World leaders in performance software
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Tuning Forum » remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Last post Sat, Sep 27 2008 9:23 AM by sassy-sarah. 30 replies.
Page 1 of 1 (31 items)
  • Sat, Sep 6 2008 7:19 PM remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Joined on Sat, Jun 14 2008
    • Posts 23
     Hi i have a standard 1.8 t agu with a ko3. i have had a remap on it today. before remap the dyno showed me having 164bhp and only 140 lbs torque. after it shows 188bhp and 171lbs torque. im sure the torque should be higher. ??? Also car was running at 6psi before and is now at 10 psi...... the guy said to me i prob have a boost leak.
    i have also noticed a loud whistling noise from the car when i accelerate. do i have a boost leak and if so how do i go about finding it??? i only ask as i wanna go k03s but want this sorted 1st. cheers ppl.
  • Sun, Sep 7 2008 4:32 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    coxo
    • Joined on Mon, Mar 3 2008
    • Posts 62
    did he run vag com before the map to find the boost leak if so he should have not done it till you got the boost leak fixed that my thoughts coz i have been flipped in the past with people saying the can map cars and they cant they just want your cash
    as for leaks check the pipes on the intake mannifold and underneth it
  • Sun, Sep 7 2008 6:38 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     i dunno if he ran vag com. he pluged lap top into it. can any garage use vagcom onto it or is it a specialist thing?? cheers
  • Sat, Sep 20 2008 2:00 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    daz749s
    • Joined on Fri, Nov 17 2006
    • Posts 64
    The whistleling noise you now here is the turbo now that it has that extra psi. The BHP figure isn't bad and you have to remember that the bhp figure will vary from car to car. There are several things you can check yourself like the turbo pipes as already suggested, but also check MAF, spark plugs as these two items can seriously affect the performance. Are you running a standard diverter valve? The standard items are known for splitting even from new and thus causing boost leak. If thats the case get a baileys (my fav) or a forge as most people on here go for. Oh easy way to test DV valve is to take it off and see if you can blow through it, if you can, then BIN it. If after checking all this then it's probably worth getting someone to run VAGCOM for you. Oh and if all is ok then it just may be that the map on your car isn't very good! And maybe you should take the car back to the company and get it done again at their cost. Must check everything else first for yourself to make sure everything is as it should be.
  • Sun, Sep 21 2008 11:18 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     thanks for info. i was told as my car is an agu you cant run vag com. if you can do you know where i can go to do so. i am goin to get a mechanic to look at pipes as i have and dont know what im looking for. i have not checked the dv its atd. i will take off now and check. how do i check maf? i want to put a ko3s on but want all this sorted 1st. then ill take it back to the place i got it mapped. what model dv do u recommend ? a recirc one or blow off? i want a nice sound. cheers mate
  • Sun, Sep 21 2008 11:38 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Joined on Sun, Aug 17 2008
    • Posts 295
    yes hun you can run vagcom on an agu.
    i have a forge recerc dv. to be honest, its not that loud but aparantly its better for your turbo.
    i also have a blow off dv in the house thats slightly louder but not much.
    Sassy Sarah, rolling in my jazz blue 20VT mmmm!
    Photobucket
  • Mon, Sep 22 2008 1:28 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     do u know where i can get someone to run vag com? do garages have it? have you got the forge 007 one?
  • Tue, Sep 23 2008 7:58 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    ColinT
    • Joined on Mon, Mar 14 2005
    • Posts 115
    flexie:
    Check the vag-com section.  Loads of guys on here have it.  I'm in Scotland so can't help but there will be somebody closer to you on here.
    More smiles per mile in the 220bhp/324 ft-lb oil burner Big Smile
  • Tue, Sep 23 2008 2:46 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    rydinator
    • Joined on Wed, May 14 2008
    • Posts 14
    i cant help you the vagcom, as with the figures that have been produced, the ecu needs a couple of weeks to get use to the remap and fuelling etc, but if you were to take it back to get it rolling road tested again, then you should see a change in figures.
    volkswagen mk4 golf gti turbo - Anniversary body kit, Rs4 alloys wrapped in Goodyear eagle F1 tyres, Tinted windows all round, Lowered on anniversary suspension and eibach pro springs, Forge re-circulating dump valve, Personal plate V5 DUB plus many more future plans...
