
    Nobby
    • Joined on Mon, Oct 22 2007
    • Posts 39
    C7KWC:
    Mine come on round about 90mph ish (on a race track of course), must be a setting somewhere!
    GT170 DSG.....and a whole load of goodies.
  • Mon, Aug 25 2008 4:07 PM Re: Poor cold starting and auto lights
    gmac00
    • Posts 9
    Next time I am on a "track" i will checkBig Smile
    Jetta 2.0 TDi Sport
  • Wed, Aug 27 2008 1:22 PM Re: Poor cold starting and auto lights
    Lynsey
    Golf V GT TDI 2.0 170PS
    • Joined on Mon, Jul 17 2006
    • Posts 573
    I have read somewhere that the headlights come on when you've gone over a certain speed and stay on and won't go off again until you've driven under a certain speed for a certain time.  This is certainly what happens with mine - they are often on during motorway journeys and remain on for the duration Smile
    I don't mind in the slightest - any excuse for the xenons Wink
    I've had a new windscreen, the lights behave the same as before including their sporadic behaviour at times! The wipers on the other hand are mental now!
  • Wed, Aug 27 2008 1:47 PM Re: Poor cold starting and auto lights
    C7KWC
    • Posts 242
    Nobby:
    C7KWC:
    Your probably right, 60, 90 same thing!!!  It annoys me because im sure people pull out on me because they think im flashing them out! Angry
  • Wed, Aug 27 2008 1:50 PM Re: Poor cold starting and auto lights
    C7KWC
    • Posts 242
    Lynsey:
    If i had xenons i would also keep them on!
  • Wed, Aug 27 2008 3:57 PM Re: Poor cold starting and auto lights
    gjv0001
    Golf V R32 3.2 250PS
    • Joined on Wed, Jan 4 2006
    • Posts 141
    As for the auto lights, they come on over about 140kph (87mph) automatically for a defined period and go off after about 64kph (40mph) again after a certain time (30 secs or so- can't remember). Don't 4 get, this isn't usually ur speedo as it's a golf so it'll be out by a bit. minr is out about 9%
    Also, I've not found in VAG.COM that u can change the timing of these or the sensitivity.
    2007 MKV .:R32 | 3dr | OEM LED Rear Clusters | K&N | Rear Tints | 6000k HIDs |
  • Thu, Aug 28 2008 7:53 PM Re: Poor cold starting and auto lights
    Sean_Jaymo
    • Joined on Sat, Oct 29 2005
    • Posts 2,163
    Knowing how Lynsey drives, I don't think hers are set to 140kph!
    VR6 Is my new toy!
  • Mon, Sep 1 2008 8:28 AM Re: Poor cold starting and auto lights
    Lynsey
    • Posts 573
    Sean_Jaymo:
    lol Chuckle the bloody cheek!
  • Mon, Sep 1 2008 3:19 PM Re: Poor cold starting and auto lights
    iannmil
    • Joined on Sat, Mar 19 2005
    • Posts 8
     I agree with the posters  regarding auto-lights coming on at set speeds and then off again after a period of time at a lower speed. I also found that they did seem to have a mind of their own during daylight hours, with no definitive pattern as to when they would come on.
  • Tue, Sep 2 2008 1:23 PM Re: Poor cold starting and auto lights
    Gloves
    • Joined on Sun, Jul 27 2008
    • Posts 24
     Your cold start problem is the same as I had until recently. Booked it in with dealers Wayside and left it with them for a few days and it has started perfectly now every time since. They advised that there is a VW software upgrade to the ECU. It worked for me.
