uk-mkivs » Technical Community » D.I.Y Guides and How to Instructions. » W8 Install guide (Foxy's original)
Last post Sat, Feb 27 2010 4:12 PM by Stokie_Mac. 28 replies.
Page 1 of 1 (29 items)
  • Tue, Sep 30 2008 5:54 AM W8 Install guide (Foxy's original)
    • Posts 8,141
     As Foxy's web site is no longer available here is the original guide taken from the web archive: It is back online again, see link further down the thread Yes
    Existing wires:
    Blue-white        Blue-red        Brown
    Insert wires into only pins 1, 3, 4 & 5.
    New wires connect to existing as follows:
    New wire to pin 1
    Blue-white to pin 3
    Brown to pin 4
    Blue-red to pin 5
    Pull the plug from the back of the instrument light Dimmer/Headlight adjuster unit.
    The purple wire, next to the brown is the illumination wire that I used - not dimmed.
    Use a skotch-lok or cut, solder and heat-shrink like this.
    Another forum member has kindly noted that the light is a very tight fit, as the insulation behind the headlining partly interferes with the new plug when you push the light up into the aperture.
    To quote his guide:
    "When reinstalling the panel, I found it was very tight - infact too tight. I found the extended plastic for the wiring plug on the panel is fouling with some insulation in the headlining. There isnt enough room for it to basically push back and the the metal clips push in. So I had to cut off a piece of the polystyrene foam insulation, just hacked it with a stanely knife. I made a little section, so the wiring plug can sit in there perfectly."
    Thanks to Aamer!
    Total cost: Approx £25 GBP
    Time taken - 30 minutes
    Part numbers:
    Light: 3B7947105F2EN
    Plug: 3B0972706
    Wires: 000979131A - two off required.
  • Tue, Sep 30 2008 11:13 AM Re: W8 Install guide (Foxy's original)
    Simpy2k
    • Joined on Sun, Oct 21 2007
    • Posts 513
     Thanks for digging that up for me! What thickness is the extra cable i need and how much? Was gonna ask another forum member to gives a lift but looks simple enough on that guide!
    Un-phased.com - Northwest's No1 VAG Site!
    STANCE AINT A CRIME http://www.edition38.com/forums/index.php?showtopic=216209
  • Tue, Sep 30 2008 3:32 PM Re: W8 Install guide (Foxy's original)
    Del-Gti
    • Joined on Sat, Aug 28 2004
    • Posts 378
    I was just looking for that last week, as it's been so long since i fitted one in my last car, i'd forgotten how to do it.
    Cheers mate.
    Cool
    2002 52 Plate GTi TDi Pd150. Full Votex kit, 18" BBS CH'S,Falken SS 595's, Xenons, ESP, Heated Leather Recaro's, Climate Control, Cruise Control, Winter pack(headlamp washers, heated seats, auto wipers, auto dimming mirror). MP3 + IPod.
  • Tue, Sep 30 2008 7:06 PM Re: W8 Install guide (Foxy's original)
    Simpy2k
    • Posts 513
     What thickness wire do i need for the long piece?Also could i not just put this directley into Pin 1 so im not joining another wire together?
  • Mon, Feb 16 2009 2:46 PM Re: W8 Install guide (Foxy's original)
    Foxy
    • Joined on Wed, Jun 5 2002
    • Posts 4,485
    Hey nice write up !!!
    My website is back up for now.......you can find it here:  FOXYS SITE
    See my website again: http://www.foxytech.hostcell.net/
  • Sun, Mar 15 2009 12:09 PM Re: W8 Install guide (Foxy's original)
    triman
    • Joined on Mon, Aug 7 2006
    • Posts 49
    Excellent guide. Just managed to finish fitting W8 light with kufatek purpose made loom. Needed this guide to help with fitting as no instructions from Kufatek
    Black 3 Door GT TDI 150 PD
    Performance Torque Remap, Stubby Aerial, Anniversary Headlights, KVW100 (Auto Windows),Miles to Empty, Illuminated needles,Cruise Control, Anti Hijack, Aero Rear Wiper, Armrest, 312mm Front Brake Upgrades,Eibach Proset Springs/Dampers,more to come.........Milltek,/ Eibach ARB
  • Tue, Apr 21 2009 1:50 PM Re: W8 Install guide (Foxy's original)
    danielsemaj
    • Joined on Tue, Apr 14 2009
    • Posts 306
    iv seen all this fuss around the so called w8 light and have no clue what the added benifits are? would someone be able to help?Big Smile
    Carbonio CAI | Forge 007-P | Forge TIP | Milltek Turbo Back | Yellow Stuff Pads & EBC Disks All Round
    Now Selling As Above 64k 5 DR Black 2000 PM ME!!!