  • Wed, Sep 24 2008 4:24 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     well i have left it two weeks and its still boosting to a max 10psi. im sure it should be higher. the guy who mapped it said i should put a bleed valve on it to turn psi up. surely i should just find the leek right? do u know where to go on here to find vag com? cheers
  • Thu, Sep 25 2008 6:45 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
     this is wot i have about £80
    Forge FMCL007P Diverter Valve - Golf 4 1.8T 07/97>
     this is wot i want about £130
    Forge FMDVSPLTR Recirculating/BO Valve - Golf 4 1.8T 07/97>
    Photobucket
  • Thu, Sep 25 2008 7:20 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Khalid23
    • Joined on Mon, Mar 10 2008
    • Posts 83
    sassy-sarah:
    Got the splitr on my car and sounds quite loud (well enough for me anyway) Had it about 9 months.....
  • Thu, Sep 25 2008 7:26 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
    does your car run ok with it? my m8 had one on his ibiza and it ran like shoot.
    i just think itl sound nice, and be better for my turbo.
    Photobucket
  • Thu, Sep 25 2008 8:04 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Khalid23
    • Posts 83
    sassy-sarah:
    i was really wary about getting it fitted as a lot people complained about atmospheric valves being no good for the engine, so did my research and couldn't find any people who had complained about it - the only niggles people had was that it wasn't loud enough. Don't know much myself but i do know that the pipes that fit to it, fit in the opposite way to the standard bosch one.
    I have heard that if you want it louder you will have to get a cold side relocation kit.
    All in all im am more than pleased with it, the little whooosh always puts a smile on my face! and as mentioned before, it's been about nine months since i had it fitted....
  • Thu, Sep 25 2008 9:21 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
    cheers hun. ive enquired about the cold side relocation kit, and the company that are doing my remap, sez that they dont make that much of a difference to your dv or the performance, its just a good way of getting money out of you...
    the dv that i have on makes a slight swoosh but sounds nice when your sat in the car :)
    Photobucket
  • Thu, Sep 25 2008 10:11 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     whats louder the 007 or splitter? is the relocation hard to do??
  • Thu, Sep 25 2008 10:14 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
    the 007 is louder than the standard one, but not really noticable outside of the car.
    this is the relocation kit on a car.
    go to http://www.dpmperformance.co.uk they sell everything on there, and damian is really really canny
    Photobucket
  • Thu, Sep 25 2008 10:31 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     cheers will it be louder with a airfilter on it??
  • Thu, Sep 25 2008 10:34 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    flexie
    • Posts 23
     also do u know where i can get someone to find my boost leak. its hard to find someone who knows what they are talking about lol. its winding me up. making me feel like selling the car and getting another celica lol
  • Thu, Sep 25 2008 10:56 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
    i have a k&n pannel filter, dont know if it makes it any louder coz it was on when i bought the car...
    i dont know of any in your area hun and ive never had a boost leak on mine, so i cant help you on that one Sad
    Photobucket
  • Thu, Sep 25 2008 11:57 AM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • Joined on Sat, Mar 1 2008
    • Posts 673
    Does the car make a loud hissing noise in the higher RPM's?
  • Thu, Sep 25 2008 2:27 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Khalid23
    • Posts 83
     with mine fitted with no other mods sounds pretty loud on the inside and from out.....
    got these clips from youtube which kinda give you a good idea of how it sounds
    http://www.youtube.com/watch?v=Rmi115eLTCo
    http://www.youtube.com/watch?v=GyOzIHreUNs
  • Thu, Sep 25 2008 2:39 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    sassy-sarah
    • Posts 295
     mine sounds nowt like that!
    Photobucket
  • Thu, Sep 25 2008 3:28 PM Re: remap help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
