Auto Gym - Muscle for MOtors
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Tuning Forum » allard race pipe
allard race pipe
Last post Sun, Aug 31 2008 2:57 PM by akgray. 18 replies.
Page 1 of 1 (19 items)
  • Wed, Aug 27 2008 9:41 PM allard race pipe
    mcisaac08
    • Joined on Sat, Aug 23 2008
    • Posts 19
     fit like everybody another question for yi,s. as you know am changing engines in my 150pd arl golf and i was thinking of putting on an allard race pipe so i can take the egr valve out! but iv heard this can cause the engine managment to come on?Confused is this true and is there any gains from putting one on???. and has anyone got a powerflow exhaust on theres? the thing is my one has a loud whistle from it at around 3500rpm i have the twin 3" ovals on back and car still has the cat fitted. would it benifit from a large bore decat(allard) and would it get rid if the noise? my cousin has a 306 hdi with a powerflow too and his also has a whistle to it up the revs.cheers
    magic
  • Thu, Aug 28 2008 1:25 AM Re: allard race pipe
    akgray
    • Joined on Wed, Nov 29 2006
    • Posts 315
    No problems getting rid of the egr. No warning lights on mine and a good mod imho. Not sure about the exhaust but just put a cat free downpipe on mine and again I think its worthwhile.
    312mm front discs. EGR removed. DeCat, Forge Quick shift, De locked, Anni Wheels. VAGCOM
    Also got a 1430cc mini with 110hp (fly)
  • Thu, Aug 28 2008 2:45 AM Re: allard race pipe
    SiGainey
    • Joined on Mon, Mar 6 2006
    • Posts 367
    mcisaac08:
    I didn't fit the Allard race pipe, but I did blank off the EGR and I do get an ECU fault and "emissions workshop" everytime I start the car. Hope to remove the blanking plate this weekend....
    2004 Bora Sport 150 TDI | OEM Xenons | Cruise | 17" Longbeaches | Aero Wipers | Sports seats | Miles to empty
    2001 Golf Mk4 V5 170 :)
    If you found this post useful, please sponsor me :)
  • Thu, Aug 28 2008 6:21 AM Re: allard race pipe
    leach76
    • Joined on Sat, Nov 10 2007
    • Posts 429
     Sorry for jumping in on this post but thats what is worrying me,the above posts both have ARL engines but one is getting no lights etc for doing this but one is?? i have been told you can turn the egr valve down or off,is this true and will it help/make a difference to the light if so
    02 GTTDI 150,RUNNING GIAC REMAP 195-ISH,FULL MILLTEK SYSTEM,ANNI LAMPS + OTHER LOW COST TWEAKING TO BE DONE!!
    Sheffields Finest
    MADE BY THE DEVIL,DROVE BY A GOD!!!!
  • Thu, Aug 28 2008 6:27 AM Re: allard race pipe
    SiGainey
    • Posts 367
    I think it's to do with age - mine's an 04 plate
  • Thu, Aug 28 2008 1:50 PM Re: allard race pipe
    ColinT
    • Joined on Mon, Mar 14 2005
    • Posts 116
    I had an Allard stage 3 conversion fitted recently.  The garage changed the map so the light went out.
    More smiles per mile in the 220bhp/324 ft-lb oil burner Big Smile
  • Thu, Aug 28 2008 5:21 PM Re: allard race pipe
    mcisaac08
    • Posts 19
     ok cheers guy,s will go for it and let you know if there is any faults coming upYes
    magic
  • Fri, Aug 29 2008 9:42 AM Re: allard race pipe
    big_h
    • Joined on Fri, Aug 29 2008
    • Posts 51
     just orderd one of these myself
    hope i dnt hav any problems with it.
    pd tdi 150 ARL, kw v2's, allard delete pipe.
  • Fri, Aug 29 2008 9:52 AM Re: allard race pipe
    big_h
    • Posts 51
     just read that the anti shudder is removed when you fit the allard pipe
    what does this mean?
  • Fri, Aug 29 2008 10:23 AM Re: allard race pipe
    azzle123
    • Joined on Sat, Feb 24 2007
    • Posts 1,525
    It means the car jolts a little when you turn the ignition off. Its nothing more than closing a door. Renault diesels dont have the anti shudder. I wouldnt worry too much about it.
  • Fri, Aug 29 2008 5:11 PM Re: allard race pipe
    mcisaac08
    • Posts 19
     let me know if you notice any difference with the allard pipe. am hopfully going to get new engine fitted next sat am home fri so it,s gona be a dry weekend for meIck! . so guy,s is it true you lose some ft-lb when you fit a large bore de-cat iv read on some forums you lose but gain on bhp? i thought it would be better other way round??Geeked.
    magic
  • Fri, Aug 29 2008 5:18 PM Re: allard race pipe
    azzle123
    • Posts 1,525
    When i replaced my allard pipe, i cleaned the intake manifold aswell. The car became alot more responsive. On my test strip (LOL) i can now hit 85 with a full tank and 1 passenger, before i was lukcy if i seen 80 with a full tank and no passenger.
  • Fri, Aug 29 2008 7:16 PM Re: allard race pipe
    mcisaac08
    • Posts 19
    Yes will do that cheers. what did you use? carb cleaner??
    magic
  • Fri, Aug 29 2008 7:56 PM Re: allard race pipe
    azzle123
    • Posts 1,525
    Soaked it in a box of parafin for a few days. Then rinsed it down with hardcore degreaser i got from a mates garage.
  • Fri, Aug 29 2008 9:07 PM Re: allard race pipe
    mcisaac08
    • Posts 19
     sorted will do cheers budYes will put pic,s up next week. thanks
    magic
  • Sat, Aug 30 2008 5:35 AM Re: allard race pipe
    big_h
    • Posts 51
     thanks for the info.
    is it true you get a bit more power after fitting the egr replacement?
  • Sun, Aug 31 2008 8:47 AM Re: allard race pipe
    akgray
    • Posts 315
    Probably no more but you will go back closer to what it should be, if you remove all the gunk.
  • Sun, Aug 31 2008 9:56 AM Re: allard race pipe
    big_h
    • Posts 51
     cool should be here next week.
    do you have to remove the manifold as well to clean the gunk?
  • Sun, Aug 31 2008 2:57 PM Re: allard race pipe
    akgray
    • Posts 315
    Makes it easier, you dont want big lumps of chod going into the engine.