  • Tue, Apr 21 2009 2:01 PM Re: W8 Install guide (Foxy's original)
    rsKien
    • Joined on Sat, Dec 20 2008
    • Posts 884
    Foxy:
    Doesnt work dude...
  • Thu, Jul 16 2009 3:39 PM Re: W8 Install guide (Foxy's original)
    Foxy
    • Posts 4,485
    Guys I have managed to find a free hosting service - you can see my website again, HERE
  • Wed, Sep 9 2009 8:58 AM Re: W8 Install guide (Foxy's original)
    deejayh
    • Joined on Sun, Sep 6 2009
    • Posts 10
    Foxy:
    till not working - website is - but the pictures are missing!
    As said previously - by fitting this W8 - what benefits are there?
    regards,
    Dave
  • Wed, Sep 9 2009 9:26 AM Re: W8 Install guide (Foxy's original)
    • Posts 8,141
  • Wed, Sep 9 2009 10:26 AM Re: W8 Install guide (Foxy's original)
    deejayh
    • Posts 10
    Cannot understand why I cannot see them then?
    Why is the W8 any good?
  • Tue, Sep 29 2009 3:46 PM Re: W8 Install guide (Foxy's original)
    Foxy
    • Posts 4,485
     It has illuminated icons on the switch.
  • Tue, Sep 29 2009 4:50 PM Re: W8 Install guide (Foxy's original)
    craigolfmk4
    Golf IV 1.6 8v AKL 100PS
    • Joined on Sun, May 25 2008
    • Posts 463
    Thanks for this. It's a great help.
    FOR SALE (PM or see classifieds) : Speedo/rev counter etc. dial aluminium rings £30 posted | Genuine rear bumper in Bright green pearl £30 | 14" steels with legal tyres £40
  • Tue, Sep 29 2009 4:59 PM Re: W8 Install guide (Foxy's original)
    ndb18t
    • Joined on Sun, Mar 4 2007
    • Posts 1,430
    I have wired up my w8 light, however i am now unable to screw it in due to the alignment of the holes, one screw will go into the hole,any ideas on what I can do to screw in as I have had it for weeks not screwed in!!! thanks
    FOR SALE ***R32 FULL leather interior- 4door*** pm me
    ***Genuine mk4 r32 wing mirrors £140 delivered***
    ****R32 4 door mats, r32 tailgate with roof spoiler!,
    vw satnav mfd 'D'!**** pm me
  • Wed, Oct 7 2009 11:58 AM Re: W8 Install guide (Foxy's original)
    Flamotronic
    • Joined on Mon, Jun 29 2009
    • Posts 232
     Hi,
    Resurrecting an old thread, but does anyone know how much the W8 light (Grey and Sunroof version) costs at the stealers?? Just been on the phone with one and they're saying £35.00 (grey with sunroof as well!!)! Is that too good to be true? I could swear they go for much more than that.
    Apparently, however, the illuminated sunroof rotary knob is £56.00 - now that's more like it! Paper bag
    ~Flamous
    :~ Kazi
    Any views (facts or opinions) expressed by Kazi ("Flamotronic") may not necessarily represent the views of 'uk-mkivs.net' or its affliated members and associates. Views expressed by Kazi should not be relied upon without verification and he will not be responsible for negative consequences arising as a result of relying on his views. His posts are subject to change at anytime.
    Please note: members, regardless of their forum positions, knowledge, experience, and establishment, must respect others (speak good or stay silent).
  • Thu, Oct 8 2009 2:43 AM Re: W8 Install guide (Foxy's original)
    cenobytez
    • Joined on Thu, Jun 7 2007
    • Posts 1,397
    deejayh:
    it also has the red illuminated downlighter led
    GT TDI 130 PD Highline ¦Genuine R32 Front+Rear Bumpers ¦ Sachs uprated clutch ¦ Milltek R32 complete Stainless Exhaust + Decat downpipe ¦ Custom Remap ¦ Rep R32 mkV alloys running Yokohama Parada II ¦ SAT-NAV ¦ Winter Pack ¦ auto-windows ¦ illuminated needles ¦ miles-to-empty ¦ Tints ¦ Sunglasses Holder ¦ K&N panel filter ¦ powerflex bushes ¦ Sharan badge ¦ Lowered 35mm springs ¦ Rain-sensing wipers
  • Tue, Oct 13 2009 3:09 PM Re: W8 Install guide (Foxy's original)
    Flamotronic
    • Posts 232
    Is it compulsory or recommended to disconnect the battery when fitting the W8 light? In my case the only cutting I would be doing is using a scotch-lok...
