Hampshires Premier VAG Servicing, Diagnostic and Tuning Centre
uk-mkivs » The Mk4 (MkIV) Community » MkIV Performance and Technical Area » Mk4 - Bodywork, Kits and Repair » My drivers door dropped.....
Last post Tue, Nov 4 2008 2:54 PM by LSH. 19 replies.
Page 1 of 1 (20 items)
  • Mon, Oct 6 2008 2:56 PM My drivers door dropped.....
    • Posts 9,545
    .....by a couple of mmCrying.
    Is it just a case of loosening the bolts VERY SLIGHTLY where the hinges bolt onto the door and putting a jack under the bottom edge of the door?
    DLS Iridium 8.3,Vibe Space 12 V3,Vibe Bass 4,Vibe Stereo 2,Vibe Stereo 4,17in RS4 reps + 50% tints.
    Coming soon...Image Dynamics CD2 horn loaded compression drivers (oooh get me!)
  • Tue, Oct 7 2008 2:30 PM Re: My drivers door dropped.....
    • Posts 9,545
    Anyone?
  • Tue, Oct 7 2008 3:18 PM Re: My drivers door dropped.....
    dieselpowered
    • Joined on Sun, Sep 7 2008
    • Posts 29
     I believe its a case of loosening the lower hinge bolts from inside the car then adjusting and re tightening. Some people are just brave and place a trolly jack under the door with a block of wood to protect the door, they do this with the door slightly open. You can buy a snap on tool to adjust the door for around £50 also.
    I've got to do mine when I get round to it.
    p.s Manual says replace the door bolts if you loosen them.
  • Wed, Oct 8 2008 2:04 AM Re: My drivers door dropped.....
    • Posts 9,545
    dieselpowered:
    Thank you,can anyone confirm this is because they use stretch bolts and what would happen if you reuse the old ones?
  • Wed, Oct 8 2008 2:33 AM Re: My drivers door dropped.....
    myboozyhell
    • Joined on Wed, May 14 2008
    • Posts 177
    Chris, the clue is in the name of the bolts.... Wink
    No, seriously, these type of bolts always create debate as to whether you can or cannot use them again - much like brake caliper bolts...
    Personally, for the sake of a couple of quid I'd renew them - you'll more than likely get a repeat of your problem if you re-use the existing ones - not so bad on your door but I'd never re-use caliper bolts (why do you think they give you new ones of them in the box with new pads......?Confused)
    Ben
    Gone, but not forgotten.....
    Reflex Silver Mk4 Golf V6 4Motion (03)
    Indigo Blue Mk4 Golf GTTDI PD130 (03)
  • Wed, Oct 8 2008 3:12 AM Re: My drivers door dropped.....
    Mav18t
    • Joined on Sun, Jul 16 2006
    • Posts 1,154
     I used the above brave method, just jacked it up, Did this about 6 months ago and all is still fine.
    Wasn't too worried as I have to get a new door anyway from a previous bump
  • Wed, Oct 8 2008 12:59 PM Re: My drivers door dropped.....
    Chrisdut
    • Joined on Sat, Sep 27 2008
    • Posts 171
    get 2 people, 2 strong people
    open the door slightly and put the window right down, you need to try and keep the door as closed as poss with out the latch catching, this allows the hinge adjustment to work
    now both of you get to the rear edge of the door one inside the window frame and one at the bottom edge of the door and you both need to lift at the same time, i.e lifting the rear of the door towards the roof
    it will take some lifting and might well seem like it isnt having any effect
    might take a few attempts to get it spot on but saves a hell of a lot of messing about undoing bolts etc
    we do this all the time in work when doors drop
    as i say tho make sure there are 2 of you, i tried it a while ago on my own and put my back out for about 2 months
    52 Plate TDI Silver Anniversary, modding has begun.
    Pressed Steel number plates, Auto lock/unlock, Alarm bleeps, Needle illumination, MTE activated, Cruise Control fitted, Comfort Indicators fitted, Bora vents fitted, parrot CK3200 bluetooth kit fitted, Delocked, modified fan fix fitted.
    Genuine Armrest fitted, W8 light sprayed and fitted.
    Mods to do : Red GTI badges front and rear, auto windows by remote, Allard EGR kit, Remove and clean inlet manifold, Fit newly referb turbo :-)
    ___________________________
    VW Maindealer Master Technician.
  • Wed, Oct 8 2008 4:10 PM Re: My drivers door dropped.....
    Mav18t
    • Posts 1,154
    Chrisdut:
    Why not just use a jack?
  • Wed, Oct 8 2008 4:16 PM Re: My drivers door dropped.....
    kalu
    • Joined on Sat, Apr 21 2007
    • Posts 610
    Mav18t:
    Chrisdut:
    +1 used a jack many times with a rubber block or piece of wood without loosening bolts.
