uk-mkivs » The Mk4 (MkIV) Community » MkIV (Mk4) Golf & Bora Discussion » V5 Engine,Please Explain It
Last post Tue, Sep 2 2008 8:59 AM by Coggy. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Sep 1 2008 1:59 PM V5 Engine,Please Explain It
    • Joined on Mon, Apr 9 2007
    • Posts 14,334
     I was driving the other day and we went past a V5,my passenger asked about the engine.I didn't know the answerEmbarrassed
    How does it work,does have a bank of 3 and a bank of 2? V6 is a bank of 3 and another bank of 3 right?
    Patch's Car
    RRP
    Chris Wales: "Rat look - the poorest excuse for owning a complete shed of a motor"
  • Mon, Sep 1 2008 2:08 PM Re: V5 Engine,Please Explain It
    tomxt99
    • Joined on Fri, Dec 14 2007
    • Posts 1,110
    Hi Patch,
    Not sure on the technical bit but think its 2 at the back, 3 at the front Tongue Tied
    Heres a pic if this helps:
    All I know is the 150 has HT leads and the 170 has coil packs.
    Great sound though I love it Smile
    Tom
  • Mon, Sep 1 2008 2:09 PM Re: V5 Engine,Please Explain It
    xmarktx
    • Joined on Mon, Sep 26 2005
    • Posts 1,845
     bank of 2 then 3 from what i can gather a very impresive engine but the one to go for is the red 5 as it got extra valves and a few tweaks
  • Mon, Sep 1 2008 2:12 PM Re: V5 Engine,Please Explain It
    v64mobora
    Bora V6 4motion 2.8 24v 204PS
    • Joined on Sat, Sep 8 2007
    • Posts 2,421
    afaik its and adaptation of the vr6 with basicly a cylinder loped off
    http://www.youtube.com/watch?v=JUkaYtMaCeQ
    216 bhp
    David
  • Mon, Sep 1 2008 2:14 PM Re: V5 Engine,Please Explain It
    • Posts 8,837
  • Mon, Sep 1 2008 6:13 PM Re: V5 Engine,Please Explain It
    Gti Fly
    Golf IV R32 3.2 240PS
    • Joined on Wed, Sep 11 2002
    • Posts 5,965
    it's a 5cylinder version of a vr6,   so basically a vr6 with a cylinder lopped off.
    It's actually a VR5,   meaning inline V5,   so the banks of cylinders are set in a v format, but inline-ish,   very odd layout to be honest,  not sure why VW did make it,  lots of design issues to get around to make it work right,   inherent unbalanced nature for a start,   but it does make a very nice noise
    Click for pics of my car
    click for rolling road vid
    Shoulda got a 150 tdi - everyone knows they are best
  • Tue, Sep 2 2008 6:56 AM Re: V5 Engine,Please Explain It
    Coggy
    • Joined on Mon, Jun 30 2008
    • Posts 145
     Shorter than an in-line six
    Not so wide as a V6
    That's probably why they made it
  • Tue, Sep 2 2008 8:20 AM Re: V5 Engine,Please Explain It
    davemarkey
    Golf IV V5 2.3 10v 150PS
    • Joined on Sat, Jun 18 2005
    • Posts 1,613
     The V5 engine is a V form engine with five cylinders, though this engine is not a true twin-bank V engine, but rather a VR5, or staggered bank straight five engine, and therefore not a true V5. The engine is derived from the VR6, and is thus a staggered 5, and has much in common with Volkswagen's earlier straight 5 developed in the 1980's for the Passat and Audi Quattro.
    Volkswagen's VR5 is a 2.3 litre gasoline engine descending directly from the older VR6 from which VW removed a cylinder creating the first block to use five cylinders in a V design.
    Taken from the golf v5 forum.
    "davemarkey"
    aka
    Sunny
  • Tue, Sep 2 2008 8:32 AM Re: V5 Engine,Please Explain It
    ajb100
    • Joined on Mon, Jan 8 2007
    • Posts 4,598
     they are on an 11degree V, and so i have been told on good authority that they were originaly designed for the american marked who have their great detest for 4 pots.
    using the 11 degrees, they are shorter than a straight 5 allowing it to be fitted transversely in the golf while still having the properties of a straight engine
    that v5oc explanaition is basicaly wiki
    dont know much about the firing order on them though, although would guess it would be similar to a 3 cylinder engine
    to big see forum rules *ahem* too
  • Tue, Sep 2 2008 8:47 AM Re: V5 Engine,Please Explain It
    davemarkey
    • Posts 1,613
    Taken from the VW self study manual on the Vr5 engine
    Why do V-engines exist?
    Front-wheel drive, in combination with a transversely mounted four-cylinder inline engine, is now part and parcel of many motor vehicle
    concepts. Installing the engine transversely has promoted the development of more compact vehicles. But the vehicle width is not sufficient to
    accommodate inline engines with more than four cylinders.
    This is why the V-engine came into being.
    Al-though V-engines have a very short overall length, they are rather wide - with a V-angle of 60° or 90°
    - and hence cannot be used in smaller mid-range vehicles.
    V-engine with an angle of 15
    The VR engines and the new V5 engine combine the advantages of the V-concept with the advantages of the inline engine.
    These are:
    short overall length thanks to V-angle,
    small overall width thanks to the
    V-angle of 15
    only one cylinder head is required,
    The V5 was derived from the VR6 by removing the 1st cylinder from the latter.
    The resulting, even more compact design makes it possible to use this powerful unit in all vehicle classes.
    Engine code
    AGZ
    V-angle
    15°
    Displacement
    2324 cm
    Bore 81.0 mm
    Stroke
    90.2 mm
    Compression ratio
    10.0 : 1
    Firing order
    1 - 2 - 4 - 5 - 3
    Mixture preparation and ignition Bosch Motronic M3.8.3
    Fuel
    95 RON unleaded premium
    Exhaust gas aftertreatment:
    Three-way catalytic converter with lambda control
    "davemarkey"
    aka
    Sunny
  • Tue, Sep 2 2008 8:52 AM Re: V5 Engine,Please Explain It
    SiGainey
    • Joined on Mon, Mar 6 2006
    • Posts 688
    Yeah, it's not a V as in V8 with two banks of 4, it's basically 5 cylinders diagonally arranged in the minimum amount of space. Great sounding engines Smile
    2001 Golf Mk4 V5 170 :)
    2005 Mazda RX-8
    2000 MY00 Impreza UK Turbo 2000
    *** VAGCOM scan / fault code clear in Chester and North Wales areas ***
  • Tue, Sep 2 2008 8:59 AM Re: V5 Engine,Please Explain It
    Coggy
    • Posts 145
     The other thought is five instead of six will result in better fuel consumption, all other things being equal