    Is there a fuse instead I can remove to prevent electrical damage?!!
    "Prevention is better than cure" - that's why!
    ~Flamous
    :~ Kazi
  • Tue, Oct 13 2009 3:13 PM Re: W8 Install guide (Foxy's original)
    peace1969
    Golf IV V5 2.3 10v 150PS
    • Joined on Sun, Sep 25 2005
    • Posts 2,249
    Flamotronic:
    ~Flamous
    I just fitted mine i didn't disconnect the battery etc.
    Bora Vents & Bora Sport Clock
    US Spec R32 Tail Lights
    W8 Light Blue Leds
    VCDS 908.1 key Usb & Vagtacho 2.5
  • Tue, Oct 13 2009 3:36 PM Re: W8 Install guide (Foxy's original)
    Flamotronic
    • Posts 232
    peace1969:
    Flamotronic:
    ~Flamous
    How did you fit yours, if you don't mind my asking? Did you cut any of the original wires, soldering, etc., or did you use the conversion loom to connect the light unit and then use scotch-lok to connect to the dimmer switch? Does it depend on the methods employed which will dictate whether or not the battery needs to be disconnected.
    I just don't want the hassle of disconnecting the battery and losing all the data, e.g. radio code, window roll-up safety feature and ECU data, that's why I'm asking! Lol Blah Blah
    ~Flamous
    :~ Kazi
  • Tue, Oct 13 2009 3:47 PM Re: W8 Install guide (Foxy's original)
    peace1969
    • Posts 2,249
    When i bought my one it came with the loom from Germany as i wanted blue led, it was plug and play except for the illumination, i used scotch-lock to connect to the dimmer switch dead easy to fitYes
    W8 Light Blue Leds
  • Tue, Oct 13 2009 5:49 PM Re: W8 Install guide (Foxy's original)
    Flamotronic
    • Posts 232
    That's exactly the kit I've got, Peace1969. So I'm assuming then, providing that I fit the light carefully I shouldn't have to disconnect the battery, yes?
    ~Flamous
    :~ Kazi
  • Tue, Oct 13 2009 5:53 PM Re: W8 Install guide (Foxy's original)
    peace1969
    • Posts 2,249
     Nope no need to disconnect the batteryYes
    W8 Light Blue Leds
  • Tue, Oct 13 2009 6:05 PM Re: W8 Install guide (Foxy's original)
    spender86
    • Joined on Sat, Apr 5 2008
    • Posts 614
    Has anyone got the current price for the parts from the dealers?
  • Tue, Oct 13 2009 6:13 PM Re: W8 Install guide (Foxy's original)
    peace1969
    • Posts 2,249
    The Stealers might cheaper though
    clicky
    clicky
    W8 Light Blue Leds
  • Fri, Nov 27 2009 11:11 AM Re: W8 Install guide (Foxy's original)
    cheshiresport
    • Joined on Sun, Jul 20 2008
    • Posts 254
    peace1969:
    Where did you get the w8 light with blue led's?
    WANTED: Immo 3 Diesel FULL FIS Bora Sport Clocks. PM me if you have any for sale. Also R32 Dead Pedal Wanted
  • Sat, Feb 27 2010 3:47 PM Re: W8 Install guide (Foxy's original)
    Stokie_Mac
    • Joined on Thu, Jul 30 2009
    • Posts 273
    SUPERB Guide..
    Yes
    I will be fitting one of these myself soon..
    Be LOYAL..
    Be PROUD..
    Be STOKE!!..
  • Sat, Feb 27 2010 3:53 PM Re: W8 Install guide (Foxy's original)
    • Posts 8,141
     I hope you know what you are doing with electrics Stick out tongue
  • Sat, Feb 27 2010 4:12 PM Re: W8 Install guide (Foxy's original)
    Stokie_Mac
    • Posts 273
    I can only BLOW myself up once cant i Neil..
    LOL..
    Big Smile
    :electricf::electricf::electricf::electricf::electricf::electricf:
    Be LOYAL..
    Be PROUD..
    Be STOKE!!..