    Also seen many approved bodyshops also do it this way.
    Need some help? with...Vagcom, Keys/Immobilser adaption/defeat, Ecu/Cluster Swap. Miles to Empty/Illuminated Needles, Autowindows etc... PM me :)
  • Wed, Oct 8 2008 4:27 PM Re: My drivers door dropped.....
    Chrisdut
    • Posts 171
    Mav18t:
    Chrisdut:
    cant use a jack on a toaureg door as the bottom is plastic
    might try it on the next mk4 but just think it could damage the door if it slips etc
  • Thu, Oct 9 2008 12:34 PM Re: My drivers door dropped.....
    • Posts 9,545
    Thanks everyone,think I'll rout a groove into a block of softwood and use the jack method.
  • Thu, Oct 9 2008 1:11 PM Re: My drivers door dropped.....
    VR6Rich
    Bora V6 4motion 2.8 24v 204PS
    • Joined on Tue, Jan 10 2006
    • Posts 984
    Let us know how you get on Chris as I need to sort out my drivers door as well.
  • Fri, Oct 10 2008 3:28 AM Re: My drivers door dropped.....
    Dod 1396
    • Joined on Tue, May 16 2006
    • Posts 1,298
    Chrisdut:
    I took my old car to a garage about this problem,they did the exact as above...My chin hit the floorSurpriseto be fair it did work..Was a brown trouser moment thou.lol
    Anni Items for sale:
    25th Anniversary Sales Brochure:
    http://uk-mkivs.net/forums/t/217507.aspx
    AutoCar 25 yrs of the GTI Supplement:
    http://uk-mkivs.net/forums/t/217513.aspx
  • Sun, Oct 12 2008 2:00 PM Re: My drivers door dropped.....
    Chrisdut
    • Posts 171
    well tried the ramp leg and wooden block method under my drivers door today, worked like a treat
    no more bad backs for me lol
  • Sun, Oct 12 2008 2:59 PM Re: My drivers door dropped.....
    skierandy
    Golf IV R32 3.2 240PS
    • Joined on Sat, Oct 29 2005
    • Posts 2,595
     so does this solve the problem of the door not closing without slamming it...
    u literally put the jack and wood block under the door and pump it up slow...... no slackening bolts or anything?
    door closed as much as possi or.....
    thanks
    Andy
    Full List of 1.6 mods clicky!!!
    www.skiandboardshop.co.uk
    PARTS FOR SALE (mk4 all mint cond.): suspension, tail lights
  • Sun, Oct 12 2008 3:12 PM Re: My drivers door dropped.....
    Chrisdut
    • Posts 171
    to find out if the door need lifting, kneel down next to the closed door, and pull the handle to open the door, while doing so look at the door lines to see if you notice the door drop as it opens, then try it the other way to see if it lifts up as it close's
    if it does then it needs adjusting, and yeah as you say, door closed as poss and jack the door only up at the rear edge, took me 2 attempts to get it spot on but all is super smashing great now
  • Sun, Oct 12 2008 4:44 PM Re: My drivers door dropped.....
    skierandy
    • Posts 2,595
     but im guessing dnt jack it too far lol
  • Sun, Oct 12 2008 4:47 PM Re: My drivers door dropped.....
    Chrisdut
    • Posts 171
    if you jack it up to high, hang your weight on the top of the door to pull it down again, it will sone become obvious dude
  • Mon, Oct 13 2008 2:12 AM Re: My drivers door dropped.....
    • Posts 9,545
    Had to loosen off the top bolt by about a turn,jack and block of wood under the back of the door and now it's spot on,the longest part of the job was adjusting the striker plate.
  • Tue, Nov 4 2008 2:54 PM Re: My drivers door dropped.....
    LSH
    • Joined on Sat, Jun 2 2007
    • Posts 384
    Imagewerx:
    May I ask how you noticed that it dropped a couple of mm's? Was it that the door became very hard to open/close etc.? or creaking noises occuring?
    Luke
    BRAND NEW MILLTEK EXHAUST (ANNIVERSARY TIP):
    http://uk-mkivs.net/forums/t/230860.aspx
    25th Edition GTI Anniversary 1.8T (36k) -> Custom Code Mapping | Custom Plates | De-Locked | | Electrical Work (Anti-Hijack, etc.) | Forge ‘Stumpy’ Aerial | Green Panel Filter | H&R Rear ARB | Hella RBBR Clusters | Polo Aero Rear Wiper | R32 DSG Intake | R32 Door Triggers | S3 Lower Strut Brace | Sharan Rear ‘VW’ Badge | Tracker | TT Short Shifter…
    OEM & that extra little bit...
